Old 11-03-2012, 06:13 AM   #31366
scoprire
scoprire's Avatar
Oddometer: 171
Originally Posted by ba_ View Post
I'm trying to find a place online to purchase the longer pinch bolts needed when I mount the Cycra triple clamp side mounts for handguards.
*** Edit:
I found this:
http://www.probolt-usa.com/stainless...l#.UJPrLGl26To
I've had good luck getting individual stainless bolts from http://www.desmoparts.com/ High quality bolts, great selection too. He has kits for some bikes, but a separate page for individual sizes.
Paul
08 DL650
08 WR250R
No one can see you posing in a blizzard.
scoprire is offline   Reply With Quote
Old 11-03-2012, 06:46 AM   #31367
markk53
jack of all trades...
markk53's Avatar
Oddometer: 6,587
Originally Posted by HardWorkingDog View Post
Those stainless steel bolts are OK (pricey), but my solution to finding longer good quality flange head metric bolts is my local Honda car dealership's parts department.
The local Ace Hardware has metric flange bolts but they are generic Chinese crap with poorly made threads and rough finishes--not something I trust to hold critical loads or look at and feel like ...
Turns out Honda's parts numbering system for bolts is readily decoded, and they use the same parts numbers for both motorcycles and cars. An 8x55 flange bolt is 95701-0805508. High quality Japanese-made, beautifully formed and spec'd. to meet the strength needed here. Call your nearest Honda car parts department, ask for that number, if they don't have it in stock they'll get it usually the next day. I paid about $1.25 per bolt, well worth it.
95701 = flange head bolt
08xxxxx = 8 mm dia.
xx055xx = 55 mm length
xxxxx08 = thread pitch??? (less certain about this...)
In reading this, I had some thoughts since I've had to deal with metric hardware in a sideline project making cam chain tensioners. If you did some digging might find the 8 is a rounded M8-.075 fine thread pitch. They do two fine pitches, M8-1.00 and M8-.075 threads per millimeter. But I'm guessing. The coarse 8mm thread is M8-1.25 threads per mm.
Here is a link to the ISO charts
I buy bolts at Fastenal, where they can be ordered individually (if not in stock and usually not). Problem is washers and nuts are not sold in singles. Just pointing out the alternative. I am fortunate in having a really good old style hardware store for the goofy or single stuff. I use Fastenal for my quantity purchases though.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 11-03-2012, 07:01 AM   #31368
markk53
markk53's Avatar
Oddometer: 6,587
Make sure you use anti-seize on them for sure when steel on stainless or stainless on stainless. I am not sure about aluminum. Seems when the bolts/nuts are threaded together the scraping of the surfaces causes some removal of a material that surfaces to avoid corrosion, then the material will bond together - aka sieze up. My brother used stainless for a nut/bolt pinch clamp on a Betor fork axle clamp. They seized and he had to snap the bolts to get them off.
I'd certainly check on the aluminum/stainless reaction to be sure. Here's Fastenal's take on it.
Here's another expert's take from an expert in the industry based on what I've found on a net search, Joe Greenslade.
Mark - klx678
Old 11-03-2012, 08:52 AM   #31369
Mr. Fisherman
oneandahalfassed
Mr. Fisherman's Avatar
Oddometer: 9,800
Originally Posted by Joe Watson View Post
Any Aussies out there scanning this thread for info because they are looking at buying. I have just put mine up for sale. Check out all the info here:
http://www.advrider.com/forums/showp...&postcount=142
Sad..
Mr. Fisherman is offline   Reply With Quote
Old 11-03-2012, 08:56 AM   #31370
AZ TOM
Oddometer: 2,364
Radiator on the left??
AZ TOM is offline   Reply With Quote
Old 11-03-2012, 09:27 AM   #31371
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,326
Damn, good eye there Mr. Tom. I can see a guard on the right as well.
"Coffee first..."
Next Trip: didn't get enough...Death Valley
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 11-03-2012, 12:27 PM   #31372
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 96
And what's the giant skidplate plz share!
EEKAMOUSE is offline   Reply With Quote
Old 11-03-2012, 12:49 PM   #31373
Mikef5000
Oddometer: 1,668
Giant skid plate has a 'tool box' on each side.
The dual radiators is interesting!
2012 XT1200Z (Totaled - Ride/Crash Report)
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 11-03-2012, 12:59 PM   #31374
Gany
Oddometer: 191
Joe's build thread is here:
http://wr250rforum.forumotion.com/t4228-my-wr250r-build
Gany is offline   Reply With Quote
Old 11-03-2012, 04:56 PM   #31375
AZ TOM
Oddometer: 2,364
Dual radiators, a great idea, dummy radiator guard??? Seems like another place for catching dirt & mud?
Old 11-04-2012, 07:17 PM   #31376
reddirtjoe
bikehoarder/msfcoach
reddirtjoe's Avatar
Oddometer: 1,519
Fork seals? How to replace?
91 Octane? Wnere? what does everyone else do?
Nonsense, I have not yet began to defile myself
reddirtjoe is offline   Reply With Quote
Old 11-04-2012, 08:05 PM   #31377
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 8,802
I run 87 mostly, every so often I splurge and put in 93. It runs exactly the same.
Go forth, wander aimlessly, explore, have adventures and shit...
MeefZah is offline   Reply With Quote
Old 11-05-2012, 03:38 AM   #31378
Joe Watson
Joe Watson's Avatar
Oddometer: 1,002
Send a message via MSN to Joe Watson
Very very simple job:
http://youtu.be/Y43k1qFVGW4
http://youtu.be/C9ICr-DOmdk
I would never pay anyone to do my fork seals.
Joe Watson is offline   Reply With Quote
Old 11-05-2012, 07:22 AM   #31379
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 350
Originally Posted by sturgeon View Post
Something like this would also work well.
http://www.heatshieldproducts.com/pr...ield-mat/76/35
I've used it to insulate luggage from exhaust heat.
Yes but then you would have to cut and match the complex curve angles of the tank area around the fuel pump intake. So much easier to reorder the tank heat shield that comes on the OEM tank and place that around the fuel pump. That is what I did; it fits quite nicely and it took about 5 minutes with the tank off prior to its first installation.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2011 WR250R,2008 KTM 990 ADV,2004 KAWA Concours
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 11-05-2012, 11:32 AM   #31380
Cycle Sector
Aka Disco
Cycle Sector's Avatar
Oddometer: 69
Im selling my stock levers in case anyone is interested, perfect condition except for some scuffs on the tip of the brake. Im also including the stock perch. $30 plus $7 shipping takes em. Please message me.
Cycle Sector is offline   Reply With Quote
Times are GMT -7.   It's 04:30 AM.
