Old 11-05-2012, 10:21 AM   #14071
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 2,057
Thumb KLR Twin...
Originally Posted by Earthscape View Post
I also think it would be great if Kawasaki brought the KLX650 back. I don't think they gave it enough of a chance back when it was available, and the choices in that class now, at least in the US, are not plentiful. A 650 with liquid cooling, Japanese reliability and 11" travel suspension would be, and was, a great bike.
Write to Kawasaki, tell them you want it - ??
If Kawasaki builds something I personally hope it would be something a lot more like this...
http://www.advrider.com/forums/showthread.php?t=797568
That's a KLR with a Versys 650 Twin inserted into it. I have met the gentleman who built the bike in the pictures (he just purchased my personal Versys so he can build another one in a 2nd Generation KLR donor), and from what he says this type of sled might be what many of us are looking for... BTW, apparently the Versys twin is no heavier than the KLR single it replaces. He also said the Versys engine had smoother, better power in off-road situations, yet could also easily cruise at over 85 MPH all day long on the slab.
If Kawasaki could build an under 400-lb Versys-engine-based twin with *REAL* off-road capable suspension, a 21"/18" wheel combination, and a real dual-purpose riding position I think they'd have a real market winner on its hands.
Just my two centavos... OMMV.
Dallara
p.s. - BTW, the builder of the bike above is considering the idea of building these KLR/Versys hybrids and making them available for sale.
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is offline   Reply With Quote
Old 11-05-2012, 10:29 AM   #14072
simmons1
simmons1's Avatar
Oddometer: 1,567
I saw one of these at Roll the Bones a couple weekends ago:
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, GT750, H2 750, H1 500
simmons1 is offline   Reply With Quote
Old 11-05-2012, 10:43 AM   #14073
Dallara
Dallara's Avatar
Oddometer: 2,057
Laugh Same one...
That's the same bike, and the same guy... He just had his bags, skidplate, etc. mounted up. He told me he did the "Roll the Bones" rally after he had returned from his extended trip to Moab, etc.
Really nice guy. Very smart, and obviously very capable. He used the entire Versys wiring harness, Versys handlebar switch assemblies (and he even installed electronic cruise control!!! ), adapted the Versys instrument panel to the KLR dash and fairing, used an 650 Ninja twin radiator to fit underneath the KLR bodywork, adapted the Versys shift linkage, etc., etc., etc., etc.
Hard to tell Kawasaki didn't build it themselves.
Dallara
Old 11-05-2012, 11:02 AM   #14074
NicolasR
NicolasR's Avatar
Oddometer: 41
Transmission leaking??
Hi. I just got back from a 700 kilometer-ride and just saw me rear wheel being all splashed with something. Apparently my bike is leaking oil from the transmission. It had a big drop of oil still holding beneath the tranny.
It is definitely oil cause of the smell. I did the first oil change at 1000 kilometers adding the exact amount of oil the manual says and it dripped through the refilling hole.
My bike has now 3500 kilometers. Have you had the same problem?? Would it be definitely a leak??? I have heard of some bikes that have too much grease from factory in the rear spindles and it melts out as you ride.
I have another question for you guys. I keep hearing a "click" noise coming from the front end when the suspension is sagging through medium to bigger bumps. What would it be??
As you see English is not my native language!!!!
Nicolas
NicolasR is offline   Reply With Quote
Old 11-05-2012, 11:51 AM   #14075
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,241
Rare to see that clean of a frankenstien bike. At first I thought you just wanted a first
generation KLR to come back then looked close. I think I would still prefer to have it
shoe horned into the KLX model.
I bet that bike opens a few eyes to those who try and run with it not knowing what's under the hood.
pluric is offline   Reply With Quote
Old 11-05-2012, 11:53 AM   #14076
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,241
Nicolas
Check your sump area to be safe. Both drain plug zones too.
Not heard of a single leaking case without some sort of impact.
Old 11-05-2012, 12:08 PM   #14077
jaumev
jaumev's Avatar
Oddometer: 1,511
Nicolas
Hola Nicolas
I don't know about the transmission leak but check the steering bolt to the "click" noise.... as you see English is not my native language as well
Saludos!
jaumev is offline   Reply With Quote
Old 11-05-2012, 12:20 PM   #14078
NicolasR
NicolasR's Avatar
Oddometer: 41
Originally Posted by jaumev View Post
Hola Nicolas
Saludos!
Jaumev saludos. Ahora cuando llegue y vi la fuga de aceite por debajo de la transmisión la limpie, y hace unos minutos fui a ver y no tiene más aceite por ningun lado. No se que podria ser. Yo he no hecho off road como para darle un golpe como dice Pluric.
Tu tambien oias el click como por la dirección o la suspension. La tuerca que debo apretar es la que tiene el tapón de caucho??
Gracias
Old 11-05-2012, 12:26 PM   #14079
NicolasR
NicolasR's Avatar
Oddometer: 41
Pluric, I have checked my sump, my drain plugs from engine and final drive, and there is no oil coming from there. It is coming from the back of the final drive case, as if it were from the axle. Any idea??? Although I wiped the oil off and there is no more coming from anywhere..
Old 11-05-2012, 12:45 PM   #14080
Dallara
Dallara's Avatar
Oddometer: 2,057
Laugh Sum greater than the parts...
The thread about the bike is worth a read...
And the picture gallery of the build are worth a few minutes of perusal, too...
https://plus.google.com/photos/11351...641?banner=pwa
I visited with the builder for quite some time and he had some great stories to tell, as well as enlightening insight as to how he came to construct the project. One of the best stories he had was from the "Roll the Bones" rally...
Apparently one day he rode along with a group of seven or eight riders that he didn't know. A couple of Beemer G/S riders, a KTM or two, and some other KLR's. They rode together all day, and at one stop late in the day one of the other riders mentioned that he had heard that "that guy that built the KLR/Versys bike is at the rally somewhere..." (I'm paraphrasing), not realizing he had been riding next to the very bike and rider all day. Seems none of the other riders in the group realized it until the builder told them...
Said it was kind of high praise that no one had noticed it wasn't a Kawasaki factory built machine.
Another good story was about his letting a BMW G/S owner ride the bike. According to him when the Beemer rider returned he wanted to immediately swap his nearly new G/S for the "Frankenbike" KLR/Versys - even!
Dallara
Old 11-05-2012, 12:53 PM   #14081
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,241
My first FJR had a seal leak on the rear hub. Similar to what you explained. You could have had been a bit
of dirt or something cause a temporary leak. If cleaned up and no sign of a current leak I would just check
the rear hub oil level and keep an eye on it for a few days.
If you're really concerned you could pull the rear wheel and see if there is any sign of oil/grease in the
spline area. Hope it's just a minor one time event for you.
Old 11-05-2012, 12:55 PM   #14082
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,241
Gracias
Okay I did understand one word. I assume the rest is something about "How does that lucky bastard get
all the women?" Am I close?
Old 11-05-2012, 02:10 PM   #14083
jaumev
jaumev's Avatar
Oddometer: 1,511
No, you are not closer at all. You need to improve your poor Spanish
Old 11-05-2012, 02:23 PM   #14084
jaumev
jaumev's Avatar
Oddometer: 1,511
Gracias
Hola Nicolás, lo siento, no tengo ni idea de que puede ser lo de la transmisión.
Al poco de tener la moto notaba un poco de juego en la dirección y era la tuerca grande que queda debajo del manillar. Ahora no tengo la moto en casa pero creo que sí lleva un tapón de cucho.
Si no recuerdo mal antes de apretarla hay que aflojar los tornillos de las tijas de la suspensión, lo hizo mi mecánico y no lo recuerdo exactamente, si no lo ves claro se lo puedo preguntar.
Estoy seguro que Pluric puede aportar sus profundos conocimientos de mecánica, ¿no crees?. Aúnque si fuera sobre mujeres seguro que acertaría aún más, es un experto!
(Uff, que alivio poder escribir algo sin el corrector del word!! )
Are you agree with the solution Pluric?
Old 11-05-2012, 02:25 PM   #14085
RedRocker
Native Texican
RedRocker's Avatar
Oddometer: 5,679
That's an impressive build Dallara, dude has serious talent.
N. Texas
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation."
RedRocker is offline   Reply With Quote
Times are GMT -7.   It's 04:40 AM.
