Old 11-05-2012, 01:57 PM   #31381
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,999
Originally Posted by Nice_Rumble View Post
Anyone else's license plate light really loose? I tried tightening the bolts but there is an internal spacer that prohibits making it any tighter plus the nuts are capped. Is it loose by design? Shorter bolts or a standard nut makes no difference due to the spacer.
Yes.
I took an old handlebar grip, cut a rectangular piece the size of the LP light housing, punched holes in it where the bolts would pass through, and used it as a spacer between the light housing and the back of the fender. It solidified the housing quite a bit and I like to think the rubber adds dampening to keep the vibes from breaking the bulb filament.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 11-05-2012, 01:57 PM   #31382
10Cup
10Cup's Avatar
Oddometer: 2,667
Yeah that's how it's designed, you can add washers behind the cap nuts to help squeeze the rubber and tighten it some.
I also found my tail light lens loose and no way to tighten it. Ended up putting some thin (IE cut with scissors) foam between it and the plastic. Has worked well now for many many miles.
10Cup - WR250R - BMW R1200GS
Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker
The cost of living's going up, and the chance of livin's going down.
10Cup screwed with this post 11-05-2012 at 02:04 PM
10Cup is offline   Reply With Quote
Old 11-05-2012, 03:26 PM   #31383
jon_l
jon_l's Avatar
Oddometer: 3,374
I noticed the same thing, but didn't do anything about it ,since tightening does not resolve.
Do we think this is an issue that needs to be addressed, or an intentional design "feature"?
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 11-05-2012, 04:02 PM   #31384
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,771
Originally Posted by jon_l View Post
...Do we think this is an issue that needs to be addressed...
NO!
I still can't get over trying to retrofit a manual cam chain tensioner in this bike.
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 11-05-2012, 05:43 PM   #31385
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,299
The plate light holder is made that way. IIRC, its a filament bulb( as opposed to an LED), and if hard mounted, is more likely to break...especially on a tail that is potentially bouncing around all the time, harshly.
The filament bulb on my DRZ tailight(aftermarket) would break couple times a season.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 11-05-2012, 10:31 PM   #31386
skierd
Wannabe Far-Rider
Oddometer: 2,971
Snow has started to fall in and around Fairbanks, a nice sheet of ice has formed on the roads, and for the first time since I've started riding I've had to put my bike up for the winter. Or at least until I can get studded knobbies...
She's been sitting since late september, with the temps getting into the negative teens overnight the last couple weeks, thoroughly cold soaked. Went out to change the oil for winter and run some stabil through her, and she started right up like nothing. Dang I love this tough old girl...
If anyone is interested in a set of stock X wheels, let me know if you're interested. I'm pretty well decided on swapping back to dirt wheels come spring, as well as getting a second bike.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 11-05-2012, 11:47 PM   #31387
Joe Watson
Joe Watson's Avatar
Oddometer: 1,033
Ok, so I got my starter/kill switch from K&S which is great! Saved a bunch not buying through Yamaha.
BUT!!!!!! Now my bloody indicator switch wont push in to return. I have pulled it apart cleaned, lubed and everything, but I just can't get it to push and return. Any suggestions on how to fix it before I fork out for a new one of these?
Joe Watson is offline   Reply With Quote
Old 11-06-2012, 01:49 AM   #31388
Joe Watson
Joe Watson's Avatar
Oddometer: 1,033
Very sad to see it go, I have put countless hours into getting it to this stage and it has taken me to MANY incredible places!!
It does not have dual radiators, just a guard to keep roost off all the bits behind there and it is no different than cleaning the radiator guard on the other side! The bash plate does have two tool boxes, one either side.
Everything on the bike I built myself, all the info is in my build log here (page 8 has all the new stuff):
http://www.advrider.com/forums/showthread.php?t=678192
Originally Posted by HardWorkingDog View Post
Damn, good eye there Mr. Tom. I can see a guard on the right as well.
Originally Posted by EEKAMOUSE View Post
And what's the giant skidplate plz share!
Originally Posted by Mikef5000 View Post
Giant skid plate has a 'tool box' on each side.
The dual radiators is interesting!
Originally Posted by AZ TOM
Dual radiators, a great idea, dummy radiator guard??? Seems like another place for catching dirt & mud?
Old 11-06-2012, 08:36 PM   #31389
ba_
ba_'s Avatar
Oddometer: 2,793
Fork protectors
Does anyone know if the fork protectors have been changed over the years so that they do not rub the forks?
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 11-07-2012, 01:35 AM   #31390
jgino157
Yer' mom!!!
jgino157's Avatar
Oddometer: 455
Same problem here
'06 Wee-Strom
'08 WR250X with X and R setups
'08 KTM 300xc-w - Plated
Colorado 2012
UPAT 2011 2014
jgino157 is offline   Reply With Quote
Old 11-07-2012, 03:52 AM   #31391
Gargoyle
Trail Jester
Gargoyle's Avatar
Oddometer: 1,180
stock WR250R HP
Anyone know what is the HP of a stock WR250R is?
'11 Husaberg FE570S
'12 KTM 990
'13 Husaberg FE350
Berkshire Trail Riders on Facebook or follow me on Twitter
Gargoyle is offline   Reply With Quote
Old 11-07-2012, 05:25 AM   #31392
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,754
It's a monster...
"The stock WR250R makes 28 horsepower and 17 foot-pounds of torque."
http://www.cycleworld.com/2011/05/20...ecial-feature/
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 11-07-2012, 06:55 AM   #31393
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,250
Just throw on a set of black WR250"X" fork protectors....they don't rub like the white "R" model.....slightly different
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 11-07-2012, 07:25 AM   #31394
BMW-K
F800GS FTW!
BMW-K's Avatar
Oddometer: 1,480
Originally Posted by thumpididump View Post
It's a monster...
Sounds a bit optimistic to me.
2010 F800GS Anniversary - a return to Eden
2011 Yamaha WR250R, 2012 Ducati Monster
2007 R1200GS (Sold)
IBA # 20880. STFU and Ride.
BMW-K is offline   Reply With Quote
Old 11-07-2012, 07:28 AM   #31395
what broke now
Petroleum Brother
Oddometer: 1,444
Me too, thumb on the scale, probably in a friendly way, but still...
what broke now is offline   Reply With Quote
Times are GMT -7.   It's 04:10 AM.
