Old 11-06-2012, 11:56 AM   #2851
Renman1117
Oddometer: 42
What size are the metric bolts mounts on the 30,44, & 60 lights?
Thanks.
Cliff
2009 Moto Guzzi Stelvio
Renman1117 is offline   Reply With Quote
Old 11-06-2012, 12:40 PM   #2852
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Thanks.
Cliff
M4x30mm
Old 11-06-2012, 02:41 PM   #2853
Renman1117
Oddometer: 42
Originally Posted by sanjoh View Post
M4x30mm
So if I where sourcing fork mounts that had metric threaded holes I would tell them that the mounting bolts or stud from the lights I am getting are 4x30mm?. My understanding was that most of these lights used an 8mm or 10mm stud or bolt to attach to the fork mount. Thanks.
Old 11-06-2012, 03:49 PM   #2854
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
The M4x30 is for the pivot in the mount. To mount the light you will need 6mm diameter hardware.
Old 11-09-2012, 11:13 AM   #2855
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Old 11-10-2012, 06:54 PM   #2856
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Old 11-12-2012, 11:34 AM   #2857
Itapop
Itapop's Avatar
Oddometer: 6
Ktm 525
Got the model 60 mounted on my K 525/04. Only fitting for me the handguard mount, slightly modified- protected place and high enough for shorter shades. The light works good as far to now and I hope it'll last. On the electrical side it's a mounting on the edge, because I've not modified the stator, so it produces 55 W on the AC circuit and only 20 W (more or less, 1,4-1.7 A at 12-13V) for the DC battery charge. The measured light absorption is 2,2 A at 13,7 V (=30 W), then the battery has a loss of 0.5A /12W per hour. Not a big problem as far it is a lithium battery of 9 A, and I put on the light only for a couple of hours after sunset. I guess the light could work at least 7-8 hours before starting to drain the battery.
Light put on only on off road riding of course- in Italy police would seize the bike with such a blinding light even if dimmed (I know, the new Ducati or Bmw GS have oem led headlights, but they are filtered by thick lens to be street legal).
Two questions:
1- I've put a 3A fuse for the overvoltage: could the light be damaged by a low amperage / voltage in case of battery drained?
2- I saw the BD Squadron light. Good light but less suitable for me. Same 4 Cree T6 leds. Why do they declare a higher absorption of 42 watts? Maybe is there a more protective internal electronics?
The best from what happens.
Itapop screwed with this post 11-12-2012 at 01:29 PM
Itapop is offline   Reply With Quote
Old 11-13-2012, 02:24 AM   #2858
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,275
Bought a long time ago, but very pleased.
Looking for some spot lights. Will they come?
Regards
Mikael
Denmark
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 11-13-2012, 06:59 AM   #2859
Itapop
Itapop's Avatar
Oddometer: 6
Regards
Mikael
Denmark
Shocking 1X4 lights! But I know, winter sunset in Denmark is at 3,30 PM...
Have you boosted /converted the stator of your 530?
Itapop screwed with this post 11-13-2012 at 03:55 PM
Old 11-13-2012, 07:24 AM   #2860
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,275
Have not ridden with all four mounted. But the 530 should do 150w. I do not know how much loss there is, but i think that 4 LED is at the edge.
KTM 530 EXC-R 08
Old 11-13-2012, 09:32 AM   #2861
Itapop
Itapop's Avatar
Oddometer: 6
Your stator should be the same as mine. 150 w is a nominal power, the actual power is 55 on AC and 20-30 W on DC. Look at this. Off road racing bikes are made like this because the AC-DC circuit is lighter and the less power draining.
LED lights need DC, so you only have 20-30 W available in the battery circuit. Note that in an ordinary circuit the generator current and the battery current are linked in parallel (all DC), so the energy comes directly from the generator and the battery gives energy only at the start or during short overloads. You're probably in my same condition, taking part of the power light from the battery, that normally should be avoided, unless the discharge is balanced with a charging period (lights off).
It is possible to convert the generator from the present two internal windings (one for untrasformed AC and one for rectified DC) to a single unified circuit, with some soldering and a new recitifier-regulator. Or to change the hole stator with a boosted one.
Itapop screwed with this post 11-13-2012 at 03:54 PM
Old 11-13-2012, 10:16 AM   #2862
michigan400
Oddometer: 82
150W would also only be at maximum rpm's. Even with a DC conversion of the stock stator you should stay at or under 70W of lights.
Get a Trail Tech 100W stator. Puts out a solid 100W at just above idle. I've had no problem running 105W of lights from my TT stator.
michigan400 is offline   Reply With Quote
Old 11-13-2012, 02:30 PM   #2863
ewagman
Oddometer: 28
I was telling someone about my model 44 LED lamps and the ST dimmer, but I can't find the ST dimmer on the web site anymore. Has it been discontinued? I fried one improperly wiring it, bought another, and love it for the daytime attention is creates. People just DO NOT pull out in front of me since I installed it, I run it full bright, 2nd quickest flash. I will kindly turn it down or off if I am behind someone in traffic.
ewagman is offline   Reply With Quote
Old 11-13-2012, 03:15 PM   #2864
DinX
DinX's Avatar
Oddometer: 104
Model 60 on a Super Ténéré
Commute monster
Dimmed at 30% or something here. Thee regular lights are 2 x 35W HID
DinX is offline   Reply With Quote
Old 11-14-2012, 04:35 PM   #2865
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
We have discontinued the ST Dimmer.
Times are GMT -7.   It's 11:23 AM.
