10-30-2012, 01:27 PM
#1966 |
Oddometer: 136
Mine made a sketchy friend...
11-04-2012, 11:39 AM
#1967 |
Alpoholic
Oddometer: 719
After last weeks snow and temperatures below -5°C (during the day...) I thought the riding season over. But yesterday brought us another beautiful autumn day, so I went for a quick ride to Chamonix-Mont Blanc.
It was wonderful. A bit chilly on the higher passes, but I was still riding in my leathers without extra jacket and summer gloves. Not at al bad for November in the Alps! Hope there will be some more possibilities for rideouts tis year. ![]()
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them you are a mile away and you have their shoes. ![]() |
11-05-2012, 06:51 AM
#1969 |
Rides slow bike slow
Oddometer: 9,555
What is it about white third gens that is so perfect?
You couldn't hear a dump truck driving through a nitro glycerin plant!Cobbie Award Winner |
11-05-2012, 07:01 AM
#1970 |
Oddometer: 503
Really good catch.
That 's a awesome baby:
11-05-2012, 07:57 PM
#1971 |
luddite
Oddometer: 566
Well, perfect except for two things:
White Wheels are an abomination, but even that offense does not justify caging one on a trailer.
11-06-2012, 05:38 AM
#1972 |
Oddometer: 9,555
HEATHEN! BE GONE!
(they do suck balls to clean)
11-06-2012, 09:11 AM
#1973 |
Exhiled
Oddometer: 188
11-06-2012, 10:29 AM
#1974 |
high, wide and handsome
Oddometer: 11,749
Yes, but as an owner of an '86 I can testify that they are imfuckingpossible to keep clean.
11-06-2012, 10:35 AM
#1975 |
Oddometer: 11,749
I found a set of CBR1100XX LSL clamps (same fork tube diameter) on E-bay a long time ago (before I actually owned the VFR -- I mean, you never know, right?) for cheap and made them work with a bit of fiddling. I used ST1100 throttle cables (~2') longer, and rerouted the rest. The only one that was a bit troublesome was the choke cable, but with a bit of head scratching I made it work.
11-06-2012, 12:04 PM
#1976 | |
PussyWagon™ Chauffer
Oddometer: 3,576
Thanks for the info. I'll keep it in mind if my lower back ever forces me to transform my bike into an ST870.
Steve 07 KLX250S w/300 kit, 05 DR650SE, 04 XT225 99 VFR800 w/870 kit, 96 GPz1100 |
11-06-2012, 03:57 PM
#1977 |
Oddometer: 250
Head bearing or tire?
A friend of mine has a 2000 vfr. We are currently on a cross country trip and he has been complaining about a wobble at 45 mph. The tire has been balanced so its not that. We are thinking that its easier the head bearing is lose, or the bike just doesn't like the tire which is a shinko raven 009. The head feels tight when rocking it back and forth but could it be a little lose? Any help would be great as we have over 4000 miles left in our trip.
04 FZ1, 06 DRZ400 SM |
11-06-2012, 05:19 PM
#1978 | |
Too old to be a nOOb
Oddometer: 1,924
11-06-2012, 06:57 PM
#1979 |
Oddometer: 250
It spins fine and when the front is suspended it doesn't seem to have slop.
11-06-2012, 11:11 PM
#1980 | |
270 deg crank
Oddometer: 103
As I said before all bikes have a point of harmonic flutter, so why is this a problem for your friend now & not before? Things that will make the flutter point more obvious include tyres worn flat in the middle from too much slabbing, adding weight to the rear of the bike especially rigid hard panniers & double especially a loaded top box, rear suspension with too much sag, too low tyre pressures. So start with the obvious. tell him to ride with both hands on the bars... death grip not necessary. Cast a critical eye over how much crap he is carrying on the bike... or post a piccy so we can all waggle a finger at him. Set tyre pressures @ 36psi front 42 psi rear from cold Set preload so the bike sags 35 mm @ the rear with rider & all luggage installed. My guess a 12 year old VFR with stock shock & spring this will be impossible, but let us know how much sag their is now. Check condition of tyres. Never ridden on Shinkos but any tyre worn flat in the centre from slabbing will cause problems long before its at legal limits. Good luck & get back to us with how its going.
270 deg crank |
