10-28-2012, 10:43 AM
#6136 |
Oddometer: 314
I'm not saying the DR650 doesn't have its uses. The original discussion wasn't about a DR200 vs. a DR650. It was based on somebody saying that the 200 wasn't big enough for the off road terrain he was trying to ride and therefore he was thinking about getting a DR650. I was suggesting that there are other bikes out there that are better suited for difficult off road terrain than either DR and that he might want to shop around a bit.
07 450EXC |
10-29-2012, 08:09 AM
#6137 |
Oddometer: 226
new windshield
just installed the slipstream enterprise S-00. only mod that needed to be done was to flatten the supplied fork clamps. they come with a bend in them which would work for wider spacing btwn the forks. Slipstreamer does not list this for the DR.
Shield provides great coverage of the hands and good leg protection.
1981 CB900C, 1998 GL1500C Valkyrie 2007 DR200 "Our Constitution was made only for a Moral and Religious people. It is wholly inadequate to the goverment of any other." John Adams 10/11/1798 "If we ever forget that we're one nation under God, then we will be a nation gone under" Ronald Reagan |
10-29-2012, 09:25 AM
#6138 | |
Where we riding to?
Oddometer: 3,572
10-29-2012, 09:58 AM
#6139 | |
Oddometer: 155
AHH now I see yes there are other bike that would definitely fill the role between the 2 better,But the 650 isn't the ill handling overweight pig that some people try to say it is , my apologies.
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course ![]() http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
10-29-2012, 09:59 AM
#6140 |
Oddometer: 226
how does one post pics? is there a sticky?
see "I'm Trying's" post #5705, he used the S-03 which is the same except for the lower shield extentions. The extentions extend 2 1/2" past the fork reflectors http://www.advrider.com/forums/showt...29927&page=381
10-29-2012, 10:16 AM
#6141 | |
Where we riding to?
Oddometer: 3,572
10-29-2012, 03:53 PM
#6142 |
Oddometer: 314
Wife just isn't getting into riding on 2 wheels like I'd hoped. Only riding it gets is once/week when I take it out for a spin to keep everything lubricated. Listed her 2003 today for $2350 in case anybody in the SoCal area is looking for one in nice shape with only 1000 miles.
07 450EXC Wallrat screwed with this post 11-01-2012 at 10:05 PM |
11-05-2012, 06:59 PM
#6143 |
Backcountry Rider
Oddometer: 378
Im looking at the 2013 dr200 on the suzuki site. It looks exactly the same as previous models but the specs state the gas tank is 2.9gal inc reserve. How can this be as the tank is supposed to be 3.4gal i
nc reserve.
The way that you wander is the way that you choose. The day that you tarry is the day that you lose. Sunshine or thunder, a man will always wonder where the fair wind blows. Buell Ulysses Xb12X Custom Leather Work-Made In England www.lordofleather.com |
11-05-2012, 07:14 PM
#6144 |
plainsman
Oddometer: 89,823
That's got to be a mistake.
_______ |
11-06-2012, 06:35 PM
#6145 |
Oddometer: 142
Nah. It's not a mistake. That space in the tank is taken up by the electric fuel pump for the fuel injection.
If you think getting old is bad; consider the alternative. |
11-06-2012, 06:40 PM
#6146 | |
plainsman
Oddometer: 89,823
Fuel injection?
_______ |
11-06-2012, 08:22 PM
#6147 |
Oddometer: 9
FMF pipe and Kientech jet kit
I just completed the install of an FMF Q4 muffler and the Kientech jet kit on my 2004 DR200. I also made the airbox mod. I ordered the muffler along with the jet kit by telephone from Kientech. Kientech gave very good service and the parts were here within a few days.
A few observations: There was a small ding in the side of the FMF muffler. Since it is hidden under the side cover, I decided not to complain about it. I was surprised that there is no pipe clamp on the front portion of the FMF pipe. It is a fairly loose slip fit onto the head pipe and relies on high-temp RTV for a seal. Not quite as well engineered as the stock muffler clamp setup IMO. The right side panel gets reinstalled with a spacer and longer screw furnished by FMF. This simply pushes the side panel out further than the factory location. Not a highly engineered solution IMO. The FMF pipe is very loud. I like a nice exhaust tone, but I was surprised at the increase in sound level. It really has a "bark." Interestingly, the FMF directions state that the muffler is designed to be used with the factory carburetor jetting! The jet kit installed with few problems. Be careful as the float bowl screws and bonnet screws were VERY VERY tight. I stripped the head on one bonnet screw and had to hack-saw a slot in it to fit a flat blade screwdriver. Cold start is greatly improved. Much less warmup required. My seat-of-the-pants road testing shows that the low and mid-range power and responsiveness might be a tiny bit better, but at wide open throttle in 4th and 5th gear, the bike had a intermittent hesitation. Top speed was about 5 mph slower! I ended up putting the stock main jet back in: hesitation gone. There was no startling performance increase with this installation. Cold start and warmup is much better, with possibly a little bottom and mid range boost. The FMF pipe, like most aftermarket performance parts, almost hits the mark, but fit-up is not as good as factory. Bottom line for me is that it was a few hundred dollars wasted. Any performance gain is very small, and the FMF pipe isn't as well engineered as I had hoped, and a little too loud. My advice; get just the fuel screw mod from kientech which will cure your cold start/warm-up problems, and have them mod your muffler which will give you a little nicer tone. |
11-07-2012, 04:32 AM
#6148 |
Oddometer: 699
So you would just do the fuel screw, and leave the jets alone? What about the airbox? I would love a better cold start with less warmup required.
1997 BMW F650 Funduro, 2007 Suzuki DR200SE |
11-07-2012, 06:55 AM
#6149 | |
Oddometer: 314
To the OP, I'm not surprised that the pipe didn't make much of a difference. Except for extreme cases, a pipe is usually only good for a 10-15% HP increase on a 4-stroke engine, so you're really only likely to gain 1 or 2 HP at best.
07 450EXC |
11-07-2012, 07:37 AM
#6150 | |
Oddometer: 226
its free to open it up a few turns.
