11-06-2012, 11:44 AM
#151 | |||
Oddometer: 1,376
If I tried to ride around only using 1" of travel I'd be _very_ slow. Rossi hard on the brakes ![]() Jorge mid-corner ![]() Casey Stoner accelerating out of a corner (gives you a good idea of total travel available to the rider ![]() So could you explain why you where trying to use such a small amount of travel? Or what the actual drill is you where doing? Also to the guy who wasn't sure about the suspension extending under acceleration, look at the distance between the bottom of the tire back tire and the bottom of the bellypan between the mid-corner and the corner exit shot. The bike leaving the corner is doing a wheelie so it has 100% load transfer to the back wheel and the suspension is almost if not fully topped out. |
11-06-2012, 11:54 AM
#152 | |
Oddometer: 1,376
Trail braking and being near the limits of tire adhesion are 2 different things, and sliding the front doesn't mean you're crashing. |
11-06-2012, 12:13 PM
#153 |
Oddometer: 246
What brings the conclusion that trail braking on public roads is just for fun, because if you have left a reasonable amount of traction you don't need to brake at all.
Into the dark side of our nature to look we all need. The energy, the passion there is. Afraid of that people are. Pieces of us it holds busy denying we are. |
11-06-2012, 12:16 PM
#154 | |
Oddometer: 1,376
If you frequently ride around on public roads with the bike pushing and sliding it's a matter of time until you get caught out. |
11-06-2012, 12:48 PM
#155 | |
0 miles and counting
Oddometer: 156
11-06-2012, 01:02 PM
#156 | |
Oddometer: 13
I don't think of trail braking as "an invitation" or "green light" for faster entries in the corners. For me it is like a preemptive measure of giving some grip to the front, until I see the clear exit and roll on the throttle. |
11-06-2012, 02:43 PM
#157 | ||
Feral Chia tamer
Oddometer: 2,596
and
Mutt'n the custard. On the outside with my back turned. |
11-06-2012, 05:15 PM
#158 | |
Oddometer: 714
The trail braking is very subtle, I have never had an issue with a bad road surface, gravel etc despite hitting plenty of it but I have had the time to react correctly and not unsettle the bike. |
11-06-2012, 05:32 PM
#159 |
Frostback
Oddometer: 269
I'll say it again. It's a practice exercise. I never suggested you should only ever use only 1" of suspension travel. In fact, I explicitly said the sweet spot was mid-travel.
If you learn to use both TOGETHER properly, you eliminate any chance for 'pogoing'. Do it improperly and you'll be worse off. I'm done.
-Steve 04 FJR1300, 2013 CRF250L I have a job, I explore, I follow every little whiff. On/Offroad help when you need it - http://www.assistancelist.com |
11-06-2012, 06:05 PM
#160 | |
Oddometer: 156
Might be fun to practice this in the parking lot with tennis ball "cones" to help break the habit of grabbing at brakes, clutch or throttle.
TheWall screwed with this post 11-07-2012 at 09:50 AM Reason: break, brake...what's the difference? :) |
11-07-2012, 01:48 AM
#161 | |
Oddometer: 246
As I said, it's done just for fun. Like hanging off. Nothing wrong about that.
11-07-2012, 04:14 AM
#162 |
Frostback
Oddometer: 269
Funny, sure looks like the bike is under power (rear suspension extended), and unless you one finger break, I can't see any fingers in the front brake. That pic doesn't show a rider going down because of trail braking, that pic shows a rider going down because they overpowered the front with the 'troddle'.
11-07-2012, 04:18 AM
#163 | |
Just Beastly
Oddometer: 6,478
Barry
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday. Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot. |
11-07-2012, 04:44 AM
#164 |
Oddometer: 13
Ofcourse, It goes without saying.
![]() More than once I was surprised by an oncoming car stepping in my lane in a corner even though my speed was low enough for me to stop before sight distance. This is what I meant by "where you can't see the road far enough ahead". Harvey Krumpet explained better. |
11-07-2012, 06:41 AM
#165 |
Citizen of the world
Oddometer: 1,096
