Old 11-06-2012, 02:48 PM   #811
Brk4moose
Could save your life
Brk4moose's Avatar
Oddometer: 24
Originally Posted by p0diabl0 View Post
Same. Also he could just turn it around so it leans away from the car...
So I had today of and I re-arranged some stuff in the garage. Bike fits perfect now, should be good to go. I used a block of wood and now it lives on the other side. Was able to go out for a chilly but quick little toot. That bikes awesome, fingers are crossed for a warm winter....
Brk4moose is offline   Reply With Quote
Old 11-06-2012, 03:18 PM   #812
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 859
I finally had a chance to install and try the Dobeck Fuel Controller
I finally had a chance to install the Dobeck Fuel Controller today. Took the bike for about a 20 mile ride (wish I could have gotten more time but not today) - I can say without a doubt it is worth the money! wow, what a difference. With 13/42 gearing and just the FI controller it's like it different bike; even with the stock exhaust it really makes a difference.
2014 BMW R1200GS -- 2013 Honda CRF250L -- 2013 KTM 250 XCW
In loving Memory of Cruzn2b - 1953 - 2014
SugarDust is offline   Reply With Quote
Old 11-06-2012, 03:50 PM   #813
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,629
That's good to hear. Shouldn't be surprising for a good FI bike. I have two acquaintances with WR250R's, and their bikes experienced notable performance and driveability improvements with a controller.
TNC is offline   Reply With Quote
Old 11-06-2012, 05:04 PM   #814
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 859
given the improvement, I may put off the FMF exhaust and instead improve the suspension with the race tech components mentioned in the DB article...
Old 11-06-2012, 05:25 PM   #815
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,370
Speaking of which .... I wonder who the other two people were that called them about the article on the same day I did.
I learned the following:
-Their custom shock for the CRF250L is ~$750. It's an Internal Floating Piston model with adjustable rebound damping and adjustable preload (non-remote). The packaging space at the upper end of the shock prevents piggyback models or remote preload adjust.
- For the front they want you to send the forks in to be reworked. For ~$450-$500 (not willing to give a firm quote until they get the forks in hand), they'll install a gold valve and modify the front spring to stiffen the rate. They've found that there is a limit to how far they can go. He said the rates (both stock and max), but I was unable to write that down. He did say that the rate the BDSB dude wanted was higher than they could deliver. They haven't looked into having a custom spring wound for the bike but will if there is enough demand.
So ... if anyone here is at all interested, give them a call and give them the impetus to make those springs!
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 11-06-2012, 08:00 PM   #816
CRFSoCal
Oddometer: 43
Originally Posted by joec63 View Post
Use this tool to get the dimensions on the stock bars. Choose CRF250L from the drop down box. Then shop for bars that are close. I went with Pro Taper CR HIGH but others will work also. The stock bars are flimsy, bent very easy in a dismount
I preferred drilling the three holes for the switchgear versus filing down the nubs so keep the stockers for the hole measurements if you go that route.
http://www.zeta-racing.com/handlebar/players/sim.html
As far as handguards I was using Cycra pro bend on the stockers with a little adjustment.
Thank you for the advice I appreciate it a lot.
CRFSoCal is offline   Reply With Quote
Old 11-07-2012, 03:28 AM   #817
Crafty_D
Oddometer: 12
Originally Posted by goondock View Post
Nice I like the red bars, congrats on the bike it is a lot of fun. GO SPRINGBOKS!
Thanks man. Will post some pics once my hand guards are on. Still contemplating cutting a whole in the side of the throttle... grrrr.. Already had to nub the pins for the handlebars.
*sigh* choices choices.
Crafty_D is offline   Reply With Quote
Old 11-07-2012, 03:36 AM   #818
Crafty_D
Oddometer: 12
NEED $850 stat!
Hahah I need ideas how to make $850 thats allot of cash in South African RAND geeez. I want the bestdualsport stage 1 kit ... Unfair, all the cool stuff from other country's.
But we have awesome trails and animals. I will take some elephant pics next time. They dont seem too bothered by the bike :) But im NOT getting off, will take pic from the seat. Also saw some gazelle last weekend while riding.
Old 11-07-2012, 05:37 AM   #819
goondock
Oddometer: 68
I am also saving up for that kit, looks good and i talked to the owner and he seems pretty legit.
as for your hand guard question if you check out page 52 you will see I posted pictures of the ones I have installed they arent the cheapest when you include the mirrors but they are solid. Lots of guys seem to like the Cycra hand guards.
goondock is offline   Reply With Quote
Old 11-07-2012, 05:51 AM   #820
Wargasm
Wargasm's Avatar
Oddometer: 195
Forks
Didn't I read somewhere that the CRF250L forks have the same external dimesnsions as the CRF250X and CRF450X, making a swap easy. wondering if anyone has acces to all three bikes to so a comparo. There'd be a few used stock forks out there off MX bikes that converted to fancy schmancy gear, wouldn't there?
Wargasm is offline   Reply With Quote
Old 11-07-2012, 06:13 AM   #821
B DIRT
B DIRT's Avatar
Location: your moms house startn a small fire in her panties
Oddometer: 1,376
I have a set of 450R forks from I think an 03-04 but the axles are different sizes so you then run into the speedo drive, and front wheel not working although thats easy remedy.
2002 XR650R (plated), 2000 XR650R (trophy), 1990 Transalp, 1986 CR125R (flashback), 1977 CT90, 2009 Big Red MUV
B DIRT is offline   Reply With Quote
Old 11-07-2012, 08:45 AM   #822
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,629
B Dirt, could you measure the two forks you have there in your possession? Give us a measurement from the very top of both forks at the cap threads all the way down to the center of the axles. This would tell us how much the front end/head angle might be affected in regards to handling. In most cases of fork swaps being discussed here, the whole triple clamp assembly has to be used, as the OEM triple clamps are not usually compatible with the usually bigger, replacement fork. On the speedo and instrument panel issue, it is often easier and better to just go to a Trailtech Vapor style instrument panel for a price of just over $100. These panels usually have more and better data anyway and are often superior to the OEM stuff. This allows you to use the better front wheel assembly that comes with the bigger/better fork. An entire front fork swap isn't what most folks are willing to undertake, but they can almost always yield a way superior result.
On the rear shock, that Race Tech shock looks very good. However, I wish they'd apply a remote reservoir with a hose type setup that would allow one to mount that reservoir in a convenient place. While much improved, there's something to gained by having a reservoir system as far as tuning and even long term reliability are concerned. Some companies offer remote reservoir shocks. I used a top drawer Works Performance shock on two KLR600/650's some years ago that had a remote reservoir. I mounted the reservoir in a convenient place, and it worked wonders for the piggy KLR. A remote reservoir shock with the Honda is probably very doable.
Old 11-07-2012, 08:49 AM   #823
'Flagger
'Flagger's Avatar
Oddometer: 2,370
I was looking at this last night .... not a whole lot of room in there for the hose.
- B
Old 11-07-2012, 08:58 AM   #824
Wargasm
Wargasm's Avatar
Oddometer: 195
Speedo isn't driven from the front on the CRF250L. I've done a couple front end swaps on streetbikes, I've got a 1980 GSX1100ET with '89 GSXR1100 front end and '02 Bandit 1200 swing arm and wheel, it's really not that difficult. AllBallz Racing has a nifty program that allows you to type in your bike and it'll spit out all the front ends that can be swapped on, with the appropriate bearings needed to make up any differences in stem diameters, provided the stem lengths and fork leg lengths are compatible.
As far as axle diameters, the whole assembly would most likely have to be used, stem, clamps, fork legs, axle, wheel etc. which would be an improvement over stock anyway.
AN upgraded front end and at the least a stiffer rear spring would go along way to improving this already great bike.
Old 11-07-2012, 09:01 AM   #825
Spud Rider
Spud Rider's Avatar
Oddometer: 3,785
B Dirt, could you measure the two forks you have there in your possession? Give us a measurement from the very top of both forks at the cap threads all the way down to the center of the axles. This would tell us how much the front end/head angle might be affected in regards to handling...
Can you confirm the 450R forks have the same tube diameters at the triple clamps as the CRF250L forks?
Spud
Times are GMT -7.   It's 10:52 PM.
