Old 10-24-2012, 11:28 PM   #601
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,391
Was just thinking that a steering stabilizer of some sort might be a pretty nice addition to a trailer. Might help tame the wag...
jesusgatos is offline   Reply With Quote
Old 10-25-2012, 05:18 AM   #602
thatboatguy
That Boat Guy
thatboatguy's Avatar
Oddometer: 9
Originally Posted by DakarNick View Post
Good work, George. I'll have to PM you about your wing!
Any time Nick,
BTW Here is the back deck and cargo pod hack I did on the KLR. I'm going to narrow the box to something reasonable and put a hinge and latch on it. I re-purposed an old life raft pod for that one. Also makes a handy place to bolt down a... er hmm... .
There are some flying photos on our blog at The Further We Go. Still somewhat on topic as there's some early bike loading attempts. And slightly embarrassing that I was a mechanic on an expedition motorcycle without the means to deal with a flat tire... Never again!
George
thatboatguy is offline   Reply With Quote
Old 11-01-2012, 01:54 PM   #603
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 4,042
Well what's the latest? Anyone putting miles on their trailers?
I just did a 360 mile weekend of back roads, gravel roads, dirt roads and trails.
It did awesome on the trails. No complaints there.
Around town and back roads. Awesome.
Overall it passed and I'm happy with it but,
This was the first time on fresh gravel roads with a loaded trailer. It was quite a
handfull at times. MX tires with 25psi didn't help matters but I could really feel
that 110 lbs. back there swaying behind. Straight line was ok up to 50 mph but
cornering was sketchy. 30 mph and below was manageable. If I could get in the
tracks with no loose gravel I could cook along pretty good.
On the highway sometimes it would fishtail between 55 and 60. Not all the time
but once it started I couldn't stop it. Kinda like a VERY slow headshake. It was
not at all scary but annoying.
I'm going to replace the 35 year old bearings and bushings. Upgrade to taper
bearings in the head tube. Get some shocks with some damping and change the
angle of the shocks to make it softer as I think the bouncing is a lot of my
problem in the loose gravel. Maybe even a steering stabilizer.
When I would rock the trailer I noticed the right mount was rocking where it
seats against the small end of the axle allowing some flex. I made a bushing
that slips over the axle nut and seats against the axle washer. I added a plastic
washer for the trailer to pivot on. This added some stiffness but I think I still
need to triangulate the forward mounts with longer gussets.
A few from the weekend. We hauled a boat load of stuff in and on the trailer.
It was awesome.
oPAULo is offline   Reply With Quote
Old 11-01-2012, 02:04 PM   #604
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,874
I haven't done much on mine lately. The coil spring I bought (only $25) is way too heavy duty for my trailer so back to the drawing board on that.
I have some gas shocks that I may be able to use but not sure yet... They're strong but I don't know if they'll hold up to the constant cycling.
I bought some angle and more tubing so hopefully I'll make some progress in the next few days.
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox that XXMe is having dirty thoughts about.
DakarNick is offline   Reply With Quote
Old 11-08-2012, 02:19 PM   #605
Eddieb
Eddieb's Avatar
Oddometer: 988
I've made a bit more progress. Here are some pics.
Whats the length and width of the bed area?
'05 DR650 - '06 Wee Strom - '86 BMW R80 with Velorex sidecar - '67 Ducati 250 Mark 3 Narrow Case
www.AdventureRidingNZ.co.nz Free GPS tracks for New Zealand, over 60 Owners and workshop manual downloads, ADV bike specs chart & more
Eddieb is online now   Reply With Quote
Old 11-08-2012, 02:36 PM   #606
theWolfTamer
Lupie on a Mission
theWolfTamer's Avatar
Oddometer: 395
I read on singlewheel.com some one else built a swt and had to lengthen the tongue to stabilize their trailer at speed. Of course it's a street trailer but still here's what he said:
Getting my trailer to handle involved a fair bit of trial and error. I found that as a bare rolling chassis, it handled quite OK, but I think that was due to the fact that it was so light, the bike just dragged the chassis along regardless of where it wanted to go. When I installed the fibreglass "box" and loaded it with 35kg of ballast, the trailer would "tail wag" at about 100kmh (approx. 60mph). After upgrading to an L rated tyre and exchanging the standard (and very worn) Honda shock absorbers for new Ikon units, the problem was reduced, but not cured. I talked to a few trailer builders and began to wonder if the problem could be the drawbar length. Sure enough, after adding about 10" to the drawbar, the tail wagging problem disappeared. I have now towed it at over 180kmh (a little over 110mph) with a 40kg load and it tracks really well. While I'm not in the habit of travelling at 110mph, I felt that it was important to over-engineer and test at extreme speed if I was to have confidence that it wouldn't do anything unexpected at the most inappropriate time! The only time you really even notice that it's behind the bike now is when doing really slow turns, or quick changes of direction such as a winding mountain road. Even then, as long as you change direction smoothly, it leaves the other guys towing normal trailers for dead...
Training to slay theWolf
Check out theWolfTamer Chronicles, my blog about my motorcycle life
theWolfTamer is offline   Reply With Quote
Old 11-08-2012, 03:27 PM   #607
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 4,042
Hey thanks for the info and the link!
I was already considering a longer tongue because the box will just barely touch the license plate in the deep ditches. Now I have two reasons.
Old 11-08-2012, 05:48 PM   #608
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,519
Another thing that causes wag is slack in the hitch joints and flex in the hitch mount.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 11-08-2012, 07:07 PM   #609
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,874
The coil spring I bought was way overkill so I decided to buy a cheap mountain bike at a pawn shop and use the coil from that. I also added two gas shocks. Not sure if it will all work but it's worth a try.
My bed is removable in case I decide to change it. Two pieces of angle create a channel that slips over the "backbone" tube.
On
Off
Eddie, the upper bed is 45.25"x25".
Overall length from vertical (side to side) pivot to rear of tire is 97".
Axle of bike to axle of trailer is 101".
Old 11-15-2012, 08:18 PM   #610
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,051
Brilliant efforts guys!
K7 Strom with Chair
84 Kwaka GT750 Cafe Project
84 Kawaka GT750 Outfit Project
TouringDave is offline   Reply With Quote
Old 11-30-2012, 04:51 AM   #611
lonewolf97
lonewolf97's Avatar
Oddometer: 2,363
Here is my trailer project. It was a jet ski trailer I had converted to carry my 97 dr650. Now I'm going to pull it with the same dr. I'm already pulling it with my roadking. All I need is to build a hitch for the dr. I'm looking at the subframe under the rear fender. It looks strong enough for an aluminum plate to be bolted to it in the same mounting holes the plastic mud guard was. That would allow the hitch to be installed/removed in just a few minutes. My game plan is to pull the trailer, set up base camp then remove the hitch for trail riding.
Sent from my Galaxy Nexus using Tapatalk 2
I'd rather be lost in the woods, than found at home.
lonewolf97 is offline   Reply With Quote
Old 01-28-2013, 11:17 AM   #612
MrBracket
MrBracket's Avatar
Oddometer: 262
Who's makin good use of the cold weather to build new trailers???
Check out what I've done to the Moto-Mule trailers.....
See more here: http://www.advrider.com/forums/showp...&postcount=426
MrBracket is offline   Reply With Quote
Old 01-28-2013, 12:53 PM   #613
griffo1962
griffo1962's Avatar
Oddometer: 1,530
Does this mean it will be a much smaller package to ship ie cheaper?? and do you have plans for fitment to a KLX250?
thanks
g
griffo1962 is offline   Reply With Quote
Old 01-29-2013, 07:44 AM   #614
blacktruck
Oddometer: 170
Question Anybody else think this is a good idea?
I used to have a trailer for my Venture Royale. It was a pretty good sized trailer and the extra space meant it was usually too full. It pulled very well but that was a big bike with lots of power. I'm in the market for a KLR and think that a small trailer would be better than some of the overloaded bikes I've seen in their RR. I'm looking for ideas or input. Is this a feasible idea for a KLR? I would plan to travel light and one up but this would allow me to keep the weight off the bike and give me a few cubic feet of storage. Does anybody make a hitch or small trailers like that? I'm overseas so still in the planning stages at thhis point. Just looking for ideas here and hoping to pull the trigger on it when I'm done here.
Anywhere is home
blacktruck screwed with this post 01-29-2013 at 04:30 PM Reason: misspelling
blacktruck is offline   Reply With Quote
Old 01-29-2013, 07:48 PM   #615
jgas
Stoogely Adventurerer
jgas's Avatar
Oddometer: 843
I've been thinking about doing this for years but my fabrication skills are in the infancy stage. I've taught myself to weld steel fairly well and sometimes I can even use a tape measure without mistakes. Gotta have the right amount of beer. Fabrication and waterskiing requires beer for me. 2 beers, I get better. 3 beers makes me reliable. Fewer mistakes than sober that is. 4 beers and I start quickly going downhill. The trick is after 3 beers, to drink at the exact rate that keeps me working better, not worse. It's an art in itself.
If I did this, the trailer would have to be built for me to lay down on, stable, narrow, and tough. It would need to be close to the bike so I could turn around without unhooking on roads and wide trails. My goal would be to pull it behind my DRZ in all but the hardest singletrack. I would need to be able to pull it into some really tough spots without crashes or breaking it. My dream trailer would be long enough for me to use it for a camper after I unloaded it. Maybe have a small lightweight rack that I could drape a tarp over and lay inside of for camping, then take it apart or fold it all up for riding. It would need to have a lightweight detachable frame that could be put together to lay on for sleeping and stay off the ground. The frame could theoretically be mounted lengthwise or crosswise to the trailer. My ideas far outstrip my ability! I would like to have a brake on the trailer, and I think that one wheel would be better than two, maybe with outrigger tires like training wheels that only touched the ground when going slow or turning around.
If someone could build this and market it cheaply it would make a fortune! Or sell easy to use plans for the do it yourselfer. Some of the ones I've seen here look great but I'd want to somehow try various ones before copying one to make sure it worked for my uses. I'm probably the only idiot that would even try to ride singletrack with a trailer, but it sure would be cool! I have seen bicycle trailers that hardcore off road guys pull with Mtn bikes. One guy has ridden all over Colorado pulling a trailer with a bicycle.
Has anyone tried pulling the trailers from the top of the bike, attached to the subframe or rear rack area? This would put the trailer at an upward angle so that it wouldn't drag, give it cornering clearance, and bring the trailer tire/tires closer to the bike. It would also keep the trailer from being affected by the swingarm moving up and down. On most bikes the subframe/rack area would have to be modified to hold up to the stress, but that would be pretty easy compared to designing the trailer I'd think?
Anyone thought of making the trailer tire, (the singletired ones), so that the tire/wheel actually leans with the bike? It would keep the trailer tire's contact patch constant and the trailer should follow the bike better.
jgas. " Most of the singletrack is gone. Forever"?
-Graduate of the "Rock on the side of the Trail as a Hammer" school of motorcycle repair.
"No matter where you go, there I was".
-DRZ 400, GasGas 275, Klein, zero cc.
jgas screwed with this post 01-29-2013 at 08:13 PM
jgas is offline   Reply With Quote
Times are GMT -7.   It's 11:40 AM.
