Old 11-08-2012, 08:49 AM   #4366
DaveRMS
(formerly GSNorCal)
DaveRMS's Avatar
Oddometer: 833
Starts in one kick? So, no need to stress then. Your big ride isn't in jeopardy. That's your free therapy.
Your bike has auto-decompress, so unless that internal mechanism on the camshaft is broken, I wouldn't think it's related to compression. You can manually actuate the decomp lever without the cable, for testing purposes.
My bike only occasionally exhibits the symptoms you describe. It's always been after sitting too long in the garage and the battery being a little low. Not sure how you checked "battery shows full charge". Does this problem go away after you've been riding the bike for a while, then stop for a break or gas? A voltmeter doesn't check state-of-charge without a load applied.
You also said it is progressively getting worse (more frequent). That usually means wear or a failure, rather than a change you made to the bike (which would be an instant change). So, I don't think it's because you removed the cable.
Hope this helps.
Dave
Originally Posted by RAZR View Post
i'm sticking with the floated rewound stator Javier at Trail Tricks did. me and my buddy are cleaning up at least 30 wires that don't need to be in the headlight bucket.
basically, Trail Tech X2 HID headlight, heated grips, Sicass switch, GPS, Trail Tech Endurance, fan (with a switch)... makes for a lot of wires. but we cleaned it up. i also have a Lithium battery. not the Shorai, but identical. works amazing.
i have a new problem...
my starter whines and doesn't engage in the motor. sometimes it does. but it's engaging less and less. battery shows full charge. kick starting it starts on one kick.
a few months ago i cut the compression release cable because it was crimping/cutting into my wiring harness. i figured i don't use it, so i don't need it. (i'm dumb, i know)
after Googling the whining starter not engaging blah blah blah, some stories of compression is coming up.
before tearing into the motor to see if the starter clutch is gone, or if the teeth are bad, i want to get some feedback.
i am not a great home mechanic, my buddy is. but he owns a 2010 530 and doesn't know RFS motors. but he's willing to help.
what should i do first?
i have a huge ride coming up in 2 weeks, so i'm stressing.
Rally Management Services is the source for Dakar-proven rally parts, bike builds, assistance, and training.
Rally Navigator - Roadbook Navigation powered by Google Earth. Create. Print. Share.
DaveRMS is offline   Reply With Quote
Old 11-08-2012, 08:55 AM   #4367
yondering
yondering's Avatar
Oddometer: 1,072
If the starter system is working right, and the motor has an issue with the auto-decomp system, the starter just won't crank the motor fast enough, and may even stop on the compression stroke. So that's not your problem.
If the starter whines but doesn't turn the motor, something's slipping. Broken teeth on the starter gears, or bad one-way clutch. It only takes about 10 minutes to get that clutch cover off and find out.
yondering is offline   Reply With Quote
Old 11-08-2012, 10:51 AM   #4368
Swarthy_Red_Beard
Oddometer: 145
What year bike? I have an 05 so had to deal with the intermediate gear issues from that year. Similar symptoms. Sounded like marbles rattling in a tin can when I hit the starter button. then the next time it would be fine. Got progressively worse until I fixed it. FWIW
Swarthy_Red_Beard is offline   Reply With Quote
Old 11-08-2012, 10:59 AM   #4369
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 7,497
battery shows 13 - 14.2
2004 525
it was clanking a while ago if i held the starter on for awhile. then the last ride, i just get the whine, then it would engage, then whine again.
this happens when bike is cold or warm/hot, intermittent.
yes, i could forget about this problem and just kick start the bike. but i'm going to fix the problem. riding singletrack and being in situations where kicking the bike is not an option. and i love the E-start.
oh yeah, the last few oil changes i've had more metal slivers on the drain plug.
after talking with a buddy that owns an 05 450 EXC, he thinks it could be the starter itself or the gears it engages with.
sorry to sound like an idiot. i've always had Javier, my former mechanic work on my bike. now i'm doing all my own work with the help from friends that are more mechanically inclined.
later today, we're going to take the clutch cover off and look for broken gears and check the starter. a starter on eBay isn't gonna break the bank.
thanks for all your input.
"when there is no more room in hell, the dead will walk the earth"
YOUTUBE LINK
www.RAZR.whereamiriding.com
RAZR is offline   Reply With Quote
Old 11-08-2012, 11:06 AM   #4370
Swarthy_Red_Beard
Oddometer: 145
Here's the link for the intermediate gear fix from ktmtalk.com. Might be worth a read in case you do find broken gears. The 06 parts are an upgrade but do require an new clutch cover or milling of your existing cover. There are options if you do find yourself in that boat.
http://ktmtalk.com/index.php?act=ST&f=7&t=139918
Good luck.
Old 11-08-2012, 11:32 AM   #4371
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 7,497
dunno if this matters, but a little over 1 year ago, my 6th gear exploded (maybe that sounds too dramatic) and i had it fixed at Trail Tricks. Javier replaced 6th and installed crank bearings that guys use on super moto set up. the crank was fine.
should i be concerned with that previous rebuild with my current issues? (like i said, i'm no mechanic)
YOUTUBE LINK
Old 11-08-2012, 01:35 PM   #4372
theGrinch
SNF Dream Riders
theGrinch's Avatar
Oddometer: 957
Razr starter problems
Show us some pics with the cluch cover off, I think you will see whats wrong then.
Sounds like starter gear going bad.
theGrinch is offline   Reply With Quote
Old 11-08-2012, 03:28 PM   #4373
Moto Vaquero
Trail less traveled
Moto Vaquero's Avatar
Oddometer: 91
I just read something just like this at ktmtalk. Apparently it's the freewheel. $71 at Munns. #13
I'm not day dreaming, I'm prerunning
Moto Vaquero is offline   Reply With Quote
Old 11-08-2012, 03:30 PM   #4374
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 4,456
Send a message via AIM to skibum69 Send a message via Skype™ to skibum69
all of mine blew up when my cam roller went on my 640
Riff Raff 2012, 2011, 2010, 2009
Skibum Soiree 2012
Skibum Soiree 2011skibum soiree '10
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 11-08-2012, 03:45 PM   #4375
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 7,497
i'm heading over to my friends in a couple of hours and we'll pull it apart to check what's up. i've reading all day and calling my fellow RFS friends and called 3bros to see if they have these parts in stock in case i need to drive there tomorrow to get parts.
more to follow...
YOUTUBE LINK
Old 11-08-2012, 08:52 PM   #4376
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 7,497
so far everything actually looks great.
i need to borrow a puller tool for the freewheel. so tomorrow this saga continues.
checked the starter and it's fine.
so Moto Vaquero is most likely correct.
thanks for all the help guys. don't laugh, but this is the first time i've pulled a clutch. i might have worn clutch plates too.
YOUTUBE LINK
Old 11-16-2012, 01:58 PM   #4377
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 7,497
N00b mechanic saga
whoa. it's been quiet in here.....
so the freewheel was toast. replaced that. all the gears in the starter assembly (intermediate gear, torque limiter gear, etc) were fine. looked like new.
intake valves were tight. really tight. gotta check those more often. exhaust were fine.
cleaned the carb.
new Trail Tech stator and rectifier/regulator.
rewired EVERYTHING. Trail Tech X2 headlight. heated grips. GPS. manual fan. looks great. no more rat's nest.
the bike runs better than it's ever ran. woohoo!!!
YOUTUBE LINK
Old 11-16-2012, 02:06 PM   #4378
Maniac28
Maniac28's Avatar
Oddometer: 388
Send a message via AIM to Maniac28
I've had my 07 525 for a year now. Awesome machine. Best dual sport I've ever ridden, period. One of the most amazing machines I've ever owned... and I've had over 20 bikes.
It's been relatively trouble free. At 250 hours the intake valves are receding... I need to get stainless valves, and I will be good for many more hours of pleasure.
Ian S.
'10 990 adventure R -- 07 525EXC
Moderator @ www.klr650.net
www.pbase.com/ischoenleber
http://2greaterthan4.wordpress.com
Maniac28 is offline   Reply With Quote
Old 11-23-2012, 07:20 AM   #4379
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,188
bump it up!
i know it's subjective, but what kind of mileage are you guys getting doing, say camping dualsport carrying luggage and stuff?
trying to decide between the 6.6 acerbis and 4.1 safari.
i think i read somewhere that the safari actually carries more than 4.1 gallons?
none of us are as dumb as all of us
clapped_r6 is offline   Reply With Quote
Old 11-23-2012, 10:40 AM   #4380
crazybrit
crazybrit's Avatar
Oddometer: 8,039
Originally Posted by clapped_r6 View Post
bump it up!
This Sept (Eastern OR desert - 900 miles) I was getting between 51 and 55 mpg. This was full Coyote but no camping gear. I'd never actually tracked my mpg on the TAT, for some reason I assumed it was lower but these figures probably explain why I never needed to fill the tank, 200 miles was all the range I actually needed.
At $120 it was a no-brainer to get the Acerbis but if I was paying full list price I'd probably get the Safari .... what range do *you* need?
crazybrit is offline   Reply With Quote
Times are GMT -7.   It's 10:24 PM.
