11-11-2012, 03:03 PM
#16 |
Cant ride for crap
Oddometer: 3,408
Ducati do make steel swingarms, on the Monster and the Paso, which is longer than the Monster swingarms. There is also the Cagiva Elefant. Mate built this one below! 50mm Magnum forks, 100mm extended Monster swingarm, Custom Ohlins rear shock. http://www.advrider.com/forums/showthread.php?t=428685
Lots of great advice above!!!! However I would say, build what you want, and half the fun is overcoming the challenges. That is what this section of the Forum is about. Once you start to build a bike you will realise there will be plenty ![]() DrJoe's build thread has taken many changes and ebbs, he has learnt a lot on the way through. So have those who have read it. Started Feb 4th 2009 and still going. http://www.advrider.com/forums/showthread.php?t=429917 If it works or not and time is of no constraint have a play You will learn so much in the process. Im sure John Britten would have received some criticism on his builds too Saliah is correct that it is much easier matching the engine and frame, dont know why you want the Ulysses Frame, if you like the styling, why not graft the tank and other body parts onto a suitable frame to start with. ![]()
Pezz :) Airhead Tragic ![]() I'm not a complete idiot -- Some parts are missing |
11-11-2012, 04:15 PM
#17 |
Lampin' it
Oddometer: 4,231
That ducati is sweet. I keep wanting to do a ducati, maybe next time.
The pace I keep going I'll have one of every manufacturer
We're not out here to rough it. We're here to smooth it . Things are rough enough in town. Nessmuk |
11-11-2012, 04:50 PM
#18 | |
Cant ride for crap
Oddometer: 3,408
11-11-2012, 06:53 PM
#19 |
Air cooled runnin' mon
Oddometer: 6,141
Perhaps you should start with a Vstrom and start stripping it down to lose some weight? It has a nice Vee twin engine to start with, large fuel tank and lot's of options. An inmate has modded a lot of totalled ones.
I used to be indecisive. Now I'm not so sure. "You only have too much fuel if you're on fire" unknown |
11-12-2012, 10:46 AM
#20 | |
Oddometer: 62
Apparently the 848 Streetfighter is very reliable. The SV 650 would be much easier to maintain though. I assume you mean lower power by saying better power? |
11-12-2012, 03:34 PM
#21 |
Oddometer: 136
11-12-2012, 08:12 PM
#22 |
What could go wrong?
Oddometer: 4,985
If you have the money and time I'd advise you to build it, otherwise how will you ever know. I love this kind of stuff!
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd |
11-14-2012, 04:47 PM
#23 |
Oddometer: 62
11-14-2012, 04:51 PM
#24 |
Oddometer: 62
Has anybody done this with a hypermotard? Its 1/2 the way there already.
edit: I didn't know Ducati started making a liquid cooled hypermotard. 821cc, 110 hp, 5.9" rear travel, 6.7" front travel. It would be a way better candidate than the 848. 2trally screwed with this post 11-14-2012 at 04:57 PM |
11-14-2012, 05:12 PM
#25 | |
Lampin' it
Oddometer: 4,231
And yes, it's WAY too much in the dirt, street though...
11-14-2012, 06:45 PM
#26 |
Oddometer: 136
And a lot has to do with how and where the power is delivered as well, the suzuki Sv twins are fairly linear with lots of midrange, vs the peaky power band of an inline and even some of the other twins such as most ducati twins and even suzuki's own TLR twin was fairly peaky in comparison, it's all a compromise, generally for more dirt and gravel I would go for something with more midrange as opposed to bottom or top end power.
11-15-2012, 10:47 PM
#27 |
Oddometer: 62
Yup midrange is good. I suppose its kind of ironic, but the engine currently in my Buell makes good power for dirt. Good traction on hardpack even with pirelli scorpion syncs.
Take the engine swap out of this build and it becomes a lot easier. I wanted to use a different engine just because modifying the bike with the stock engine presents problems of its own, and I've never been a fan of the Harley twin. It's just too damn car-like. 6500 rpm redline and low maintenance bore me for some stupid reason. Anyway, back to the problems of using the stock engine. Most of them stem from the swingarm. I want to run chain drive so I would have to add adjusters. As previously mentioned, cast aluminum is not easy to weld. There is always the bond and rivet approach but I doubt I could pull that off. And even if I could I don't know if I could trust it. Needless to say, I don't have lotus' engineering abilities. So using the stock swingarm is out and that requires me to find a place for the oil tank on top of trying to find/make a swingarm that will work. I like the exhaust placement on the stock bike, but if I put long travel suspension on and want to keep the seat height down I need to gain a lot of clearance. There is about 5 inches from the bottom of the exhaust to the bottom of the oil filter so I could gain upwards of 4.5" of clearance if I reroute the exhaust. That means modifying the headers and creating a whole new exhaust system aft of the headers. I might be able to steal some pipes off of an XR1200, but it would still take a decent amount of fabrication. Since it's not just a simple suspension swap I figured I might as well get the most for my work and swap in an engine I would love. But I think that I underestimated the work to swap a new engine in. I'm not saying the idea is trashed but I have to think about it some more. Sorry if I sound like one of those people that's always talking about doing things and never actually does anything. I always intended this thread to be a sounding board. I wanted to attempt to predict the biggest problems I'd likely have and I think that goal has been met. I read the SAR rules and I think this was the right place to put this, if it wasn't, sorry, I'm still a noob. 2trally screwed with this post 11-15-2012 at 11:12 PM |
11-16-2012, 03:46 AM
#28 |
Oddometer: 10,906
Seems possible, but imo not worth doing. I think it'd be more work than building a custom frame around the 848. One problem with using street bikes off road is most folks still end up with horrendous ergonomics. Last thing you want in the dirt is a big street tank (or filter cover) stretching a long way between the seat and the bars.
A big tank on a ktm superenduro would be hard to beat, even after a lot of work. If you really want lighter than the KTM maybe find an old Highland 950. I'm not sure the Uly frame will ever be very good off road. Definitely needs major geometry changes, even then the egronomics will be screwy. Also, the short wheelbase isn't your friend off road neither is the width. I like my uly a lot, but it's really surprisingly bad off road (my bandit 1250 was better). A KTM690 is mighty good off road and not too bad on-road if you want really light. If you need more power, building a forced-induction, 100+hp 690 would have to be easier than making a uly chassis work off road. You could also try swapping in a compact twin like a pimped out Ninja 650 motor into an XR650R or big KTM single chassis.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038 Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703 |
11-16-2012, 09:02 AM
#29 |
Oddometer: 62
I went over the geometry changes I would have to make. But ya I never have been sure about ergonomics. With the amount of work that had to be done I know I could make them better, but there isn't much I could do about the seat. Tilting the frame back and making my own subrame would move it forward a little, but not enough to make it perfect.
A turboed KTM 690 would be crazy. I wonder how difficult it would be to make it reliable. At the least it would need lower compression and an improved cooling system. I think an oil cooler would be necessary if I didn't want to change the oil every 500 miles. If I wasn't worried about making 20+ hp I could probably leave the head alone. Hopefully the stock bottom end could take an extra 10, 15 hp without grenading. If I could get low enough compression with a thicker head gasket I might not even have to change the piston. Damnit quit giving me ideas, I have too many already. |
11-16-2012, 09:18 AM
#30 |
Oddometer: 62
Whew, I can get the turbo idea outa my head. I want to be able to do water crossing, and water on a hot turbo = useless turbo with some warped turbines. I'm not 100% sure about that but for turbo cars and trucks they recommend letting the car idle for a minute before you shut the engine off to keep the turbines from cooling too quickly. Even in a setup were the turbo doesn't get very hot (relative to something like an rx7) dunking the thing in water would cool it more quickly than a rapid shutoff from high rpm and would definitely cause damage. And besides all that, the 690 makes good enough power already. If I got one I would be more concerned about making the electrical system reliable and getting some extra range.
