Old 11-11-2012, 05:44 PM   #76
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,981
Or maybe , a Ducati air-cooled twin in a full cradle frame is the ticket ?
Old 11-11-2012, 05:50 PM   #77
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
Originally Posted by bk brkr baker View Post
Full size.
1999 Suzuki TL 1000 Street Tracker. Very nicely built, runs great! This is a race bike, has no speedo/odo.
That looks like too much fun. Oddly, a speedo is not required in Colorado to make a bike street legal.
Approx mileage is 1500. No Title.
... but a title IS required.
Doesn't look to be much of a jumper though. Lots of vunerable near the bottom.
Yea, I probably need something that can take more battle damage.
Pablo83 is offline   Reply With Quote
Old 11-11-2012, 05:53 PM   #78
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
Beautiful, but I originally bought the GR for $400. I think this build would be out of my budget.
Pablo83 screwed with this post 11-11-2012 at 06:49 PM
Old 11-11-2012, 06:02 PM   #79
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,727
Try this place out.
http://www.oldbikebarn.com/
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 01-26-2013, 11:30 AM   #80
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
Originally Posted by Pablo83
Houston, we have a problem...
So I went to PMI in Pueblo yesterday and found a great track to ride the GR on. Then I decided to push it down some more technical stuff. I came across an unexpected ditch where I could either hit the brakes hard, and probably have an ungraceful crash, or gas it and jump the ditch. I made the logical choice and when I landed the jump I bent both foot pegs, tore off one of the peg rubbers, and punched a hole in the oil pan. What are the chances that eBay has an oil pan?
I finally got around to building a skid plate.
I welded some nut to the back of a few tabs which then got welded to the frame as skid plate mounts
I wanted it for the ice races this Sunday so I didn't have time to order 5052. I had to build it out of 6061 diamond plate because that was available locally
Done:
It took me about 5 hours to make. It protects the bottom and left side of the engine because that is where I have had issues when dropping the bike.
I'll try and post some pics of it installed some time.
Old 01-28-2013, 01:17 PM   #81
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,358
Nice job! Purdy welds, too!
HapHazard is offline   Reply With Quote
Old 02-13-2013, 08:02 PM   #82
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
The Elephant Ride
I took the GR on the Elephant Ride this year. It was a blast.
Old 03-04-2013, 07:23 AM   #83
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
Originally Posted by fnqgr650 View Post
Hi Pablo
Bumped into you on other post Xmas. I have a gr650 and speedo is now shot, tacho is going to get cable coming thru post and I am relying on gps which i have to remove all the time to avoid someone else doing the same. I don't really want to move away from original speedo/dash but given two other options I might need to. I am looking at the $50 new, seperate speedos or second hand other model/make. Any advice is well recieved?
That's a tough one. If you want OEM gauges then check eBay and you probably want to check eBay sites in some European countries as well since this is going to be hard to find.
If you are going to buy an aftermarket speedo they come in different ratios. The GR is 2240:60 (2240 RPM= 60 MPH). I bought a cheap J&P branded speedo from J&P and it never worked well and completely broke in 6 months and they wouldn't replace it, so I don't recommend them. Lots of Harley's are 2240:60 so there are lots of speedos out there that will work.
The last option I can think of is a Trailtech Vapor unit. It permanently mounts to the bike. You will need to glue a magnet to the front tire and clamp a pickup to the forks to run the unit. These are popular for plated dirt bikes.
Old 03-10-2013, 03:10 AM   #84
mark1150
mark1150's Avatar
Oddometer: 196
Wow,
Well worth reading and the end result is super cool.
A huge pat on the back for such an inspired build.
mark1150 is offline   Reply With Quote
Old 09-06-2013, 05:01 PM   #85
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
Old 12-14-2014, 10:06 AM   #86
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
one of the innovative aspects of the GR650 is the dual mass flywheel: at lower RPMs a secondary flywheel engages so the bike will idle and accelerate smoother. When pulling away at WOT, it almost feels like the bike downshifts at a certain RPM and I've been suspicious that this is caused they the disengaging flywheel. Something I've wanted to do for a while now is remove the second flywheel and see how it handles. I finally got around to it recently.
It's a pretty simple system that was very easy to remove. Pulling away from a stop now requires a little more clutch slipping, but no more than any modern dirt bike. Power delivery is much smoother throughout the RPM range. I no longer have to keep the bike at peak RPM to keep the engine from feeling sluggish. I thought I would have to raise the idle to keep the bike idling smoothly, but that did not turn out to be the case. Needless to say, the second flywheel will not be going back on.
Old 12-14-2014, 04:43 PM   #87
BiGR Rich
BiGR Rich's Avatar
Oddometer: 260
Good to know, Pablo!
Haven't heard from ya in a while - how are the spoke wheels coming along?
BiGR Rich is offline   Reply With Quote
Old 12-15-2014, 08:44 AM   #88
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
The GR now has new shoes:
Old:
New:
The biggest change with the tires is going from a 16" to a 19" rear. The GR has always felt wobbly in high speed corners. A couple people have suggested it had a flexible chassis. turns out it has a lot more to do with that balloon of a back tire. With the 19" rear, handling is much better.
Old 12-15-2014, 04:54 PM   #89
BiGR Rich
BiGR Rich's Avatar
Oddometer: 260
Thumb
Looks good, sir!
Old 12-15-2014, 07:32 PM   #90
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,828
Originally Posted by BiGR Rich View Post
Looks good, sir!
Thanks for the rims, Rich. I really like spoked wheels. If you know someone who prefers cast wheels on a their GR, I have an extra set.
Times are GMT -7.   It's 11:18 PM.
