Old 10-23-2012, 09:44 AM   #211
naginalf
Handy Schtroumpf
naginalf's Avatar
Oddometer: 233
Originally Posted by kellymac530 View Post
BTW ther are a few fender options that might help with venting for the oil cooler but may still help keep at least some mud off of it
Ya know, this brings up a point I've been thinking about. The original oil cooler location has it's obvious disadvantages, especially if you plan to ditch the bars. But the relocation to behind the fender does seem just as dumb for the opposite reasons. One gets airflow but is in a dangerous place, the other gets no airflow but is protected. What's the point in relocating the oil cooler if it doesn't do anything, a finned oil pan would be much better and much less complicated. Hell, quite a few riders don't even use an oil cooler, and I for one was thinking of going this route, not least of which for weight savings. But why does no one ever put the oil cooler vertically on the frame tube? That way it's to the side of the fender, gets plenty of airflow without having the motor behind it, and won't get crushed on a fall over.
'91 R100GSPD
Adventures with a Type1 TARDIS.
naginalf is online now   Reply With Quote
Old 10-23-2012, 09:55 AM   #212
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,097
Originally Posted by naginalf View Post
the other gets no airflow but is protected. What's the point in relocating the oil cooler if it doesn't do anything.
There's plenty of airflow there for an oil cooler to do it's job. Even with a fender one inch in front of it, there's still plenty of airflow. The one real drawback to the location under the steering head is that it can get coated with mud easily, even with a fender in place.
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Airhead Wrangler is online now   Reply With Quote
Old 10-23-2012, 10:41 AM   #213
Beater
Scope Creep's Victim
Beater's Avatar
Oddometer: 2,205
This is exactly what I've been thinking about for the dobber. I think there will have to be a 'custom made' mounting bracket, but I really think it could work.
I'm still keeping the crash bars .... but I just like to cruise with my feet on them for longer rides.
Fred
'85 R80RT G/Sified
'91 R100GS Bumblebee
Airhead Zen: Ride-Maintain-Repair-Ride On.
Beater is online now   Reply With Quote
Old 10-23-2012, 10:58 AM   #214
naginalf
Handy Schtroumpf
naginalf's Avatar
Oddometer: 233
That's a funny coincidence, I was actually looking at Dobber for a visual reference when I posted, and was imagining it with a sideways cooler mounted. I must be psychic .
Does anyone manufacture a finned oil pan?
'91 R100GSPD
Old 10-28-2012, 02:31 PM   #215
x3300 OP
geoff
Oddometer: 170
Speedo Sensor
The Trail Tech computer uses a reed switch and magnet for its speed sensor. I used some high-temp epoxy to mount the magnet in the hole of one of the brake disk buttons.
http://stuff.gotdns.org/bike/orgs-build-up/56-speedo-sensor/magnet.jpg
With the magnet fixed I tried different locations for the reed switch and decided that mounting at the top of the caliper adapter gave the best cable routing while giving a good signal. I drilled and tapped a hole in the adapter for it.
http://stuff.gotdns.org/bike/orgs-build-up/56-speedo-sensor/sensor.jpg
Here's how I routed the sensor cable up along the brake line with a few nylon ties.
http://stuff.gotdns.org/bike/orgs-build-up/56-speedo-sensor/cable.jpg
At first I used the brake line guide I had made up before, but it was a tight fit for both the brake line and sensor cable.
http://stuff.gotdns.org/bike/orgs-build-up/56-speedo-sensor/old-guide.jpg
I didn't want the brake line to get hung up and kinked, so I made a new guide from a block of hard plastic I had. I put a 22 mm hole in it and made the base a little wider to better match the 58 mm fork upper.
http://stuff.gotdns.org/bike/orgs-build-up/56-speedo-sensor/compare.jpg
Here's the drawing I made up for the new guide.
http://stuff.gotdns.org/bike/orgs-build-up/56-speedo-sensor/guide-drawing.jpg
The new guide with the cable routed through it.
http://stuff.gotdns.org/bike/orgs-build-up/56-speedo-sensor/new-guide.jpg
-x3300
x3300 screwed with this post 10-28-2012 at 02:57 PM Reason: Add guide drawing.
x3300 is offline   Reply With Quote
Old 11-10-2012, 08:52 AM   #216
x3300 OP
geoff
Oddometer: 170
Mendo Forest
I took the bike up to the Upper Lake District of Mendocino National Forest for a long weekend of riding.
http://stuff.gotdns.org/bike/orgs-build-up/57-mendo-forest/mendo.jpg
I was expecting to just ride the easier trails, but was surprised that the bike was nimble enough to ride through every trail there except for a few that had ruts too deep for the cylinders to pass. The bike is noticeably more work to maneuver through the tight parts than my KTM 530, but the tractor like power makes it so its not too bad. Its really good on the faster trails, and just keeps chugging on in the uphills as long as I can keep it balanced.
I did some night riding to test out the lights. The high beam of the 8" Trail Tech Race Light really lit up the trails. I'll try to get a photo of the output next time.
I had a lot of fun. Here are a few videos that show the bike in action.
-x3300
Old 11-10-2012, 12:41 PM   #217
gsd4me
unconditional love
gsd4me's Avatar
Oddometer: 5,582
You didn`t need to switch the headlight on for me (in the first clip), I could see perfectly.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 11-11-2012, 03:00 AM   #218
Rucksta
Chronic Noob
Rucksta's Avatar
Oddometer: 2,292
Just takes your breath away -
If the Earth is flat why are my tyres round?
Rucksta is offline   Reply With Quote
Old 11-11-2012, 12:29 PM   #219
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 19,867
You, sir.
I want to ride with You.
Nice videos mate
What to do... What to do...
Stagehand is offline   Reply With Quote
Old 11-12-2012, 04:44 AM   #220
Beater
Beater's Avatar
Oddometer: 2,205
Originally Posted by Stagehand View Post
You, sir. I want to ride with You. Nice videos mate
+1. Nicely done. Great riding.
Fred
'85 R80RT G/Sified
Old 11-12-2012, 08:06 AM   #221
naginalf
Handy Schtroumpf
naginalf's Avatar
Oddometer: 233
You, sir.
Nice videos mate
+2 Thanks for posting, that made my day!
'91 R100GSPD
Times are GMT -7.   It's 09:28 AM.
