Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 11-12-2012, 05:52 PM   #91
Xcountry-Rider OP
Oddometer: 912
A user review of the Tusks on another thread. http://www.advrider.com/forums/showthread.php?t=647580
Xcountry-Rider is offline   Reply With Quote
Old 11-12-2012, 06:02 PM   #92
advtenn
advtenn's Avatar
Oddometer: 1,364
Nice thread, I'm still trying to decide on which guards to install.
I did read that in order to use the HDB guards, that they require the use of the ROX risers.
bikes guns and shine
"My body thinks my brains gone crazy" ..........Corky McMillian
advtenn is offline   Reply With Quote
Old 11-12-2012, 06:15 PM   #93
Marsh Tiger
Marsh Tiger's Avatar
Oddometer: 550
Are the stock bar ends threaded? How hard are they to remove. I have The Acerbis installed and they worked OK with the stock bar ends. I want to redo them this winter, just wanted a little heads up if they are a bitch to remove.
Marsh Tiger is offline   Reply With Quote
Old 11-12-2012, 06:21 PM   #94
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,480
Stopped by dealership today and added the Adventure tank bag to my order....
Looked at a set of Givi Trekker luggage a friend had on a 955 tiger.
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is offline   Reply With Quote
Old 11-12-2012, 06:59 PM   #95
Xcountry-Rider OP
Oddometer: 912
A nice thing abut the Tusk D-Flex Handguards/Spoilers is that the spoilers are replaceable for 30 bucks if they get all scratched up.
Old 11-12-2012, 08:16 PM   #96
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,182
I have the twisted throttle barkbusters on my 955i Tiger and they were on my XB12 Ulysses. I went down quite a bit in the dirt on the Uly and the Barkbusters held up well and earned their money.
"I refuse to tiptoe through life only to arrive safely at death"
'13 Tiger 800XC, '14 Street Triple, '00 KLR 650(current project), and a 2010 Honda NT700V for the wife.
Drunk_Uncle is offline   Reply With Quote
Old 11-13-2012, 02:24 AM   #97
bluesman
Oddometer: 3,326
As promised - photo with Triumph OEM bars + Touratech tank/rad bars in black
bluesman is offline   Reply With Quote
Old 11-13-2012, 06:49 AM   #98
backwoodsKLR
Oddometer: 9,480
Cool. That looks like it should protect everything. Are the upper bars in the way if maintenance access?
sent from my Galaxy S3 using Tapatalk 2
2013 Tiger 800XC
Old 11-13-2012, 06:50 AM   #99
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,695
Originally Posted by Dr. Doofenshmirtz View Post
That's my Tiger pictured there; I'm really liking the Tusk handguards. They're rock solid, and with the large spoilers installed, they actually do a great job of keeping wind/weather off my hands.
By the way, the big bar adapter isn't really required. The Tusk handguards can be installed without it with a little fiddling.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 29-31, 2015
markbvt is offline   Reply With Quote
Old 11-13-2012, 07:08 AM   #100
precarious
precarious's Avatar
Oddometer: 559
I tanked it hard on the Acerbis Rallye guards, and they saved my controls. Rugged stuff. But those HDB guards look pretty cool. When I do it again, I'll be getting those.
precarious is offline   Reply With Quote
Old 11-13-2012, 07:18 AM   #101
fbj913
I ride
fbj913's Avatar
Oddometer: 2,355
I made the pictures!
Just FYI the Acerbis set up that I have is not just the straight acerbis rally pro guards. I also have the added wind protection spoiler that attaches to the top. And there are several versions of Acerbis.
http://www.motosport.com/dirtbike/se...segment=badger
there is also many other kinds of hand guards. this is only a tip of the ice berg.
fbj913 is offline   Reply With Quote
Old 11-13-2012, 08:00 AM   #102
bluesman
Oddometer: 3,326
Surprisingly they are not...I was worried about same, but since first time (with slightly bad bars) I installed them myself I found that panels indeed can be removed without removing bars at all, everything else just open, no interference.
However, to install them you have to remove front side panels - otherwise it is pain in the a...e to access front upper mounts system.
If you ever try to install those - take note, that you will need loooong extender with 14 mm head to access front engine mounts nuts from "opposite" side across bike. In this case you do not need to remove tank etc., just side panels and rad side panels.
Old 11-13-2012, 08:27 AM   #103
Xcountry-Rider OP
Oddometer: 912
--mark
Mark you had to do some grinding correct? Anything else you can tell us about the install?
Old 11-13-2012, 08:56 AM   #104
markbvt
Oddometer: 2,695
I actually did use the big bar adapter on the throttle side, but obviously the orange Tiger you have pictured in the first post did not. If I had done more fiddling I could have worked out the same thing.
I did do a little grinding with a Dremel inside the regular bar clamp for the clutch side handguard, just to facilitate being able to mount it a little further down the handlebar. I didn't have to take off much metal though.
--mark
Old 11-13-2012, 09:21 AM   #105
jphish
Oddometer: 617
Doc D - Thanks for the tutorial. VERY helpful. Do any of those after market handguards appear to accomodate a Kaoko throttle control. seems Touratech would (with less protection?) but not sure about the others. Trade offs I suppose - but use my Kaoko quite a bit on the long rides. Thanks, j
jphish is offline   Reply With Quote
Times are GMT -7.   It's 07:35 PM.
