Old 09-30-2012, 10:06 PM   #31
HappyRiding
Grumpy
HappyRiding's Avatar
Oddometer: 3,327
Wade, you should be nicer to the next front end. Good luck with the rebuild.
"Hey I've never seen the sun come up in the west!?!" - Fozzie Bear
HappyRiding is offline   Reply With Quote
Old 11-13-2012, 11:41 AM   #32
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,364
Ya took too long and Bimota came out with whatcher building!
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is online now   Reply With Quote
Old 11-13-2012, 11:44 AM   #33
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,645
Oh help me Rhonda that is stupidly delicious
Want so bad it hurts, I don't even want to know how much it costs.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Old 11-13-2012, 11:48 AM   #34
Gummee!
Gummee!'s Avatar
Oddometer: 28,364
I haven't seen too much about it, but I did see 1100cc
M
Old 11-13-2012, 12:44 PM   #35
Wadester OP
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,036
M
Ain't you got anything better to do than taunt me with yet another unaffordable Bimota - and this one is (sadly) pure vaporware.
Bimota DBX-1100
En Espanol: http://www.masmoto.net/novedades/201...mota-dbx-1100/
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is online now   Reply With Quote
Old 11-13-2012, 02:13 PM   #36
jerdog53
Crop Dusting Everywhere
jerdog53's Avatar
Oddometer: 5,423
13 Hyperstrada 09 696 Monster
"Shorter of breath and one day closer to death"
jerdog53 is offline   Reply With Quote
Old 11-13-2012, 11:01 PM   #37
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,581
I was waiting for a thread like this.
I got a 2005 Ducati ST3 that had been in a garage fire for really cheap.
This year, I decided to do a build like yours for the DirtBag Challenge. I got all the suspension work done, but couldn't make it run due to EFI CPU issues... it's one of the red key/black key models. I'll replace it with a MicroSquirt.
Anyway, looking forward to your build.
Suck, Squeeze, Bang, Blow
Roadracer_Al is offline   Reply With Quote
Old 11-14-2012, 07:10 AM   #38
Wadester OP
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,036
I'd like to see what you've got done so far - parts choices, etc. For the EFI issues - have you heard of DucatiDiag? An inexpensive enthusiast written full-access bit of software:
http://www.ducati.ms/forums/92-hyper...-hm-owner.html
http://ducatidiag.xooit.com/index.php
Don't know if it would help you out - if you've got the red/black keys, this will let you read/erase error codes and completely reprogram your EFI. Also supposed to let you recalibrate your speedo, remove O2 sensors and turn off immobilizer/remove stock instruments.
Old 11-14-2012, 08:00 PM   #39
Roadracer_Al
Oddometer: 1,581
Thanks for the link - I'm pretty interested in trying out the MicroSquirt, but I may try the diagnostic before pulling the trigger on the MS. Both the red and black keys have had some heat damage, which may have ruined the RFID chip.
I got a CRF 450 roller cheap. Swapping the steering head was dead easy: turned up some cups for the bearings, and a 3/8" thick spacer between the top triple and the steering head. Bolted up like a champ. A better and easier, but more costly solution would have been to buy tapered roller bearings in the correct size.
The rear was quite a bit more work.... and I have a penchant for understatement.
I started with the ST3 swingarm and removed all the stock shock mounting hardware, leaving only the main cross brace. I then sectioned it aft of the cross brace and added 2.5" to accomodate a DR650 wheel with an 18" rim laced to it. I chose the DR rim because it has factory cush drive.
I then sectioned the SA in front of the cross brace and added 1.25" there in order to accomodate the shock and linkage from the CRF.
I did all this cutting and welding basically as a one-time-use for the DBC -- I have plans to create a new SA from scratch using 3" x 1" tubing. There is a ***big*** problem with adding travel to the ST3 SA: the SA pivot pinch bolt interferes with the sprocket. The pinch bolt will have to be changed.
The lower shock linkage mount required a bit of tinkering, too. I plan to make a removable cradle which will have an outboard bearing for the swingarm, footpeg/shifter/brake mounts, and possibly split dirt-bike style radiator mounts. The doohickey with the zig-zag is a removable frame section. I've made 2 so far, and need 4.
Here's a photo gallery of the progress to date:
http://alanzina.zenfolio.com/p965200943
Old 11-14-2012, 08:14 PM   #40
Wadester OP
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,036
Might as well show a few:
Alan Lapp and Zina Deretsky: DirtCati &emdash;
To post these, get the embed code from your site - then click the A/A thing in the upper right of the reply window - then paste in the embed code. Voila.
Old 11-15-2012, 11:07 PM   #41
Roadracer_Al
Oddometer: 1,581
Thanks for that. I didn't want to hijack the OP's thread.
Old 01-06-2013, 07:27 PM   #42
Wadester OP
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,036
I finally got my butt in the shop and peeled back some wiring harness to get the old frame free - also had to pull the injector set:
Can you tell which frame is which?
Now, I need to put the "new" frame and wiring harness back on - and start mounting the front forks.
Old 01-07-2013, 08:06 PM   #43
Ted.audia
Oddometer: 6
fantastic progress and glad you are back working in the shop! Keep us posted on how things are going
I need to take inspiration from you on my own monster conversion/money pit
cheers
Licentia Vel Nex
00 Aprilia RS50; 05 BMW r1200gs; 03 Ducati M800adv; 02 Ducati 998
Ted.audia is offline   Reply With Quote
Old 03-01-2013, 01:22 PM   #44
jbcaddy
Oddometer: 1,211
How much trouble is it in NM to change the frame? titled as a different bike? or changed numbers on registration?
What are ya doin' with the old frame? I have yet another project looming and could use some bits off it
jbcaddy is offline   Reply With Quote
Old 03-01-2013, 07:39 PM   #45
Wadester OP
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,036
I was patient/lucky enough to get a frame with title, so it's just another bike to the DMV.
What devious plans ya got for a bent Duc frame? Or maybe it's "what bits?"
Times are GMT -7.   It's 08:54 PM.
