Old 11-13-2012, 11:39 AM   #61
dave186
Oddometer: 183
Is the 50cent mod the resistor on the icp sensor? I tried that back in the day.
dave186 is offline   Reply With Quote
Old 11-13-2012, 01:20 PM   #62
dirtrulz
Oddometer: 473
24 Valve cummins with a 12 valve front cover and mechanical pump and you would have a good motor to put into whatever you want. Easiest swap ever. one wire to the fuel shutoff and a throttle cable. You can get adapters for just about any bell housing to mount to a cummins. Easy to make major power and will still hold together. The new 6.7 worries me a bit. Very little metal between the cylinders.
The only thing I hated about the fords were the leaf spring front end and its terrible turning radius. Always had to park in the back 40 at parking lots because you couldnt get into a spot. Actually watch a guy who got stuck in his spot and had to wait for the guy inn front of him to come out and leave. Stock the engine was a dog but a chip really wakes them up.
dirtrulz is offline   Reply With Quote
Old 11-13-2012, 04:17 PM   #63
_cy_
Oddometer: 6,375
upgrading 24v to mechanical pump fixes that motor only weakness. lots of racers have done it. sold my backup 12v mechanical pump when I realized odds are will not be needing it.
person that purchased it for $1200 was happy.. high output pump from a wrecked 97 5sp w/90k miles, going into his 24v.
Old 11-13-2012, 07:08 PM   #64
preppypyro
preppypyro's Avatar
Oddometer: 578
Originally Posted by DaFoole View Post
Under the valve covers there is a wiring harness that can come loose and cause CEL codes, and rough running, sometimes without even throwing codes. All it takes is two quarters ground down a little bit shoved in the clip to prevent the harness from coming apart and causing problems. Its a somewhat common issue, and a fairly easy cheap fix.
I never have done the napa air filter mod yet. I go through air filters like a mofo (live and drive lots on gravel) and didnt like the idea of it not being washable. I see riffraff diesel sells washable filters now so Ill have to order one up when I need to order parts. (dont know how familiar you guys are with diesels, but if you ever need parts, give Clay at riffraff diesel a shout, he is awesome to deal with and his prices + shipping are generally half price of what I can find up in Canada!)
I know ELC isnt absolutely necessary, but the trouble free operation and not having the hassle of having to test your coolant was worth it to me. Its more of an upgrade or modification, then an absolute necessity!
preppypyro screwed with this post 11-13-2012 at 07:17 PM
preppypyro is offline   Reply With Quote
Old 11-16-2012, 05:53 PM   #65
DaFoole OP
Lewddite at large...
DaFoole's Avatar
Oddometer: 4,262
Is there a link for this somewhere? My google-foo is weak....
I am prepared to do this in the next year or so. Don't you still need to add the anti-cavitation juice?
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over
"Don't come in here with your thoughtfulness, empathy, and reason... this is shit, up with which, I shall not put." -Boondoggle
DaFoole is offline   Reply With Quote
Old 11-19-2012, 12:32 PM   #66
preppypyro
preppypyro's Avatar
Oddometer: 578
I followed a thread on ford-trucks.com that had pictures in it, cant find it right now at work though. Ill post a ink to a thread that has a video though, I know a ton of guys watch the video and seem to like it.
http://www.ford-trucks.com/forums/11...-cent-mod.html
And as for the coolant, once ya switch to elc, its pretty low maintenance. Just keep it topped up with the right mixture and your good to go.
No need to add any anti cavitation juice!
Old 06-21-2013, 07:49 PM   #67
DaFoole OP
DaFoole's Avatar
Oddometer: 4,262
Question.....
Truck has been running GREAT!!!
Problem.... When run for 3-4 hrs the clutch, after stopping, surges, bucks when letting it out...really bad!!!!!
Pressure plate?? Read some online forums regarding this. Currently in the shop..... "We cannot replicate the problem"....
Duh!!!! I told them it was after several hrs driving. Ideas, suggestions?????
Help!
Old 06-26-2013, 12:53 PM   #68
dave186
Oddometer: 183
Does it still have the dual mass flywheel? Kinda hard to diagnose but sounds like an organic clutch that's reaching the end of its life.
Old 06-26-2013, 01:12 PM   #69
_cy_
Oddometer: 6,375
Question.....
Help!
how many miles on her now? it simply may be time for a new clutch. transmission/clutch are always weak part of drivetrain.
lots of aftermarket high performance options. went with a full Sachs ceramic clutch on my 96 12 Cummins pulling about 450hp. found it at Oriellys for about $300 for entire setup, brand new.
high performance clutch mfg want $600+ for similar setups. full ceramic are bullet proof but grabby. little to no slip... go with one side kevlar/ceramic for towing.
Old 06-27-2013, 12:49 PM   #70
Carlo Muro
Supercązzola
Carlo Muro's Avatar
Oddometer: 2,188
Originally Posted by Valker View Post
Simply the best diesel engine ever put in a pickup. They are in high demand here even with 300K + miles on them. Several of my friends have assured me (FWIW) that get over 20 mpg regularly, even with a trailer.
depends on the gearing on the speed you drive. Mine (well my dad's), is an F-350 with 4.10 gears. It won't touch 20 if driven at any speed on the interstate above one which will get you killed by Peterbilts. More like 15 mpg with the stock tune on and 15.9 with the economy tune turned on. Empty. It's a dually but only 2wd. We use a DP-Tuner with the +80 HP economy tune for tooling around unloaded. It makes all the difference in performance and a little difference in economy.
A single rear wheel 250 non- 4x4 MIGHT best 20 at highway speeds on a perfect day.
When it comes to diesel trucks you hear a lot of fairy tales. I haven't found most of them to do anything incredibly spectacular with regards to mileage when running lightly loaded.
My uncles F-450 (4.88 gears) will only return 8 mpg. Yeah that's right...eight. That's with a heavy 5th and 100+ hp tractor and hay making machines and shit aboard. Don't think he ever hardly runs it empty.
Carlo Muro is offline   Reply With Quote
Old 06-27-2013, 12:57 PM   #71
Carlo Muro
Supercązzola
Carlo Muro's Avatar
Oddometer: 2,188
Originally Posted by _cy_ View Post
as good 7.3 engines are... Cummins 12v are better.
Cummins to Ford conversions are the reason there's a baseline price for any Cummins 12v motor of about $2,000. so the junkiest 12v truck has a baseline value of the Cummins motor.
main disadvantage of 12v Cummins trucks ... the trucks
but yeah...it's fairly well accepted that the Cummins is better. Not that the 7.3 is any slouch. I haven't yet run across a kit to swap a 7.3 into a Dodge
Old 06-27-2013, 07:33 PM   #72
shiryas
Dragon with matches
Oddometer: 118
DaFoole,
My bet is the DMF (Dual Mass Flywheel) is starting to go and you really do not want to ignore this if that is the problem.
https://www.google.com/search?um=1&c...w=1591&bih=873
The Ford ZF transmission and Bell housing are cast as one unit and when the flywheel finally lets go you will be lucky if the bellhousing/transmission do not crack. I bought my 97 as a mechanics special with this very problem because the former owner did not want to replace the transmission and could not afford to have a shop do it.
Our 99 7.3 brush truck was replaced just last year when it started shifting funny. Ford has a solid flywheel for the 99-03 or you can get a reputable aftermarket such as South Bend, Valair, etc . . .
shiryas is offline   Reply With Quote
Old 06-27-2013, 11:57 PM   #73
_cy_
Oddometer: 6,375
good point ... have never heard of anyone transplanting a 7.3 into a dodge
not that there's anything wrong with that. a local builder specializes in transplanting 6BT and 4BT Cummins into low mileage 1/2 ton Pickup trucks of all different flavors. then selling for $$$ ..
do late model Ford truck folks in need of a new motor transplant a 7.3 instead Cummins 6BT?
Old 06-28-2013, 05:57 AM   #74
Cataract2
Where to?
Cataract2's Avatar
Oddometer: 1,830
But to be honest. Why would anyone want to have a Dodge body? The swap for the Cummins into the Ford is to get the best of both worlds.
People who get made because they're old, haven't lived.
Cataract2 is offline   Reply With Quote
Old 06-28-2013, 06:19 PM   #75
Carlo Muro
Supercązzola
Carlo Muro's Avatar
Oddometer: 2,188
That's a good question. I would imagine that in many locations they don't do either due to emissions regs.
I believe that the 6.4 and 6.7 Fords are ok and don't often need replaced. A 6.0 is another story. Some of the 6.0 are old enough that a same model 24V should be able to take its place without hassel from the man.
Times are GMT -7.   It's 09:36 AM.
