Go Back   ADVrider > Riding > Regional forums > Central From Da Nort Woods to the Plane States
Old 11-13-2012, 01:55 PM   #54376
Solace
Solace's Avatar
Oddometer: 923
46k was my high water mark for annual motorcycle miles. Ahhh, the good old days ...
Later,
M
Solace is offline   Reply With Quote
Old 11-13-2012, 03:31 PM   #54377
indypup
indypup's Avatar
Oddometer: 3,764
Later,
M
Wow, and I thought my 40K annual was a lot. ;) 12K miles in 18 days to Alaska and back is the most for one trip...
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 11-13-2012, 03:48 PM   #54378
Retread10
Oddometer: 10
I made a trip this summer to Alaska from June 1 to July21, covering just below 11k mi. I'm retired and obviously not in a hurry. Had a hellava trip. Made it up to Prudhoe Bay, down to the Kenai and a lot of the common points between here and there. One of the trip highlights: a timberwolf trotting down the road behind me while I was photographing Bear Glacier on my way down from Hyder. If I can figure out how to post photos here, I'll do a ride report this winter.
Retread10 is offline   Reply With Quote
Old 11-13-2012, 04:19 PM   #54379
indypup
indypup's Avatar
Oddometer: 3,764
Hey Retread10! You live in Troy too?
Old 11-13-2012, 04:58 PM   #54380
Gonzo_Matt
Random Hero
Gonzo_Matt's Avatar
Oddometer: 2,492
I might not get to ride a ton of miles, but I managed a hundred and some change today....was a bit brisk, but fun, and the 650 decided to not have working lights anymore...
Gonzo_Matt is offline   Reply With Quote
Old 11-13-2012, 05:23 PM   #54381
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,283
Mine did that once, it was a lose wire under the seat going to the battery.
http://www.youtube.com/user/advfilmer
2013 Super-10
2007 KTM950SEr
2006 KLR650
2001 YZ426 (street Legal)
buildit is offline   Reply With Quote
Old 11-13-2012, 05:29 PM   #54382
Gonzo_Matt
Random Hero
Gonzo_Matt's Avatar
Oddometer: 2,492
that's what I figured, that or a fuse. Brake light and turn signals still work, just no head or tail. I need to do some other stuff to it anyhow so no biggie...
Old 11-13-2012, 05:37 PM   #54383
Whitey1
"Whitebread"
Whitey1's Avatar
Oddometer: 10,191
Thats a first. Hmm check the harness for the license plate light. I just unplugged it and tucked it up under the fender when i cut off the fender extension. It never once gave me a problem though. Hmmm.
Whitey1 is offline   Reply With Quote
Old 11-13-2012, 05:41 PM   #54384
Gonzo_Matt
Random Hero
Gonzo_Matt's Avatar
Oddometer: 2,492
it just went off today after I had ridden some rough ass gravel. I never asked, did you do the Doo on that bike?
Old 11-13-2012, 05:48 PM   #54385
buildit
buildit's Avatar
Oddometer: 14,283
Well, at least you get to fix yours at home not on the side of a trail in Tellico, TN.
2013 Super-10
2007 KTM950SEr
2006 KLR650
Old 11-13-2012, 06:01 PM   #54386
S2P
S2P's Avatar
Oddometer: 720
Does anyone know how to test a stator,cdi box and coil off a bike? A guy I work with sons RM100 quit running ,no spark so they pulled it all out, but don't know how to test it or where to take it. They said someone told them they don't make all of the parts anymore and they don't know which part is bad. I told them maybe Action Cycles in Alliance could check it.
"In wine there is Wisdom, in beer there is Freedom, in water there is Bacteria"...Benjamin Franklin
WR 426
TTR 125
S2P is offline   Reply With Quote
Old 11-13-2012, 06:36 PM   #54387
ScienceOfDirt
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,731
The CDI is tough to check. Usually you just try a know good CDI. The coil is easy with a multimeter. Check the resistance across the two terminals, and again from the terminal to the spark plug wire. They should be less than 1 ohm. Zero ohms is bad as well. Any large, or infinite resistance reading means bad coil. Same thing for the stator. Any large values are bad, as well as 0. You can probably google to get the exact spec to compare to. As long as the resistance values are small, I'd suspect the CDI then. They did try a new plug didn't they?
EDIT: My google fu is week. I couldn't find the specs.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt screwed with this post 11-13-2012 at 06:41 PM
ScienceOfDirt is offline   Reply With Quote
Old 11-13-2012, 07:20 PM   #54388
Whitey1
"Whitebread"
Whitey1's Avatar
Oddometer: 10,191
I was anti-doo. I did pull the side cover the last time I adjusted the doo and from what I could see everything was in tact and looked fine.
Old 11-14-2012, 04:15 AM   #54389
ruppster
ruppster's Avatar
Oddometer: 917
I'm glad I did the one on my 93, I fished the missing chunk out of the crankcase with a magnet.
I have the tools still if someone needs to borrow them.
I also rewired part of the bike and installed ato weatherproof fuseholders for the circuits on my KLR. I put a couple under the kickstand switch cover and one near the radiator fan. I hate electrical gremlins. The fuseholders came from eBay, they look like this:
15 KTM 690E, 05 KTM 450EXC
ruppster is offline   Reply With Quote
Old 11-14-2012, 04:26 AM   #54390
Gonzo_Matt
Random Hero
Gonzo_Matt's Avatar
Oddometer: 2,492
I may take you up on the offer of borrowing those this winter. I love those fuse holders, I have a couple hundred of them i got in a lot at an auction and I use them for everything, they are great for snowplow wiring.
Times are GMT -7.   It's 10:35 AM.
