Old 11-14-2012, 07:26 AM   #1
D.T. OP
Difficult but useful
D.T.'s Avatar
Oddometer: 11,635
Question Carbon
Any tips on how to remove carbon from the tops of pistons with out F'n up the aluminum? Tried a wire wheel in the drill and it's not working too well.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 11-14-2012, 07:31 AM   #2
lanceputnam
Hayden's Dad
lanceputnam's Avatar
Oddometer: 439
Soaking in carb cleaner?
So others may live...
2012 BMW R1200 GS-Rallye
COBDR, AZBDR
lanceputnam is offline   Reply With Quote
Old 11-14-2012, 08:22 AM   #3
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,331
A putty knife often works well, just hit both corners with a file or grinder to round them a little. Other items on hand that can work are flat bladed screwdrivers and don't laugh but a cheap SS butterknife also works.
If the pistons are out, then as mentioned soaking in solvent is really good as most of the carbon will just fall off after an overnight soak but if it is still in the motor and the head is off careful scraping is usually the way to go.
GreaseMonkey is offline   Reply With Quote
Old 11-14-2012, 08:47 AM   #4
MCCOYBOY
Oddometer: 99
Try finding someone with an ultrasonic cleaner. Here is the before and after on the last head I rebuilt. It was loaded with carbon but the cleaner made short work of it.
Before
After
MCCOYBOY is offline   Reply With Quote
Old 11-14-2012, 08:56 AM   #5
hayasakiman
Oddometer: 159
Ultrasonic Cleaner for that size is pretty pricey. What kind of solution was used?
How about using gun cleaner solution like Hoppie's? Or, Non-corrosive degreaser?
hayasakiman is offline   Reply With Quote
Old 11-14-2012, 09:11 AM   #6
MCCOYBOY
Oddometer: 99
It's an 8 gallon unit and you can pick one up for around $800. I use a 70/30 mix of pinesol (30%) and water (70%). It also heats the mixture up to 150-175 degrees F. Most shops will have one and won't charge much to clean some pistons. I did a few out of an old yamaha xs850 for a guy and charged him $30 to do 3 pistons.
Old 11-14-2012, 09:13 AM   #7
FlySniper
Bleh...
FlySniper's Avatar
Oddometer: 1,662
Denatured alcohol or 90~99% rubbing alcohol. I can't remember which worked best, one of them cuts carbon really well...
I suspect a soaking in Pine-Sol might work too.
Don't even consider anything with lye, like Greased Lighting.
A feeling of having made the same mistake before: Deja Foobar.
"Think about how stupid the average person is. Now, realise that half of them are dumber than that." - George Carlin
FlySniper is offline   Reply With Quote
Old 11-14-2012, 09:53 AM   #8
hayasakiman
Oddometer: 159
I used Zep for cleaning and it worked good. I will try Pinesol the next time.
Before:
After with Zep:
Old 11-14-2012, 10:57 AM   #9
D.T. OP
D.T.'s Avatar
Oddometer: 11,635
Thumb
I have acess to an ultrasonic cleaner at work, it uses equipment cleaner 30 for solder mask.
The carb cleaner isn't doing much. May try some pine sol and rubbing alcohol too.
Thanks! I just bought some used pistons that I want to clean up.
I tried my 1.5" plastic putty knife and it works much better than I thought it would! I ended up using carb cleaner, wire brush and dull putty knife.
D.T. screwed with this post 11-14-2012 at 06:21 PM
Old 11-14-2012, 01:45 PM   #10
Wasser
Spilt my beer
Wasser's Avatar
Oddometer: 5,191
Stop by your local Chrysler/Dodge/Jeep dealer and pick up some Mopar Combustion Chamber cleaner.
Or, if your local auto parts store carries the Wynns Combustion Chamber Cleaner. Its the same stuff as the Mopar. Wynns makes it for them.
Wasser is offline   Reply With Quote
Old 11-14-2012, 08:24 PM   #11
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,337
Aircraft grade paint remover, methylene chloride. It's nasty and it works well.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 11-14-2012, 08:37 PM   #12
espacef1fan
Oddometer: 680
Try MEK (Methyl Ethyl Ketone) IF you can find it...HORRIBLE shit...wear protection..lol
or you might try oven cleaner and a green scrubby pad...?
2006 Bonneville GS100
2006 Ninja 650R
Want a dual sport again...accepting donations..lol
espacef1fan is offline   Reply With Quote
Old 11-14-2012, 09:13 PM   #13
16VGTIDave
blame Reaver...
16VGTIDave's Avatar
Oddometer: 568
In the past, I've used Castrol Super Clean diluted 1:1 with water (to increase volume and reduce cost) in a steel wash tub and heated it over a camp stove. The parts were simmered for about an hour in this mixture. Other water based de-greasers may also work. All oil, sludge and grease were removed, as well as most of the carbon. The remaining carbon was very soft and easily brushed off with a brass brush. When clean, rinse the parts well with warm or hot water and dry thoroughly. Use compressed air if available, or a heat gun, or a cheap hair dryer (from a thrift store, not your bathroom! ). Then apply oil to prevent corrosion or rust. The parts will rust or corrode quckly as there is nothing protecting them.
Please wear long gloves and eye protection at a minimum! A face shield and a respirator would be even better. Super Clean will remove all the oils from your skin and kill layers of it very quickly. Been there, done that, learn from my mistake! Cracking and peeling skin is painful. I'd hate to think what it would do to eyes...
HTH,
Dave
16VGTIDave is online now   Reply With Quote
Times are GMT -7.   It's 03:41 PM.
