Old 11-14-2012, 04:00 PM   #1
YOUNZ OP
Oddometer: 284
Important Harley twin cam info
I was over at the J&P Cycles web site, checking on a sprocket and saw an important article regarding the twin cam bikes.
Primarily, about the cam chain tensioners failing way to soon and trashing the engine.
Mostly, not covered under warranty, according to the owners comments!
YOUNZ is offline   Reply With Quote
Old 11-14-2012, 04:06 PM   #2
TRRcheck
Oddometer: 307
You're at least 5 years late on the news bud
TRRcheck is offline   Reply With Quote
Old 11-14-2012, 04:35 PM   #3
YOUNZ OP
Oddometer: 284
I don't own a Harley, it was posted on the site today. Apparently it's still a problem, dude.
Old 11-14-2012, 04:50 PM   #4
EricD10563
EricD10563's Avatar
Oddometer: 390
I'm not 100% sure but I think it mainly a problem for Twin-Cam motors prior to 08,
In one year I rode 18,589 miles on an island that's 72 miles long. That's 50 miles a day everyday for 365 days. I think I'll go home now. 69k miles and still riding http://travelwithe.com/blogengine.net/
EricD10563 is offline   Reply With Quote
Old 11-14-2012, 05:06 PM   #5
DAKEZ
DAKEZ's Avatar
Oddometer: 17,983
THAT IS SO 2006. Late to the party again.
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind."
— Dr. Seuss
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 11-14-2012, 05:09 PM   #6
mitchxout
mitchxout's Avatar
Oddometer: 523
I'm sorry to say the cam chain problem has been going on since the early 90's.
mitchxout is offline   Reply With Quote
Old 11-14-2012, 05:22 PM   #7
The Dirty One
Oddometer: 116
They didn't have chains in the early nineties.....'99 was the first year for the modern twin cam.
The Dirty One is offline   Reply With Quote
Old 11-14-2012, 05:29 PM   #8
mitchxout
mitchxout's Avatar
Oddometer: 523
Evo's had chains.
Old 11-14-2012, 05:47 PM   #9
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 2,592
Evo's had chains.
haha, cam chains? not
plugeye is offline   Reply With Quote
Old 11-14-2012, 05:49 PM   #10
panhead_dan
motorcycle addict
Oddometer: 625
Just so you can be all caught up, there is also a whole lot of inner cam bearings that go bad. This usually destroys the engine. (not re-buildable). Loose rollers inside the case is a bad thing, for sure.
A gear drive cam set up eliminates the chain tensioner thing but it must be difficult to fit up correctly because a lot of those have a loud whine which may be from the fit of the gears, I'm not sure. There is a much better bearing available for the inner end of the cams too.
A good practice is to pop off the timing cover and have a real close look at around 25000 miles.
I would rather live my life as if there is a God,
And die to find out there isn't, than live my life
As if there isn't, and die to find out there is.
panhead_dan is offline   Reply With Quote
Old 11-14-2012, 07:25 PM   #11
scapegoat
Pushin forward back
scapegoat's Avatar
Oddometer: 2,820
Crank run out is the problem with gear drive. Word is 09 up hyd tensioners are the way to go.
Reality is merely an illusion, albeit a very persistent one.
scapegoat is offline   Reply With Quote
Old 11-14-2012, 07:35 PM   #12
DAKEZ
DAKEZ's Avatar
Oddometer: 17,983
06 on the Dyna's 07 on all the twin cams.
If you warmed the bike up, never got on it hard until completely warmed up and did not lug the engine (the engineers want you to cruise at 2900 to 3100 rpm's) then the old tensioners would last 80k plus miles.
The ones that ran into problems were the throttle blippers and those that thought they should be cruising down the highway at 2200 RPM's. They were having issues at around 25k miles.
— Dr. Seuss
Bib
Old 11-14-2012, 07:40 PM   #13
frog13
frog13's Avatar
Oddometer: 999
So,I guess I'll keep my Honda.
frog13 is offline   Reply With Quote
Old 11-14-2012, 08:26 PM   #14
NuckaMan
Space Available
Oddometer: 278
2005 Suzuki Hayabusa
2008 BMW GS Adv
NuckaMan is offline   Reply With Quote
Old 11-14-2012, 08:30 PM   #15
Tosh Togo
Oddometer: 1,594
When a manufacturer's biggest efforts go into "nostalgia", there's no surprise in that.
What could have been, and never got a fair chance.
Tosh Togo is offline   Reply With Quote
Times are GMT -7.   It's 03:28 PM.
