Old 11-14-2012, 07:28 PM   #1
espacef1fan OP
Oddometer: 582
Static Tire Balancer--Is this one any good?
http://www.cyclegear.com/eng/product...and/web1010635
Im kind of done dealing with dealers and shops. This balancer would pay for itself the first tire change with the rapings they charge you for in the Nashville area...
2005 Ninja 250
-WTT or WTS
$2400 OR KLR650, TU250, W650..sportbikes, naked bikes...whatever...
espacef1fan is offline   Reply With Quote
Old 11-14-2012, 07:42 PM   #2
bhorocks
bhorocks's Avatar
Oddometer: 310
save your money if you dont care for the truing stand.. I use the harbor frieght one and it works just fine..
http://www.harborfreight.com/motorcy...and-98488.html
bhorocks is online now   Reply With Quote
Old 11-14-2012, 07:46 PM   #3
espacef1fan OP
Oddometer: 582
I just read all the reviews for that balancer, it seems all of the shafts are bent from the box...no good. I want to like the $39.99 thing..but..yeah. :/
2005 Ninja 250
-WTT or WTS
Old 11-14-2012, 08:08 PM   #4
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,173
"marc parnes" balancer
sometimes they pop up used
none of us are as dumb as all of us
clapped_r6 is offline   Reply With Quote
Old 11-14-2012, 08:35 PM   #5
espacef1fan OP
Oddometer: 582
I like it...but how important is it to get the shaft perfectly level? I mean jackstands only get so close....
2005 Ninja 250
-WTT or WTS
Old 11-15-2012, 03:16 PM   #6
Rd650
Rd650's Avatar
Oddometer: 124
+1 on the HF trueing stand. Worth $40 for sure.
Rd650 is offline   Reply With Quote
Old 11-15-2012, 03:35 PM   #7
ibafran
villagidiot
Oddometer: 1,168
Do the search for balancing stands on this site. You can build yourself a 'dead on rails' balancer for about $10. It works so good that it is scary. Original article can be found some years back in Motorcycle Consumer News under DYI Motorcycle Wheel Balancer. Visit http://board.mcnews.com/ and look at the article index till you find it. Annoys me no end that the info isn't on the 'free' section of the site.
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 11-15-2012, 05:17 PM   #8
sailah
Lampin' it
sailah's Avatar
Oddometer: 4,142
I built one very similar to this but did not want thumbscrews. So I simply made the cones "stepped" to fit my Husky and KTM wheels. I also simplified the mounts. I used 1/2" drill rod and 1/2" shielded bearings. It's very accurate. If you don't have a lathe, you'd have to have a machine shop turn up the cones. I tried it once with sealed bearings and they have too much resistance. Shielded works great.
Here's a pic I found of the dead on rails.
I drop mine down on jack stands, takes seconds to set up. Mine is pictured with the KTM cones on it which are 20 & 26mm I think. The Husky ones are setting next to it. I also made some housings for the bearings but they serve no purpose.
Total cost was maybe $20.
Here's what I used, Mcmaster catalog stinks for linking parts, but I listed the part numbers.
http://www.mcmaster.com/#catalog/118/3673/=k6iwi2
Tool steel 0.5000" ±0.001" 8893K451 $5.06
1/2" ID 1 1/8" OD double shielded ball bearings 6384K61 $7.98
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Old 11-15-2012, 05:33 PM   #9
ohgood
ohgood's Avatar
Oddometer: 745
I don't get it... what's wrong with the stock axle and two lawnchairs ?
no, really.
Crazy_Dave just made it into my sigline, and I agree: I fall down alot.
ohgood is offline   Reply With Quote
Old 11-15-2012, 06:09 PM   #10
sailah
Lampin' it
sailah's Avatar
Oddometer: 4,142
no, really.
The friction of the seals in the bearings is enough for it not to be accurate.
I tried mine with brand new precision sealed bearings and it was not accurate. Asking old wheel bearings to do this work not happening.
With the shielded bearings, it's much more accurate. I will let it settle, and move the wheel maybe 1-2 degrees and it will go right back to settled after clocking back and forth.
With open bearings it would be even more accurate but they are really hard to keep clean.
I notice a huge difference on the road with my dirt bike tires, especially since I am running rimlocks. My KTM has the valve core and rimlock in the same 30 degrees so it's really out of whack the Husky at least offsets them.
Nessmuk
Old 11-15-2012, 07:16 PM   #11
ragtoplvr
Oddometer: 4,543
I have a Harbor Freight one, it is within about 1/2 ounce. How do I know. I balance as perfect as I can. Then take wheel off and remount. Then I re-balance, taping the weights in place. Doing this several times, I never have needed over about 1/4 oz to rebalance.
I have tested the tires to 120 and no vibration. Beemer likes that, ran a LOT smoother for a while. Good enough for me.
Rod
ragtoplvr is offline   Reply With Quote
Old 11-17-2012, 06:11 AM   #12
Jamming
Desert RAT
Jamming's Avatar
Oddometer: 2,569
I use one, works great! Works better if you use bearings off a skateboard wheel.
My Native American name is "plays in traffic"
Triumph 1050 Tiger
WWW.Motorcyclistcafe.com
Jamming is online now   Reply With Quote
Old 11-18-2012, 12:25 PM   #13
mendoje
Oddometer: 134
I also have the Harbor Freight balancer. Take the bearings out, peel out the bearing shields and toss 'em. Then flush out the grease and lube with very light oil. You'll be able to balance to a 1/4 ounce or less no problem.
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike )
mendoje is offline   Reply With Quote
Old 11-18-2012, 05:35 PM   #14
espacef1fan OP
Oddometer: 582
This sounds like good advice!
2005 Ninja 250
-WTT or WTS
Old 11-18-2012, 07:47 PM   #15
racer1735
Oddometer: 293
Not all the shafts are bent. I can attest to that. Genreally the bent ones are the few that speak up about them (that thing about the 'greasy wheel', you know?) You may have to true up the uprights, but that is easy. And the bearings work exceptionally smoothly.
One cylinder (my XL) or four (my ST)? That is the question.
racer1735 is offline   Reply With Quote
Times are GMT -7.   It's 03:27 AM.
