Old 11-14-2012, 06:47 PM   #2866
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Watts Vs Lumens
I continued to be amazed at the Vendors on this forum promoting Watts as end all be all to light output.
As I said many pages ago, Watts is a measurement of electrical consumption.
It is not a measurement of light output.
Please do your research and reach your own conclusion
Old 11-14-2012, 08:25 PM   #2867
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,130
X2
It was an ok way 20 yrs ago to compare 2 bulbs of the same design, but even then candlepower is better measurement than watts!
Low594 is offline   Reply With Quote
Old 11-15-2012, 01:16 AM   #2868
Itapop
Itapop's Avatar
Oddometer: 6
As I said many pages ago, Watts is a measurement of electrical consumption. It is not a measurement of light output. Please do your research and reach your own conclusion
Truly true, but they declare 3,600 lumen for the BD Squadron and 42 watts. Model 60 takes 30 actual watts with the same 4 Cree T6 and same lumens, so don't know why 12 watts of difference in consumption. Just a curiosity for me, maybe a stabilizing component that takes energy, I'm not a technician.
The best from what happens.
Itapop is offline   Reply With Quote
Old 11-15-2012, 09:49 AM   #2869
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,967
Watts is just volts x amps - but LED's run on amperage, not voltage. You want more light out of an LED? Run more amps thru it. You can also cook it this way! Good LED lights have an amp regulator on them (rather than just a simple resistor), really good lights also have a temp sensor which will dial back the amps when you're about to cook the LEDs due to lack of cooling. IIRC, the life of the LED also drops as the amps go up - just like the old halogen bulbs when overvolted!
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 11-15-2012, 09:49 AM   #2870
michigan400
Oddometer: 80
+1,, good question.
Edit - Just seen your response wadester. So if more light requires more amps, more amps at the same voltage (12 I'm assuming) means more watts consumed. How can 1 change and not the other 2? If 2 lights use the same LED's, have the same output in lumens and run at the same voltage how can they not consume the same amount of watts?
I'm not trying to be a smartass or anything, just curious as well because from my understanding something sounds off. I'm no expert by any definition so the problem very well could be in my understanding of it.
michigan400 screwed with this post 11-15-2012 at 09:59 AM
michigan400 is offline   Reply With Quote
Old 11-15-2012, 03:24 PM   #2871
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,967
Originally Posted by michigan400 View Post
+1,, good question.
Part of that is how you read light emission specs. Are either of the light mfg's in possession of test reports of the light emission of their device? Or are they quoting the specs of the LED mfg for light output? I haven't pulled spec sheets for those LEDs, but I bet it says "900 lumen output" on it. You want to claim something else? Pay for a lab to rate your device - with enough samples to truly have a statistical validity.
Old 11-16-2012, 11:10 AM   #2872
RoundOz
Plenty of seasoning
Oddometer: 993
Muddy waters...
In comparing lights output in Lumens with how many watts they consume, you are comparing the efficiency of the conversion of electrical power to light. Assuming that all the measurements are accurate, if one light puts out more lumens than another for the same wattage, then it is more efficient. The wasted watts don't just disappear however, they are converted into another form of energy, most likely heat. This is why fluorescents and LEDs produce so much more light and are cooler (generally) than halogens and incandescents.
Just because two lamps use the same type of LED (and not that I have done any research on this but I would guess that Cree makes many different grades of LED with different efficiencies and quality control levels) is not the whole story. The electronics package that drives the LED could be more or less efficient too. Less efficient means more heat and heat is the enemy of electronics. So maybe you should look for the lamp that uses the least watts? I doubt that the difference between the best and worst lamps amounts to more than a few watts in the driver board, but that is just opinion, based on the idea that if the board was producing huge amounts of heat in such a small space, even great heat sinking would not save it.
So Lumens per watt is the best way to compare lamps? Wait, there's more mud here. Lumens are a measure of the total light output of a source - in ALL directions. Even if the manufacturers are being truthful and accurate in what they state, the key to performance is getting the photons where you want them - the design and quality of the lens is the main variable here. A better measure of light output in a given direction is Lux, which measures the amount of light falling on a surface. As light from a lamp typically disperses with distance, more so with a flood beam than a spot beam, to compare output between lamps you would have to measure lux at the same distance from the source, and probably pretty close to reduce the errors of beam patterns. So what happens to the light that doesn't go where you want it to? It disperses uselessly (or usefully, depending on what you are trying to illuminate) or it bounces around inside the lamp and creates more heat.
If manufacturers are not quoting Lux, (and some do provide isolux diagrams - Lux maps, if they can be trusted or compared) and everything else is open to interpretation, what is the best way to choose lights. For my money, I guess I would keep wattage iin mind if my electrical supply was marginal...then look at beam patterns, ruggedness, customer satisfaction, return policies etc. that's where sites like advrider are a real resource.
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 11-17-2012, 10:35 AM   #2873
Meritlane
Meritlane's Avatar
Oddometer: 63
F8 dimmer mount
Looking for a good idea for placement of wireless dimmer box on an F800GS.
Ideas?
Meritlane is offline   Reply With Quote
Old 11-18-2012, 05:57 PM   #2874
kelsow
kelsow's Avatar
Oddometer: 1,118
Had a crash today. Bike hit hard and slid into fist sized rocks.
Lights are still working albeit pointing in the wrong direction.
"Kelsow's helmet is so tight, it cuts off the circulation to his personality."
Ride: 2010 BMW F800GS
Site: dualsport.ca and rideatlantic.ca
kelsow is offline   Reply With Quote
Old 11-18-2012, 08:17 PM   #2875
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,293
Offff....hope you're alright!
Old 11-19-2012, 07:01 AM   #2876
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,203
dang, those are tough lights!
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 11-19-2012, 09:37 PM   #2877
GorG
Oddometer: 2
Sanjoh, please check your email!
GorG is offline   Reply With Quote
Old 11-19-2012, 10:26 PM   #2878
jkstehn
Oddometer: 105
First ride home tonight in the dark. NICE!!!
Question for the crowd: What tricks are out there to help keep the rotary dimmer from moving so easily? I mounted my dimmer on the left bar, near the turn signal and sometimes bump it with the tip of my glove when I activate or cancel the directional.
Was thinking o ring or plastic wire wrap around the body of the first switch to rub against the side of it and provide some resistance to rotation.
Thoughts?
Jon
Sent from my Galaxy Nexus using Tapatalk 2
Jon
WR 250 R
jkstehn is offline   Reply With Quote
Old 11-20-2012, 03:00 PM   #2879
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Ideas?
Inside the fairing or under the seat.
Hope you are ok.
Checked, did I reply
Old 11-20-2012, 03:10 PM   #2880
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,920
Glad to hear you are happy with the light How about a pic of your installation?
Oring doesn't work very well as the knob overhangs the edge of the box and the oring will roll under the knob. I'd recommend moving it to a location that is out of the way, perhaps just rotating the box in place would work?
Times are GMT -7.   It's 07:29 AM.
