Old 11-15-2012, 01:29 AM   #48991
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 750
Originally Posted by Barron View Post
The NX650 5th is awesome. I've got 15/45 gears and can run highway speeds with no problems at all. I've also got the NX second gear to move the gap from between first and second to between second and third where it's less noticeable. It was definitely worth splitting the cases and have really enjoyed getting back the grunt in 1-4th gears that I had to give up when I put a 43 tooth sprocket on for highway speed.
As luck would have it, I should be able to get that 5th gear pretty easy in a few weeks
-Barron
2007 XR650L,
Looking to acquire a stock XRL choke plunger.
The multi-quote function is your friend.
It's surprising how idiots have good luck, I don't have good luck.
KyoXR is offline   Reply With Quote
Old 11-15-2012, 04:45 AM   #48992
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
Originally Posted by Brown Falcon View Post
Yes, I remember that NC mud... sticky sticky stuff! Not much worse than the Oregon clay out here though.
I remember Willamette Valley clay. However, now that I'm in Western GA I can tell you the clay soil here is redder and sticky-er than anything in OR. It stains anything if left on too long.
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 11-15-2012, 04:57 AM   #48993
absoluteclint
absoluteclint's Avatar
Oddometer: 206
Originally Posted by XR650L View Post
Custom made to take Rotapac Fuel tanks and sleeping bag, tent etc on back. Bolt straight onto subframe supports. Let me know if you want more pictures of it.
Sure... If you get around to it... That'd be great. I've been talking to Mike at Manracks... He's holding a SD rack for me now... One similar to Spud's. Mike has been very responsive and great to deal with so far.
Sierra (or anyone else who can comment)... I've got my de-smogging kit ordered. I quickly skimmed the removal pics/instructions on 4strokes.com... Looks like a pretty straight forward process. Is there anything I should be on the look out for or pay particular attention to when doing the removal? Any other adjustments or mods that are necessary after removing the smog kit?
Thanks... Clint
absoluteclint is offline   Reply With Quote
Old 11-15-2012, 05:16 AM   #48994
JWhitmore44
pistolero
JWhitmore44's Avatar
Oddometer: 1,621
Thanks... Clint
Don't remove the oil separator, that black cup thing behind the petcock. It's not part of the smog control and it's actually useful
84 Honda Goldwing (GL1200)
03 XR650L
JWhitmore44 is offline   Reply With Quote
Old 11-15-2012, 05:26 AM   #48995
bearcat1
bearcat1's Avatar
Oddometer: 238
I was just cruising along and all of sudden............. whoops!
I am exhausted just looking at that picture!
bearcat1 is offline   Reply With Quote
Old 11-15-2012, 05:30 AM   #48996
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
+1
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 11-15-2012, 07:25 AM   #48997
absoluteclint
Oddometer: 206
Originally Posted by Sourjon View Post
+1
John
John and Whitmore... Thanks for the advice and diagram. That will be printed and have a permanent home in the garage-library. Got a link for anymore simple, internal diagrams like that?
Bearcat... You're right! I knew pretty quick I wasn't going anywhere. I spun the wheel one good time and wiggled/pulled/rocked the bike once... No movement... I went straight to the phone for a bailout call!
I'm thinking of getting something like this to carry along on unsure trails...
http://www.amazon.com/Maasdam-PowR-P...act+come+along (removable handle... only 12 inches long... pretty compact)
or
http://www.amazon.com/Wel-Bilt-Manua...ref=pd_cp_hi_3
Old 11-15-2012, 09:04 AM   #48998
Dooga
Adventure Tourer
Dooga's Avatar
Oddometer: 304
The best XRL-friendly heated grips
There's a lot of advice as to which grips will not play nicely with the XRL's wimpy juice-box -- what heated grips are the most XRL-friendly? Also, which is the most XRL-friendly way to tap into juice for a vest and maybe pants so that I can ride through DC's relatively mild Winter? Thanks in advance, kids. I am going to man up and keep riding!
1995 BMW K1100LT
Dooga is offline   Reply With Quote
Old 11-15-2012, 10:15 AM   #48999
sc-razor
sc-razor's Avatar
Oddometer: 3,776
or
I can't believe you didn't go flying over the bars. Must not have been an abrupt stop.
2009 XR650L
2009 KTM 300XC-W
Steve
sc-razor is offline   Reply With Quote
Old 11-15-2012, 10:18 AM   #49000
XR BADGER
XR BADGER's Avatar
Oddometer: 39
Manracks case saver on the way! Was wondering if the best way to adhere the piece was jbweld or ht silicone?
2007 XR650L, Dave's carb mod's, XR'S only smog kit, XR'S only skid plate, Acerbis 5.8 tank, CRF 450 front fender...
XR BADGER is offline   Reply With Quote
Old 11-15-2012, 10:37 AM   #49001
ThumpnRed
Pig Wrangler
ThumpnRed's Avatar
Oddometer: 2,558
I used JB Weld to attach my non Manracks case saver. It has held up great .
Originally Posted by Cigar Mike :With plastic buy two.
'93 XR650L A few stock parts left...
ThumpnRed is offline   Reply With Quote
Old 11-15-2012, 11:31 AM   #49002
JWhitmore44
pistolero
Oddometer: 1,621
+1 on JB weld, I wouldn't trust silicone to hold up.
03 XR650L
Old 11-15-2012, 01:44 PM   #49003
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 2,454
+2 on the JB weld. I used a dremel to rough up the case surface and the back of the saver then taped off the area that I wanted the JB weld on as Steve advised me in the past . It worked out great. I wouldn't trust the silicone to hold up either, just doesn't seem like the right tool for the job.
Here's a pic of mine...
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 11-15-2012, 01:46 PM   #49004
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,941
or
Those are huge,heavy and bulky....all you need is a tiny 3to1 or 5to1 rope and pulley.....finding or making an anchor point is the hardest part....
About $30 bucks ........they are stainless steel and poly.....stick them in a saddle bag and forget about them till needed.......put them away wet no problem, those others you posted would be all rusted and corroded.
Hurricane Bob is offline   Reply With Quote
Old 11-15-2012, 02:09 PM   #49005
mcma111
mcma111's Avatar
Oddometer: 12,402
-Barron
Your bike sure looks different these days.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 05:57 AM.
