11-03-2012, 02:26 PM
#646 | |
STILL Jim Williams
Oddometer: 5,956
11-03-2012, 02:46 PM
#647 | |
STILL Jim Williams
Oddometer: 5,956
That wood is Brazilian gold. Supposedly the only thing harder is ipe. The grain couldn't be tighter. |
11-03-2012, 03:48 PM
#648 |
Oddometer: 154
Got to have Hope!
Stopped into your Hope St. locale.
Best croissant this side of Paris. Lunch samichies for picinick down by the bay, yummy. |
11-03-2012, 04:25 PM
#649 |
STILL Jim Williams
Oddometer: 5,956
Thanks for the support
Much appreciated. Let me know next time you're in town. I'd be happy to show the bakery in nearby Pawtucket.
11-03-2012, 09:48 PM
#650 |
Watching the bears
Oddometer: 1,897
"Buen dia ., Buen camino..." - Bato |
11-04-2012, 03:32 AM
#651 |
STILL Jim Williams
Oddometer: 5,956
That looks better than most bakeries
![]() ![]() ![]() Nice color. Volume. Hole structure. Great job
11-04-2012, 08:00 AM
#652 | |
Oddometer: 1,852
It would smoke & turn black, but never ignite.
11-05-2012, 02:15 PM
#653 | |
Oddometer: 2,486
Then I went to using an upside down skillet on a rack above the bread (the theory being that the bread's own steam and a minor cover even on the next rack up was enough to create a steamy environment for the bread to rise), then finally tried the lid-style for half baking... which worked very well once, and not so well afterward. I'm going back to the pan of water int he oven thing and I'll see how it does. |
11-05-2012, 06:48 PM
#654 |
Boring bastard
Just don't you know....pour cold water into an empty hot pyrex dish.
Not that I ever Did such a boneheaded thing. Or tried to pick the pieces out of a ridiculously hot oven. Nope. Never ![]() ![]()
I like cold wet doggy nose in my crack. |
11-05-2012, 07:13 PM
#655 |
Oddometer: 2,486
Sounds like another convert to some cast iron cookware has been born.
My bread gets cooked in a 8" skillet (measured from the top rim), and a small 6.5" porcelain coated skillet gets the water (that I'm back to using). ... but then I wouldn't add water to an already hot skillet, either. It gets the water in it early, and gets put back in the oven for the pre-heat. Mambo Dave screwed with this post 11-05-2012 at 07:56 PM |
11-05-2012, 08:30 PM
#656 | |
Watching the bears
Oddometer: 1,897
And oh so good with real butter.....
11-10-2012, 10:54 PM
#657 |
Don't mean sheeit. .
Oddometer: 2,549
Finally tried this no-knead bread, though I used some sourdough starter that I've had going for a long time, and no yeast. Otherwise I stayed pretty close to the recipe and timeline. Looks good, but I haven't cut into it yet:
Also last night I made some potato-fennel sourdough bread, it's my wife's favorite. I made a wetter dough than I usually do, and baked in a hotter oven, I like the results: I recently bought another kiln shelf from the local pottery supply, so that I can have baking stones above and below the bread, and this batch baked at about 475. The one thing I still want for my bread baking is to make up some cloth lined baskets for rising. Seems like they do a better job of making a tall loaf than the couche does. I like a taller loaf just for practical purposes, the sandwiches fit in my lunchbox easier.
Zak ktm old bmw others |
11-11-2012, 08:42 AM
#658 |
Oddometer: 1,175
^ So you put a kiln stone above your bread and do you cook directly on the bottom kiln stone? If that is so are the kiln stones ok with no traces of lead or you just use the stones for even heating? I like the idea of some mass in a standard home oven and have not thought of kiln stones. How far are the kiln stones spaced? Thanks
11-11-2012, 10:07 AM
#659 | |
Oddometer: 2,549
Yes, I cook directly on a kiln shelf/baking stone, and the upper baking stone is as close as it can be to the top of the bread, based on where my oven shelves are- I usually end up with about 6" between upper and lower. If you look at most commercial bread and pizza ovens, the decks are only 6-8" high on the inside, so you get heat radiating down from the top. I notice on the pizza fanatic forums, a lot of people use steel plates as thermal mass, I guess to radiate/conduct more heat into the pizza than ceramic would. Edit: I should point out that the no-knead bread in the first batch was made the way the no-knead recipe advises, in the enameled dutch oven in the background of that picture. I preheated oven and dutch oven to 475, put the bread in, baked for 30 minutes covered and 15 minutes uncovered. Worked very well, though I usually like to make more than one loaf at a time, which would be hard with that method.
11-16-2012, 09:32 AM
#660 |
Oddometer: 2,486
Please tell me I didn't just poison myself.
Mixing and matching bread theories, just before baking I saved a part of the no-knead mix I baked days ago as a 'biga' (if I'm even spelling that correctly). My loaves are smaller - like 3 cups of flour - because it's just me eating them (maybe I've accidentally poisoned too many girlfriends with my cooking?) I went and mixed that in with my no-knead recipe (that I put slightly less yeast in with) yesterday, and cooked it all up just now. Somehow I got a true sour dough taste (strong! a bit stronger than any sour dough bread I've ever bought... but good!) in just that small time of allowing that biga to sit, and then re-using it. Like strong enough that I'm wondering, now, if I have bad bacteria or mold or something in it, because I've heard biga for sour doughs takes quite a while to develop its flavor. Anyone foresee a problem with using parts of the last batch as the biga with a no-knead recipe? It seems to be leading me down the path of adding taste to the traditional no knead bread. ---- While they aren't baking stones, I leave my four cast iron skillets in the oven for the 500 degree preheat. I use two of them, hot, to bake bread now as my poor-man's dutch oven. Three of my skillets are the same size, so I just use one on top of the other, but upside down, as the 'lid' for the dutch oven. Between those, and the two left in the oven while I'm dumping dough into the first, there is enough radiant heat that I seem to be getting away without a baking stone. It may not be traditional, but I'd suggest to a lot of guys out there who want bomb-proof stuff to just use cast iron. For my smaller 3-cup of flour bread I cook for 15 minutes with the top one on, then 20 minutes this last time with the lid off, at 500 degrees. I was trying 15 and 15, but it seemed too short of a time for both the crust and the insides. Mambo Dave screwed with this post 11-16-2012 at 09:40 AM |
| Thread Tools | |
