Old 11-13-2012, 07:43 AM   #106
Pugsley/Hobbfather
Oddometer: 414
^Forgive ignorance here...
...but any reason to use the hole saw in the handheld drill? It looks like the pilot was created with a drill press.
Otherwise:
HOLY COW THIS IS AWESOME!
Pugsley/Hobbfather is online now   Reply With Quote
Old 11-13-2012, 09:04 AM   #107
oregoncoast
Racing Like a Noob
oregoncoast's Avatar
Oddometer: 4,461
Looking great. I hope I get to come up there one of these weekend's to break stuff...I mean, help out the build too!
Old 11-13-2012, 09:09 AM   #108
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 730
I was just asking Luke yesterday if we might see you, he said that between working overtime and building your MK1 Rally Suby, you were swamped. Hope we get to see you sometime soon, would hate to have you miss all the fun.
"Nothing can stop us but fear and common sense”
LC Garage is offline   Reply With Quote
Old 11-13-2012, 09:38 AM   #109
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,136
Originally Posted by Luke View Post
Small tool, big job. But it worked.
Sooner, or later, this is bound to wind up being a caption for different picture.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is online now   Reply With Quote
Old 11-13-2012, 09:53 AM   #110
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 730
This may be evidence of Luke's very dry wit....
Old 11-13-2012, 01:36 PM   #111
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,151
Otherwise:
The cordless drill can turn much slower than the drill press, which is good for the hole saw bit. Here's the post: http://advrider.com/forums/showpost....postcount=1695
Jdrocks wasn't kidding about the binding either, I've got a tender spot on my ribs where the drill's battery pack smacked me a few times.
Luke is offline   Reply With Quote
Old 11-16-2012, 12:48 PM   #112
Pugsley/Hobbfather
Oddometer: 414
^Luke^
Ahhh...added to my vast knowledge base...
Old 11-19-2012, 09:24 AM   #113
LC Garage
On Any Sunday
LC Garage's Avatar
Oddometer: 730
Swing Arm
Luke came over Saturday and started fabricating the swing arm, as you can tell from the photos, he made pretty good progress. I'll post the pics and let Luke weigh in later with the commentary.
Swing arm pics;
And Luke's new toy;
Old 11-19-2012, 12:47 PM   #114
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,374
Why are you making the swingarm out of multiple pieces of box tubing? Doesn't look like it would be and harder to drill offset holes for the swingarm pivot that would give you the angle/clearance you need? Luke, if you want to send me some dimensions I can help you figure that out?
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is offline   Reply With Quote
Old 11-19-2012, 03:04 PM   #115
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,151
A straight tube won't work because the shock mounts are going to be under the center of the swingarm. Here's the cross section of the parts to be avoided at the centerline of the swingarm.
Old 11-28-2012, 12:45 AM   #116
TwinDuro
Befuddled Adventurer
TwinDuro's Avatar
Oddometer: 318
Very nice TIG torch Luke! Is the little knob towards the upper end of the torch handle a shielding gas control valve?The swingarm is coming along nice as well.
Only problem is we need more updates! I'm sure I'm not the only one having CBZR-650 withdrawals...
"Remember, you may have to grow old, but you don't have to mature." - Red Green
TwinDuro is offline   Reply With Quote
Old 11-28-2012, 11:19 PM   #117
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,151
Yeah, I'm having withdrawal too. I got a little work in last week but have been busy since then.
From last week, a little more swingarm work:
Start with making a tube to simulate the hub with extra spacers.
This'll be a lot faster when I get the parting tool working.
Then tack some parts together.
More stick welding. I like.
The welds turned out as flat as the tube stock.
It turned out pretty well, with the axle and swingarm legs clamped together they were within 1/2mm at the swingarm pivot tube.
Cutting the cross brace.
The legs needed a bevel cut into them, and that was the last thing to do. These cuts were tricky, and I had to learn a few things about chop saws and metal tube. Chop saws need pressure to cut. Long flat cuts don't work. Metal tube has internal stress. Slit it long ways and it will spring out. Not the end of the world, but that'll be something to fix next time.
Old 11-29-2012, 12:11 AM   #118
jesusgatos
jesusgatos's Avatar
Oddometer: 2,374
Understand what you're doing with that swingarm now. Thanks for clarifying. For any precision cuts, you might want to try scribing lines on all four sides and then using a 4-4.5" angle grinder with a cutoff wheel. It's almost impossible to hit perfect angles on a chopsaw.
Old 11-29-2012, 01:17 AM   #119
Luke OP
GPoET&P
Luke's Avatar
Oddometer: 4,151
Originally Posted by jesusgatos View Post
precision ... angle grinder
You must have a much steadier hand than I do. I always do way better with the chop saw. Start with a decent one and take the time to square it up. It's a moot point anyway because the accuracy of the swingarm doesn't depend on the accuracy of the cuts. It just makes the fit better for welding.
The half mm was the difference in width between each end of the swingarm with the axle end bolted up and the pivot end free. A 0.05 degree error.
Old 11-29-2012, 01:59 AM   #120
wayne_l
Oddometer: 182
Like your build up so far ..Thanks Have a question on the front end .. which tripple trees did you use for the forks ? did you have to modify the neck bearings to fit ?
wayne_l is offline   Reply With Quote
Times are GMT -7.   It's 08:10 AM.
