Old 11-16-2012, 05:05 PM   #1
BigChris99 OP
BigChris99's Avatar
Oddometer: 224
Getting into frozen car door locks?
My daughter is going to college in eastern Iowa, gets pretty
cold there in the winter. This is her first year having a car out there. The car is a '99 Toyota Camry. We had to remove
the after market car alarm that came on the car, too many problems. So, she has to manually unlock the doors on her
car, just like most of us did when we were kids. Being from southern California we are not too experienced with freezing
temps. So what is the best way to either keep locks from freezing, or getting into a car that has locks that are frozen?
I suggested she keep a lighter in her purse to warm up her key. Good idea?? You guys that deal with this every winter
must have some things to do or not to do to get her through an Iowa winter.
4on3off
IBA#7849
1991 Honda GoldWing...gone 1997 Honda Valkyrie, 1998 Kawasaki KLR 650
BigChris99 is offline   Reply With Quote
Old 11-16-2012, 05:08 PM   #2
this is a RV
Oddometer: 242
Deicer spray for her bag too.
this is a RV is offline   Reply With Quote
Old 11-16-2012, 05:10 PM   #3
VStromTom
Oddometer: 1,575
Lived in SD for 4 yrs, never ever had a problem with frozen locks on any car I had while there. Sleet, snow, rain/sleet, -20, doubt she will have a problem. Cars did not have remote door locks, always had to use a key. The lighter idea is probably a decent one.
VStromTom is offline   Reply With Quote
Old 11-16-2012, 05:10 PM   #4
cchoc
Outdoor Photographer
cchoc's Avatar
Oddometer: 131
I used to live in Kansas and used a lighter on my key, worked fine. Not sure about the newer keys with chips, though.
Charlie...
Stalking Light
'13 F800GS Kalamata Metallic
cchoc is offline   Reply With Quote
Old 11-16-2012, 05:19 PM   #5
ragtoplvr
Oddometer: 4,539
Silicone spray the door gaskets, keep a small container of lock deicer, that you will likely never use.
Rod
ragtoplvr is offline   Reply With Quote
Old 11-16-2012, 05:20 PM   #6
mcma111
mcma111's Avatar
Oddometer: 7,966
Get some powdered graphite and lube up the lock cylinders. Do all of your vehicles and the house while your at it. Work the graphite into the cylinder/pins with the key.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 11-16-2012, 05:21 PM   #7
BigChris99 OP
BigChris99's Avatar
Oddometer: 224
Great ideas guys, thanks. I'll pass them along to her.
4on3off
IBA#7849
Old 11-16-2012, 05:22 PM   #8
Jimusma
JimUSMA
Jimusma's Avatar
Oddometer: 42
+1 on the decider spray. About the size of a lighter or a lipstick. She'll probably never need it, but nice to have.
JimUSMA
Jimusma is offline   Reply With Quote
Old 11-16-2012, 05:23 PM   #9
WVhillbilly
WVhillbilly's Avatar
Oddometer: 4,553
I use something similar to this on my door locks and latches.
http://www.homedepot.com/buy/blaster...l#.UKbmjoY8WSo
My locks don't freeze, I also spray silicone on the door seals so the door doesn't stick shut.
Other option http://www.mdc.edu/main/
WVhillbilly is offline   Reply With Quote
Old 11-16-2012, 05:35 PM   #10
troidus
Oddometer: 6,877
+1 on silicone spray on the door seals (and other weatherstripping, hood, trunk, and door stops, hoses, etc.--just not belts or controls).
Tell her not to wash the car if it's going to drop below freezing that night. Also tell her that if one side is iced over from freezing rain, the other side probably isn't as bad and she might have better luck getting that door open. And tell her not to try to roll down the windows if they're iced up or she'll break the regulators or tear up the rubber. Make sure she gets a good ice scraper and a snow brush--they do not have to be the same device, but some of the combined units are decent.
troidus is offline   Reply With Quote
Old 11-16-2012, 05:49 PM   #11
P B G
Oddometer: 9,781
I went to the University of Iowa, never had my locks ice either.
I think the only times I've experienced this were vehicles that were parked outdoors, then inside somewhere warm/heated, then back outdoors... Which I never did in college.
Old 11-16-2012, 05:58 PM   #12
BigChris99 OP
BigChris99's Avatar
Oddometer: 224
Thanks, but she's in her Jr year at this school. Really likes it, and she's National Honor Society for her first two years.
She has a full ride academic scholarship. Pretty entrenched there. Likes the small town too. Except for the winters!
4on3off
IBA#7849
Old 11-16-2012, 06:00 PM   #13
BigChris99 OP
BigChris99's Avatar
Oddometer: 224
That's good the hear, her car stays outside.
4on3off
IBA#7849
Old 11-16-2012, 06:57 PM   #14
FlyingFinn
Oddometer: 940
Originally Posted by BigChris99 View Post
My daughter is going to college... her car is a '99 Toyota Camry.
..she has to manually unlock the doors on her car
Being from southern California we are not too experienced with freezing temps...
Such a sob story
A college kid has to drive a 99 Camry. With no power locks!! Where's the justice!!
Silicone on gaskets, good.
Oil in the lock cylinder, good.
De-icer to get a frozen lock (there was no oil) to open, good short term bad long term.
Prevention really is the key here.
Oil the locks and silicone the gaskets, that way the won't be problems with freezing.
Using the de-icer get her out of the pickle at that moment but the de-icers also tend to flush out any trace amounts of lubricant from the lock cylinder.
Then it freezes even worse.
Mikko
"It is not when or how you die but how and if you truly were ever alive!" Dr. Jerri Nielsen FitzGerald
FlyingFinn is offline   Reply With Quote
Old 11-16-2012, 07:15 PM   #15
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 6,275
I never tried to spray the door gasket, that is a good one.
Only time it happened to me was after washing the car when it was below zero out.
"Tough times don't last, but tough people do." Robert A. Schuler
D.T. is online now   Reply With Quote
Times are GMT -7.   It's 07:01 AM.
