Old 11-16-2012, 03:57 PM   #31
slowlane OP
slowlane's Avatar
Oddometer: 82
Thanks JerryH. It will definitely have extra gas as I plan on mounting a 1 gallon tank on either side of the rear end. Yes the milk crate is an amazingly simple and useful stuff carrier. I have hauled many things in it as well as attached many things to it over the years. I have ridden this bike on tons of gravel roads and every "ding" and "clang" of a rock hitting the underside of the bike was always a little disconcerting. This bike is going to be in for a lot more than a simple gravel road in the future so I felt some sort of guard was necessary. As for the front fender, I am going to remove the original and replace it with a cheap repro fender that I have, and I'm not too concerned about that one getting beat up or broken.
slowlane is offline   Reply With Quote
Old 11-16-2012, 05:24 PM   #32
MacNoob
MacNoob's Avatar
Oddometer: 1,629
I didn't see where your spiffy new shocks came from?
"Ignorance, you see, can be out thought. Arrogance can be outmaneuvered. But ignorance and arrogance combined are unassailable."
82 Honda C70, 71 Honda CL175, 08 Kawasaki KLR650, 85 Honda GL1200 Goldwing
MacNoob is offline   Reply With Quote
Old 11-16-2012, 05:57 PM   #33
slowlane OP
slowlane's Avatar
Oddometer: 82
The shocks are from hondatrailbikes.com. They are listed under the Z50 '79-'87 category in the frame section as "Rear Shock Set - AFT - 280mm - All Models". The pair ended up being $140 even with shipping.
Old 11-16-2012, 06:32 PM   #34
elite1
elite1's Avatar
Oddometer: 172
Subscribed
So, when does the adventure begin?
10 Triumph Thruxton - ton up bitch ; 86 Elite 150 Deluxe - pimpin' 80's icon ; 78 Puch Newport - still in the family. Still can't outrun Fido. ; 07 Elite 80 - bulletproof but boring - sold ; 82 Honda Ft500 Ascot - The lil' donkey's bed - gone but not forgotten.
elite1 is offline   Reply With Quote
Old 11-16-2012, 08:10 PM   #35
slowlane OP
slowlane's Avatar
Oddometer: 82
Honestly, I wish it was starting tomorrow. The big adventure should start in late June. I am moving from Texas to New Hampshire to work on a farm and between leaving my current job and going up there I will be taking the C70 on a long trip. At first I didn't really want to say what I have planned, didn't want to spoil the anticipation, but what the heck. The C70 and I are going to make a run at the whole Trans America Trail. I have always loved exploring dirt roads and trails and for years have wanted to take a cross country trip with this bike. Unfortunately, it's just too slow for pretty much any U.S. long distance road so my dream started to fade. Then I found out about the TAT and decided that's my chance. I have to do it. I'll be between jobs so I'll have all the time that I need and I have been saving money quite a while for "something, someday" so finances shouldn't be a problem. In the coming months I plan on taking several smaller trips on the bike on with the setup I am creating in this thread to make sure that its functional. I am well aware that the C70 is not the most logical choice of bike for the trail, but for me, I can't see using any other. After over 25,000 trouble-free miles, and with it still running as strong as ever, I am not concerned with its reliability in the least, which will be comforting on such a journey. I have traveled so many miles with the Honda that I have developed a great understanding of it and riding it is practically second-nature. I placed an order for the TAT maps a couple days ago so they should hopefully be here next week for me to start perusing.
Old 11-16-2012, 08:37 PM   #36
slowlane OP
slowlane's Avatar
Oddometer: 82
Nice. Especially nice if it has 30k miles on it! The down-tube bash plate looks great, like stock. - if they made them stock. After riding a 100cc Honda step through SE Asia I can certainly see the use of a bash plate for some types of riding - for instance, it makes sliding over logs pretty easy. Did you make a cut out for the oil drain plug? Did you have to find a center stand elsewhere? Yours is a '82, right? With CDI?
Thanks. I have always maintained it so it has held up well. I did cut out a hole for the oil drain plug. The center stand is an all OEM Honda setup from dratv.com. They carry all sorts of parts for these bikes in the U.S. Yes mine is an '82 12-volt CDI bike.
Go into more detail on what you are planning to do.
Where? Lots of dirt? How long? Far?
Bigger bore and upgraded clutch will make things easier. Just saying.....
Sorry I guess I missed your post. Yes there will be lots of dirt, rocks, and mud. I am going to attempt the full Trans America Trail this summer. I have as much time as it takes. I've considered upgrading to a 88cc piston/cylinder setup but I am tempted to just leave the bike alone even if it means helping it up the steeper sections. I'm not sure how much more power the stock bottom end and transmission can reliably handle.
Old 11-16-2012, 11:03 PM   #37
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,911
I had a Brand new Honda 50 Step through in 1967! One of the best bikes I have EVER owned and I've owned PLENTY. So reliable, so easy to ride, such a pleasure. I think It's a great choice for the TAT...why not? Everything you need should fit in or on the milk crate. Nice job on the bash plate. I applaud your efforts
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 11-17-2012, 06:57 AM   #38
bayoulubejim
Oddometer: 454
The bottom end can handle anything you throw at it.
Go 88cc,, cam , 2mm bigger carb, Upgrade or at least refresh the clutch. Leave the gearing alone.
If It was me?
Beef up clutch .Case bore it, go to 125cc,free flowing pipe, cam, and 22mm carb. Xr tank on underbone. Up one on front sprocket.
bayoulubejim is offline   Reply With Quote
Old 11-17-2012, 07:47 AM   #39
chazbird
Oddometer: 3,720
What a fun way to ride the TAT and it will be an adventure. It will probably be the ultimate test for a C70 and will equal or better, if that's the correct word, in how Nate the Postman's C110 trans Asia or the Symba underboning RTW rides tested their bikes.
chazbird is offline   Reply With Quote
Old 11-17-2012, 03:57 PM   #40
slowlane OP
slowlane's Avatar
Oddometer: 82
The TAT maps came today! Also I modified (cut up) a cheap aftermarket leg shield to fit over the bash guard. I just couldn;t bring myself to cut my original shield even though its somewhat beat up. To me a C70 is just not a C70 without that leg shield. This aftermarket shield is of very inferior quality to the original and I probably wouldn't even put it on a rider, but it was perfect to be hacked to fit my bike for the trail.
Lots of cutting to clear the bash guard tubes.
I had to trim off some of the bottom as well. This picture makes it look a lot better than in person. I'd say it fits just okay.
Old 11-17-2012, 04:05 PM   #41
slowlane OP
slowlane's Avatar
Oddometer: 82
Thanks. I really like the subtle styling differences of those '60's models compared to the early '80's Passports. My friend had a nearly mint '65 C100 that I rode a few times. It was noticeably slower than my C70 though. My C70 is easily the best vehicle that I have ever owned, cars included. With mostly just basic maintenance, it has never let me down.
Old 11-17-2012, 05:37 PM   #42
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,429
I spoke to the president of our club, the CJMC and he told me the CT90/110 are really Passports that a dealer in Boise modified for the farmers in the area as farm bikes. Honda found out the dealer was selling so many of the little bikes that they went there and found out how the dealer was modifying them. They copied the design and out came the CT90.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 11-17-2012, 06:00 PM   #43
elite1
elite1's Avatar
Oddometer: 172
So I just read up on the TAT and the author of the website suggests at least 400cc's to handle the trail. I applaud your faith in your little c70 to be able to stand up to this. If there is any small displacement bike that can do this, its a Honda Cub. Soichiro would be proud.
Old 11-17-2012, 06:40 PM   #44
slowlane OP
slowlane's Avatar
Oddometer: 82
I don't doubt that at all given some of the technology, or lack thereof, on the earliest CT's. My favorite is how instead of the dual range transmission of the later bikes, the early ones use a multi-sprocket rear wheel. There was the standard Cub/Passport sprocket and then a huge additional sprocket for hill climbing or hauling. You had to add/remove a section of chain and run on a different sprocket to switch "ranges". I love it!
Old 11-17-2012, 06:47 PM   #45
slowlane OP
slowlane's Avatar
Oddometer: 82
Thanks. Yeah that 400cc minimum makes me slightly apprehensive, but that's all part of the thrill I guess. I know there will be sections that I will have to walk the bike through or up where a bigger bike could power its way on. I don't expect to be able to cover the daily 200-250 miles that many TAT riders seem to, especially in the Western states.
Times are GMT -7.   It's 04:59 AM.
