11-16-2012, 04:22 PM
#91 |
goin' to Shaboom's!
Oddometer: 668
Model year 2012 and 2013 differences
Can anyone tell me the improvements/difference from the 2012 model year to the 2013? Looked it up, but can't find definitive info.
11-17-2012, 05:17 AM
#92 | |
Transient
Oddometer: 906
As Salty said it's a great bike, once set up for you you'll love it.
One day lad(as they look out the castle window) this all will be your's, what ?.... the curtains? |
11-18-2012, 03:30 AM
#93 |
Paulo Lança
Oddometer: 254
Loving this bike
http://www.trailaventura.com/ |
11-19-2012, 08:10 AM
#94 |
Slow Ride to Nowhere
Oddometer: 121
2011 vs. 2013
2011 vs. 2013 I was pondering the same question.
I thought the 2012 had significant motor updates.
"The Constitution? I'm pretty sure the patriot act killed it, to protect our freedoms" Bart Simpson 06 FJR1300 09 XR1200 H-D Yea I thought I never would either 75 Norton 850 E-Start Project 69 Z-50A Mini Trail with Lights & 2007 X-Challenge Heavy dirt bike sweet sweet motor |
11-19-2012, 11:15 AM
#95 |
Oddometer: 470
May I ask a question concerning the 350 EXC. I am going to buy a new KTM after I sold my 450 EXC (2010) few weeks ago.
I surfed through the internet and found several tests. It is puzzling me that the German Motorrad Magazine writes: "The 350 is easier to ride, especially for the less experienced rider. Where the 450 gets in trouble as the backwheel spins the 350 with it slower torque gets through with ease! It is just the better bike when speed is not important" I see. The Austrian Enduro magazine also compared both bikes and states: "For the less experienced rider we would reommend the 450 as it has more low down grunt and therefore chugging power. It pulls you up the hill in idle while the 350 needs higher revs and a lot of clutch action. The 350 stalls often where the 450 just chuggles and needs no clutch action. So one recommends the 350 for the less experienced rider and one the 450. I had a 450 and it was great but it steered lazy and always took the wide line. I am not an experienced offroder and I drive mainly the tough trails where you need first and second gear. So no desert blasting or 6th gear farm lane heat. Steep, slippery hills up and down and hard trails like in the vid from ADVTuga. The 500 may be the killer in faster terrain, in the real hard stuff its far to strong and torquey, that is exactly the reason why no one uses one in the hard races like Erzberg, Hellsgate or Romaniacs.... So the 500 is not what I like to have. Which one should I buy? And no I cant testride one, even here in Austria a testbike is very hard to get as its almost winter. Testrides are again planned for spring (said the dealer) but I will not wait that long... Thx Steve |
11-19-2012, 11:31 AM
#96 | |
Oddometer: 470
The 2013 has, as far as I know only the technical updates which have been installed on the 2012 models after some problems. Rubber throttle potentiometer cover, easier to replace and better fuel filter and stuff like that. And the "Six Days" bike has a new fork. Edit: the 2013 has a new designed balance shaft and a new starter and starter gear. cheers steve Steveman screwed with this post 11-20-2012 at 12:41 PM |
11-26-2012, 10:44 AM
#97 | |
Oddometer: 168
_______________________________ 2011 F800GS 2006 450EXC 2001 F650GS (Sold) 2008 WR250R (Sold) |
11-26-2012, 11:33 AM
#98 |
Oddometer: 25
had my 350 EXC-F for 1 season now
awesome bike. no problems at all i could have got the 500 no problem but i didn't because i wanted to stay light as possible. i like trails and woods and street |
11-26-2012, 12:40 PM
#99 |
Oddometer: 24
First off, love the bike. I've had it for about 2 weeks and already put 500 miles on it, most recently almost 300 in Moab for Thanksgiving weekend. That said, I had a starting (id10t error) issue I wanted to ask about.
I shut it down after a run but did not turn the key off. In a few hours, the light completely drained the battery. I figured, no big deal, I'll kick it over, do a run, and let the bike recharge the battery. First, this thing is HARD to kick over. Never once did we get it anywhere near started. So, we decided a bump start was in order. We ran it down a hill, put it in second and popped the clutch. After hearing the engine turn over more than a dozen times, sputtering the hole way, it died. At this point, I am thinking (WTF), is this a FI issue? Does it require having some battery power to start? I can't believe this is the case, since the non-EXC bikes don't have a battery, but it gets stranger... We then tossed in the towel, pulled off the seat, and jump started it. The weird thing is, it started immediately, but as soon as we removed the cables it died. We actually had to leave the cables on for a minute or two, while the bike was running, before we could remove them and it would stay running on it's own (regardless of throttle position and RPMs). It's like we had to use the alternate power source to keep the bike running until the battery had recharged enough. Obviously this is concerning for any endurance type ride, like the 170 mile desolate White Rim Trail we did while in Moab. Anyone encounter this issue? Any ideas on what I was doing wrong (and yes, the key was on the entire time)?
2013 KTM 350 exc-f |
11-26-2012, 12:55 PM
#100 |
Oddometer: 8,040
Was the headlight on? I'm not sure it's switchable off/low/hi or just low/hi on this bike? If it was on you usually need to disconnect it (behind the mask) if you want to kick over a totally dead bike. Otherwise sounds like an FI issue, the previous works on a carb'd KTM.
11-26-2012, 01:31 PM
#101 | |
village idiot
Oddometer: 831
I copied this from a memebers post @ ktmtalk....hope it explains why you had the issue. And, 2stamp, get rid of the WRR and get thsi bike...you will be happy you did! "I could not find a fix for the dead battery starting issue in the thread. If I have missed it, sorry. I did read all of peoples accounts a while back, and while attending the KTM Adventure Rally in my home town of Bend, Oregon, I had the opportunity to ask the KTM tech a few questions. Kyle (KTM Master Adventure Tech) was familiar with our dead battery plight. He mentioned he had success starting a 350excf with a dead battery with the help of a 9v battery. Yes, a 9v battery. The fuel injection system needs 9 volts to operate, and that is what prevents our FI bikes from starting. Kyle had mentioned he had come up with a design for a 9 volt/capaciter fix for the bike, and had shopped it to a few companies with no success. Kyle said that if you carried a 9V battery with some connection jumpers, you could start the bike with it. He said to idle the bike for at least 10 minutes without reving the throttle. If you rev it or turn on any accessories, it will most likely stall out. I am willing to bet there is enough room under the seat for a 9v battery and some wires. I have not tried this, but it sounds sane to me"
12 KTM 350 EXC-F 09 KLR 650 12 Genuine Stella 05 Yamaha XT225 03 Honda Goldwing GL1800 |
11-26-2012, 02:13 PM
#102 | |
Oddometer: 24
I'll post up the results, but currently my bike is at a friends, so it will be a few days. More thoughts, info, and comments welcome!
11-26-2012, 02:15 PM
#103 | |
Oddometer: 24
If the 9v trick doesn't work (see previous posts), I may try disconnecting the lights and giving it a second try. Thanks!
11-26-2012, 02:41 PM
#104 |
Oddometer: 695
I'm finding that this discussion is being repeated on a lot of threads across the ADVRider spectrum, from dirt bikes to street tourers. Manufacturers are implementing new technology faster than we are educating ourselves on how that technolgoy works, how we need to properly use it, and the consequences of new failure modes.
FI bikes have ECU's that require not only current but a consistent voltage for the ECU. This is why you can't just "jump it and go" with a depleted battery. The stator may provide enough power for the fuel pump, but without the minimum charge on the battry (or capacitor), the resulting voltage fluctuactions trip the ECU to failure mode and it shuts off to protect itself. To avoid these failure modes, either a battery or a capacitor will do, but the battery has to be in good condition (e.g. not recently totally discharged) and a properly sized capacitor needs to be fully charged. With all accessories off (e.g. headlight), 9V is the minimum, but 12V is better, with the capacitor or battery providing the "depth" to produce a stable (non-fluctuating) current for the ECU. (This means that the kick-starter also needs some "depth" or "buffer" from an electrical reservoir to provide stable current to start the bike.) One of the best discussions I've seen to date regarding the electrical requirements in somewhere in the middle of the WR250 Megathread. Bigger batteries and stronger alternators help avoid similar situations in modern automobiles, but the weight penalties for motorcycles result in compromises in the electrical system designs. The aftermarket won't pick-up on the emergency starter concept due to the liability of "hurting" the ECU. Spend some time reading other threads and see what has already been done before messing around with your bike. Google is your friend. Lithium-Ion batteries are lighter than lead-acid batteries, but they seem to have less stable current properties when stressed. Also, voltage in lead-acid batteries drops off slowly with inadequate charging; Li-Ion drops like a step function. Lots of folks are using Li-Ion to save weight; some few have had problems. Others are carrying small Li-ion battery packs as backups for their lead-acid primary batteries when riding the far reaches of beyond. Still others are wiring-in capacitors to augment their factory electrical systems. The bottom line - protect your bike's battery. With FI bikes, get in the habit of turning them off with the key ALL the time (assuming your bike has one). If you have to use the Kill Switch, get in the habit then turning off the key. Most of us don't use this procedure enough to make it a habit, but with FI / ECU sophistication come new REQUIREMENTS that need new riding habits.
1990 Honda NT-650 Hawk-GT Never doubt that a small group of thoughtful, committed citizens can change the world; indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 screwed with this post 11-26-2012 at 02:49 PM |
11-26-2012, 06:21 PM
#105 | |
Oddometer: 24
Quoting a few sections, I will definitely do more searching on the topic before doing anything. I've already had discussions and thoughts on carrying a spare, good to know others are doing this. As for the habit, I need to figure this one out... I always use the key, except when I am on an incline and want to shut it off in gear, because I am using the hand brake to hold it in place (which is what I did last weekend). Perhaps I will force myself to use the foot brake when needing to turn off on an incline and just discontinue use of the kill switch except in emergency situations. Thanks again!
