Old 11-17-2012, 08:25 AM   #1
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,478
Laugh GS "Power Controller" Discount Sale- In stock!
Orders: got Paypal? send the coins to HIGHTECHCOONASS (at) Gmail (dot) com
We have a 10 in stock the we can ship out this week at a $10 discount.
$75 plus $5 flat rate to ship in the US.
This is a power boost for all GS, smooths out the throttle response, and has been proven around the world - And as always money back guarantee!
Original vendor link......
http://www.advrider.com/forums/showthread.php?t=777887
Originally developed for the F800gs / F650GS throttle response... but now used on all BMW EFI bikes....
The problem is the bikes run to lean! - why? because of emissions tuning... the fix? give the engine a little more gas... how I do it? Tell the ECU the air temperature is lower than is actually is... Simple!
This smooths out the throttle response for the F800GS and gives the bike more HP.
It has a 2 position switch....
one position to use for 85 deg F and below ( -36 deg F temperature shift) and
another position to use when the air temp is 85 deg F and above (-18 degree F air temperature shift).
The 2 position switch can be mounted where ever the user prefers.
This is basically the same general idea as the Accelerator module and the Booster Plug sold overseas but a with a more refined fuel enrichment control when the temperature rises.
The idea of the switch : The rider may take off in the mountain mornings at 40 deg f and it may be 90 deg F later at noon riding in the desert. A -36 deg F offset to the ECU (the way the Accelerator plug works) is not need when the air temperature gets hot. Only a -18 deg F offset to the ECU is needed when the air temperature is above 85 deg f. Better control for a more precise enrichment.
The switch was a request from riders in some of the development discussions.
Good question to go over again.....
Blue position- this setting it tells the ECU that the air temperature is 36 deg F cooler than it is. The ECU enriches the fuel (on increase throttle movement and decrease throttle movement only)
Red position- this setting it tells the ECU that the air temperature is 18 deg F cooler than it is. The ECU enriches the fuel (on throttle movement only)
Less enrichment is needed when air temperature is above 85 deg F.
Steady state throttle- the O2 sensor controls enrichment!
Orders: got Paypal? send the coins to Hightechcoonass (at) Gmail (dot) com
Cost: $85 plus $5 to ship
5% of the sales to Baldy and the ADVRIDER web site!
WAL-MART guarantee - if you are not happy with the performance of the Power Controller please return for 100% refund!!!!
Step one.....
Step 2.....
Step 3....
Step 4 ....
Use sticky to stick down a base and tyrap the sensor to the "stick base"
5. Mount the switch where ever you prefer...
operations: the "red paint" on the switch is for -10 offset (above 85 deg F) away from the red paint or blue is for -20 deg c) when temperature is below 85 deg F.)
any question PLEASE send me a PM!!!!!! I check a few times a day!!!
Shipping Options
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass screwed with this post 03-21-2013 at 07:42 PM
HighTechCoonass is online now   Reply With Quote
Times are GMT -7.   It's 05:23 PM.
