Thread Tools Search this Thread Rating: Thread Rating: 41 votes, 4.34 average. Display Modes
Old 11-17-2012, 09:50 AM   #5866
dvwalker
Working to ride
dvwalker's Avatar
Oddometer: 667
usb vs main drive
I also use to install all my maps onto my 16gb SD drive. But after loosing the Montana's SD drive connection out on the trail more than once, I've since altered my map install approach. I now install CN map onto the main drive as my primary basemap, just in case the SD goes south. That way I have at least one good working map. All my other maps remain on the SD.
The ear plug in the battery compartment works the majority of the time to make everything snug, but when the going gets really rough the SD can still vib loose, hence temp loosing your map. Should mention I've only had this occur on gnarly rock infested single track type trails. When this occurs the fix is easy though, open bat compartment, re-snug the SD drive and ear plug snugger.
dvwalker screwed with this post 11-18-2012 at 08:27 AM Reason: **SD drive correction
dvwalker is offline   Reply With Quote
Old 11-17-2012, 11:37 AM   #5867
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,804
Originally Posted by dvwalker View Post
I also use to install all my maps onto my 16gb usb drive. But after loosing the Montana's usb drive connection out on the trail more than once, I've since altered my map install approach. I now install CN map onto the main drive as my primary basemap, just in case the usb goes south. That way I have at least one good working map. All my other maps remain on the usb.
The ear plug in the battery compartment works the majority of the time to make everything snug, but when the going gets really rough the usb can still vib loose, hence temp loosing your map. Should mention I've only had this occur on gnarly rock infested single track type trails. When this occurs the fix is easy though, open bat compartment, re-snug the usb drive and ear plug snugger.
You mean SD, not USB.
And this is how I keep mine in place:
"Don't play a lute to a cow" (Old Chinese Idiom)
Emmbeedee is online now   Reply With Quote
Old 11-17-2012, 11:52 AM   #5868
bighopper
Oddometer: 124
Originally Posted by Emmbeedee View Post
Mine was reading a 24 hour high of +33, on a day it never went higher than 6C.
Guess I'd better ask Garmin for a working one.
Good thing this was posted. I never checked mine as I was just using the current temp (mine was one of the first batch out of GPSCITY - Calgary). Anyway have checked it the past 2 days & I have a 45C as max & 0C as min & that hasn't changed even going on a cage ride (winter here) to verify that it does function.
Guess I'll be calling Garmin support for a replacement.
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
bighopper is offline   Reply With Quote
Old 11-17-2012, 05:51 PM   #5869
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,830
Guess I got lucky, my Tempe seems to be working correctly.
Guess what doofus, nobody reads your lame blog.
Old 11-18-2012, 06:34 PM   #5870
number9
number9's Avatar
Oddometer: 310
So, I currently have a 2720 and 60CSX and both work fine. I used the 2720 on the ST1100 for years with no issues. I got the 60CSX to use on the dirtbike in the woods and then when I sold the ST and got an FZ1 I started using the 60CSX on it as the 2720 seemed too big and blocked the gages.
I've got a Ninja 1000 now and took a few days trip this week with the 60CSX on it and the screen is too small for street use Im feeling. I am thinking of getting a Montana 600 to use on the street now.
What do you guys that have the powered cradle do about covering the contacts when you ride without the GPS? If I wired the cradle up to the bike it would be on a keyed power connection, so it would be "hot" anytime the bike is running.....if the GPS isn't in the cradle, how do you protect the contacts from getting wet and shorting out?
2000 Yamaha YZ250
2009 Yamaha YZ250
2013 Kawasaki Ninja 1000
number9 is offline   Reply With Quote
Old 11-18-2012, 06:41 PM   #5871
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,804
The Rugged Mount includes a rubber cover for the contacts. The cover is 'captive' on the mount so you can't lose it when you're not using it.
Old 11-18-2012, 06:47 PM   #5872
number9
number9's Avatar
Oddometer: 310
Ah, NICE. Thanks man.
2000 Yamaha YZ250
2009 Yamaha YZ250
Old 11-18-2012, 06:57 PM   #5873
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,804
Also, even if you forgot to use the cover, rain would not short it out. It's low voltage USB power, and nothing to really worry about. Most of the time I forget to use the cover and it makes no difference except to my paranoia.
Old 11-18-2012, 07:54 PM   #5874
guavadude
de-composer
guavadude's Avatar
Oddometer: 317
I wired my AMPS mount with an SAE to the battery unswitched so it's always hot. I've seen someone else added a switch but I imagine the Montana doesn't draw much juice and I'll always take it off the mount when stopping.
Am I missing something or is it ok to have the mount unswitched?
guavadude is offline   Reply With Quote
Old 11-18-2012, 07:58 PM   #5875
guavadude
de-composer
guavadude's Avatar
Oddometer: 317
When I'm in map mode with no navigation, is there a pref to not have the way point "pin" drop? I'm having a hard time scrolling around without dropping pins.
Old 11-18-2012, 09:01 PM   #5876
socaltrailrider
Oddometer: 75
Looking to buy a Montana this week. Best price I've found is at GPScity. Has anyone come across the Montana on any Black Friday sales?
2011 Weestrom
KTM 300XC
KTM 525 EXC
socaltrailrider is offline   Reply With Quote
Old 11-18-2012, 09:20 PM   #5877
guavadude
de-composer
guavadude's Avatar
Oddometer: 317
Got my new 650 from EMS for $439 and it came with a $15 coupon. They go fast so watch for what you want.
Should be deals on black Friday and cyber Monday from everyone.
Old 11-18-2012, 09:31 PM   #5878
eddyturn
Wannabe
eddyturn's Avatar
Oddometer: 983
Why are they selling so darn cheap? New improved model coming out after the holidays is my guess. New battery compartment that does not require an ear plug. I'm sure there are more things than that which must be fixed on V2.
All things being equal... fat people use more soap
eddyturn is online now   Reply With Quote
Old 11-18-2012, 09:40 PM   #5879
guavadude
de-composer
guavadude's Avatar
Oddometer: 317
That's actually the price they were this time last year. I think it has more to do with black Friday and EMS being competitive.
But seeing that I waited a year to buy one and got mine last week, a new model should be out any day now!
Old 11-18-2012, 10:02 PM   #5880
socaltrailrider
Oddometer: 75
I did check ems.com. The 600 is $499.99 right now. I'm going to keep an eye on the site though.
2011 Weestrom
KTM 300XC
KTM 525 EXC
socaltrailrider screwed with this post 11-19-2012 at 04:57 AM
Times are GMT -7.   It's 06:02 PM.
