Old 11-17-2012, 07:46 AM   #49066
flatfender
flatfender's Avatar
Oddometer: 769
Originally Posted by mcma111 View Post
Your going to have to remove the tensioner and shaft and test the one way clutch. Hold the shaft (by the flat at the end of the shaft) with a pair of vise grips and see if you can get the clutch to skip when pushing backwards on it. Perhaps there are wear or flat spots on the shaft that are allowing this to happen. You do know that if the chain tension is not controlled that the chain can jump some teeth and even allow the valves to hit the piston. You don't want this to happen do ya??
Okay that makes sense, if the locking mechanism fails eventually the spring will fail because it's not meant to hold pressure forever. Cam chains that jump teeth never have a happy ending, uhhem, my long gone '70 Bronco and sourjon backing down a hill in gear using the clutch are strong reminders for me.
1998 XR650L Dualsport
flatfender is offline   Reply With Quote
Old 11-17-2012, 10:45 AM   #49067
Ironman2001
Oddometer: 27
Originally Posted by Brown Falcon View Post
I don't need heated gloves... I just need gloves that go up above my jacket cuffs! It sucks having water going up your sleeve on the way to school. Plus my gloves are perforated leather, so not waterproof at all.
I need me some waterproof gauntlet gloves... but I'm a poor, unemployed, disabled vet, full-time student (and my wife won't let me buy new gloves). Sorry, I'm done wallowing in self-pity now. Now to wallow in a bottle of beer instead...
Hahaha seems you have enough money to buy beer. Make a choice... beer or gloves?
Ironman2001 is offline   Reply With Quote
Old 11-17-2012, 11:02 AM   #49068
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Hey I jumped a timing chain a '85 KLR600 back in '87 backing it down a hill doing that. I'll never forget the sound the engine made when I hit the electric start. It broke both exhaust valves and stuck them into the head...
That was my last KLR...
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
MentalGuru is offline   Reply With Quote
Old 11-17-2012, 11:03 AM   #49069
bomber1965
Duel
bomber1965's Avatar
Oddometer: 2,197
Originally Posted by purpledrake View Post
About $30 bucks ........they are stainless steel and poly.....stick them in a saddle bag and forget about them till needed.......put them away wet no problem, those others you posted would be all rusted and corroded.
Hey Bomber, that pulley in the camo bag is really slick. Where did you find this? I want one.
PD
Features:
Stainless Steel Made
4 Sealed 1 1/4" Roller Bearings
100FT heavy Duty Rope
Come with Comouflage Carring Bag
1 Ton Capacity
http://www.ebay.com/itm/Stainless-St...-/370634497502
bomber1965 screwed with this post 11-18-2012 at 07:16 AM
bomber1965 is offline   Reply With Quote
Old 11-17-2012, 11:25 AM   #49070
Brown Falcon
Mossy-Back
Brown Falcon's Avatar
Oddometer: 709
My wife is okay with me buying beer (a little at a time). Not so hot on the expensive gloves all at once. I moved my controls around a bit and I can use my snowboarding gloves now. Problem solved (for now).
Evan
Ooh-Rah! Once a Marine, always a Marine!
'93 XR650L (Xena)
Brown Falcon is offline   Reply With Quote
Old 11-17-2012, 12:17 PM   #49071
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 3,318
Originally Posted by ShooterDave View Post
How on God's green earth are you able to drain it from the main lug without getting it all over the place. If you remove the bolt slightly and leave it there, it sprays all over the place. I never once was able to do it without it getting all over the skid plate. Ok, well ALL OVER is an overstatement. It would always end up on the skid plate, a lot more than I would like. When I finally took the skid plate off.... it was an oily, gunky mess. It was so annoying that with the new skid plate I got for my other bike, I didn't care that it didn't have an oil hole. This skid plate is the best protection ever.
I need pics / video or it ain't true dude.
Tis true,no mess,no fuss......no video till spring.......though i do think it`s comical me making a video to instruct on oil changes on sumpin as basic as the LPIG
B
01 XR650L,102mm JE 11.25:1..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
techforlife is offline   Reply With Quote
Old 11-17-2012, 01:37 PM   #49072
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 810
Different animals.
Thanks Steve, Ya I thought that they were different.
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 11-17-2012, 03:35 PM   #49073
ReferJohn
Behind Bars 4 Life
ReferJohn's Avatar
Oddometer: 198
2 ?'s
with Flatfenders recent timing chain issues i now am riding paraniod-kind of.
1. what causes a timing chain to jump? besides backwards motion in gear.
and how can i prevent that?
2. what are the symptoms of a timing chain that has been jumped
will the L still lift the front wheel in 2nd and 3rd and perform the same or will you be able to detect it right of way.
Thanks for helpful insight and advice
John
'01 XR650L
'06 NPS50
'12 FLTRU
ReferJohn is offline   Reply With Quote
Old 11-17-2012, 04:49 PM   #49074
Ironman2001
Oddometer: 27
Question I have a suspension question
How does one tell if the suspension in my bike is stock or modded? I think the springs might have been changed to stiffer ones but can't really tell.
Thanks, Rob
Old 11-17-2012, 05:18 PM   #49075
my6
my6's Avatar
Oddometer: 238
If memory serves me there will be different colored stripes painted on one end of the shock spring. What colors mean what I can't say. The fork springs you will need to remove and take a couple of pics of for the more learned here to see.
Check your Six
94 XR650L
"Hellbitch"
my6 is offline   Reply With Quote
Old 11-17-2012, 06:19 PM   #49076
beechum1
beechum1's Avatar
Oddometer: 4,818
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
Springs over the years were different colors. you'd have to test the displacement with weights to get an accurate assessment .
Sent from my GT-S5360L using Tapatalk 2
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
Old 11-17-2012, 07:24 PM   #49077
Brown Falcon
Mossy-Back
Oddometer: 709
Yep. Pretty sure my '93 has a stock spring and it's red. My friend's '03 has a yellow spring that's stock.
Evan
'93 XR650L (Xena)
Old 11-17-2012, 08:43 PM   #49078
ReferJohn
Behind Bars 4 Life
ReferJohn's Avatar
Oddometer: 198
John
Just want to keep this fresh and not get burried....... GURU's feel free to provide help please
'01 XR650L
'06 NPS50
'12 FLTRU
Old 11-17-2012, 09:25 PM   #49079
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 1,816
I'm not a guru but I had timing chain issues. All from a rebuild I did trying to save the budget. The chain was stretched and it allowed it to skip a couple teeth when I used the clutch to brake as I rolled backwards on a hill I failed to clear. It wasn't enough to damage the motor when I tried to restart but it was enough that the bike wouldn't start and run. New chain installed and I've used the clutch getting off the trailer several times no problem.
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 11-18-2012, 07:01 AM   #49080
mcma111
mcma111's Avatar
Oddometer: 7,989
John
Since I am at work I have plenty of time to reply to your inquiry.
This is based on my '91 XR600. I used to go riding in Mendocino National Forrest and there were many times that I would get stuck going up a hill and I would walk the bike back down using the front brake and also the clutch while the bike is in gear. I would have both feet on the ground as to not fall over so the in gear/clutch bit was actually the rear brake. I can remember letting the clutch out and the engine winding backwards and I never had a problem with the cam chain jumping no matter how I punished this bike.
Now as to the why and how of a jumping cam chain. It all comes down to the tensioner. The tensioner has a one way clutch in it. If the clutch rollers develop a flat spot or the shaft is worn then there is the possibality that the tensioner will not be exerting pressure on the chain guide and under certain conditions the chain can jump or skip on the cam gear. How to prevent this from happening?? Don't ride your bike. If you ride your bike you wear out parts. No ride = No wear. Simple.
Same bike. Now as to having the cam out of time. A couple years ago the engine did the standard oil starvation bit after an oil change. Upon tear down I found that the last time I was in the engine I had installed the cam one tooth advanced. The bike always started up just fine and had loads of power so what does this mean? It's a friggin HONDA!!! If the cam is advanced you get the cam timing coming in more on the low end. Retard the cam timing and you get more top end. Change the cam timing a bunch of teeth as in a bad tensioner/chain skipping and you get valves that are hitting the piston.
There you have it. Send BEER.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
mcma111 screwed with this post 11-18-2012 at 07:36 AM
Times are GMT -7.   It's 12:19 PM.
