Old 11-11-2012, 10:40 PM   #16
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 492
The Mr. Gasket pump has worked at our auto shop for a couple of years. Not one toasted marshmallow to date. But, I'm not the kind of dipshit that would hook up the wires right next to the end of fuel line . . .
If your gonna be dumb, you gotta be tough
When you get knocked down you gotta get back up,
I ain't the sharpest knife in the drawer but I know enough, to know,
chollo9 is offline   Reply With Quote
Old 11-12-2012, 04:05 AM   #17
AdventureDave
MMMMM Bundy!
AdventureDave's Avatar
Oddometer: 658
jiggle syphon
dont you guys have jiggle syphon's?
https://www.whitworths.com.au/main_i...135&item=67399
cheers
David
whoops just reread OP "Something of a suitable commercial level not cheapo auto supply" mybad. disregard above suggestion.
AdventureDave screwed with this post 11-12-2012 at 04:22 AM
AdventureDave is offline   Reply With Quote
Old 11-12-2012, 07:25 PM   #18
racer1735
Oddometer: 293
I use a transfer pump from Harbor Freight. Don't laugh, its inexpensive and does the job. I use it to empty the tank down to a minimal amount, then I'll remove the transfer hose, disconnect one end of the fuel line from the petcock, and drain the remainder of the tank that way (smaller diameter hose takes longer to drain). For fuel injected bikes, drain a bit further with the transfer pump, then start the engine and run the tank dry (I don't do this too often as I don't like the fuel pump running dry).
As far as the transfer pump, just put a light grease or some oil on the pump shaft. That will keep things lubed and operating properly.
One cylinder (my XL) or four (my ST)? That is the question.
racer1735 is offline   Reply With Quote
Old 11-12-2012, 08:31 PM   #19
the_gr8t_waldo
Oddometer: 1,850
well, i'll be damned!! today at work a buddy just had to show me his new commercial grade siphon http://www.grainger.com/Grainger/DAY...rum-Pump-4HA27 who'da thunk?
the_gr8t_waldo is online now   Reply With Quote
Old 11-18-2012, 04:49 AM   #20
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 6,730
Send a message via AIM to HaChayalBoded
I used that siphon pump from harbor freight to change the oil in 30 generators recently. Works well, didn't spill much. And they are like $5
Eddie
Stuff FS
'00 Harley MT 500
'93 Concours, extreme farkle (for sale)
'00 Shadow ACE Tourer (for sale)
'03 Shadow Sabre (Gone)
'90 Honda Hawk GT NT650 (Gone)
Lookin' for a (cheap) '95 GSPD Classic
I've been stranded in the combat zone
I walked through Bedford Stuy alone
Even rode my motorcycle in the rain!
HaChayalBoded is offline   Reply With Quote
Old 11-18-2012, 04:50 AM   #21
HaChayalBoded
Brooklyn Bored
Oddometer: 6,730
You can also use a pump that goes onto a 55 gallon drum and chop the tube down to whatever size you need.
Eddie
Stuff FS
'00 Harley MT 500
Old 11-18-2012, 11:25 AM   #22
davsato
Oddometer: 753
the fuel hose on my honda is 10mm and draining it through the petcock is NOT slow! as i found out when i recently took the tank off to change the air filter, shut the petcock, pulled the hose off and got a face and lap full of fuel. oh yeah, my bike has one both sides joined by a bridging tube, forgot that! and twenty litres of fuel gives it a lot of head too!!
Dave
davsato is offline   Reply With Quote
Times are GMT -7.   It's 12:44 PM.
