11-18-2012, 09:19 PM
#16 | |
Oddometer: 4,539
You can pop a shield, wash out the grease, oil and put the shield back in. But really, it is plenty close with them in. I never feel a shake Rod |
11-18-2012, 09:57 PM
#17 |
Oddometer: 442
psh make your own. I made this out of wood lying around.
04 KLR 650 07 KLR 650 06 sv650s 07 Ducati Monster |
11-28-2012, 07:00 AM
#18 |
No Marks....
Oddometer: 1,610
11-28-2012, 11:22 AM
#19 |
Oddometer: 2,187
I use 1/2" round stock with a magnetic torpedo level hung from it, pretty simple. No point in over thinking this shit eh? I have my favorite tires like everyone and when chainging like for like it pretty much never changes.
07 SE PG007 "Up there where you eat moose-cock you must all be rockets scientists." |
11-28-2012, 01:11 PM
#20 | |
No Marks....
Oddometer: 1,610
Seriously does not matter a hell of a lot. First time you hit a BFR it changes anyway! Only the Starbucks crowd agonizes over wheel balancing |
11-28-2012, 04:26 PM
#21 |
Boring Old Fart
Oddometer: 814
Did something similar for my DL1000. Made some quick & dirty uprights, far cruder than the pic above, with 90 degree "V" notches rather than round holes. Then I bought an 18" piece of 20mm shaft stock and a pair of open 20mm ID bearings from McMaster-Carr. The bearings rest in the notches.
Wheels are balanced with MotionPro stick-on weights to higher speeds than I care to push the Strom - all is good.
"I don't want a nickel... I just wanna' ride my motor-sickle." Arlo Guthrie |
12-02-2012, 09:31 AM
#22 |
Unwounding
Oddometer: 4,323
I just bought the HF one, nice enough piece.
I had just tried Dyna Beads and after swapping tires on/off and testing the beads, the weights and nothing I'm convinced that nothing is just fine. I can't find a difference between any of them. My front wheel took 3/4 oz and I can remove it with no effect at all up to 100 MPH. |
12-04-2012, 05:54 PM
#23 |
Oddometer: 582
I dont balance my dirtbike tires, USUALLY. unless its a dualsport. My sportbike tires are a different story, hence the thread;)
2005 Ninja 250 -WTT or WTS $2400 OR KLR650, TU250, W650..sportbikes, naked bikes...whatever... |
12-04-2012, 06:27 PM
#24 |
Oddometer: 575
Got the Marc Parnes too and am very happy with it, nice workmanship
RIDE ON |
12-06-2012, 11:25 AM
#25 | |
Castle Anthrax
Oddometer: 1,188
There are crap tools that just get thrown around. Then there are others that I depend on for good accuracy and look/feel right for the job. MP balancer is one that I like to take out of the box and use. |
12-07-2012, 07:37 AM
#26 | |
Oddometer: 745
![]() this is going to be one fantastic day.
Crazy_Dave just made it into my sigline, and I agree: I fall down alot. |
12-07-2012, 10:02 AM
#27 | |
Oddometer: 67
12-09-2012, 10:43 AM
#28 |
Alps Adventurer
I can understand that. Why pay for substandard work?
I built one similar to the one in your link for under $30. It acts as a wheel balancing and truing stand. I used precision Swiss bearings without seals (you ought to see this thing resolve), some sheet metal that I sheared and bent for the base and 1"x 3" tubing for the uprights. It was nicely TIG welded. There was no way I was going to let anybody change my tires and nick a rim, so why stop there. ![]() BTW, balance your wheel rim by itself just to find the heavy spot. Then install your tire accordingly.
All the best, Alex Euro & North American Travel & Technical Stuff for the R1150 GS & Adventure Euro & Alps Motorcycle Tours - Priced Right, How to go about Great spirits have always encountered violent opposition from mediocre minds.....A. Einstein |
