Old 11-04-2012, 05:57 PM   #3481
Ailkel
Chickie
Oddometer: 7
Good troubleshooting. Hopefully the used switch will work out without the need for any mods. After all all vehicles run on used parts.
Sent from my Motorola Electrify using Tapatalk 2
Ailkel is offline   Reply With Quote
Old 11-04-2012, 07:32 PM   #3482
AZbiker
Crunkin' with crackers
AZbiker's Avatar
Oddometer: 6,949
Originally Posted by Purcell69 View Post
The "start" button is bad. I picked up a momentary switch from the auto parts store and wired it in to the right switch harness. The bike starts and runs perfectly again. I just need a more permanent solution, since this switch is not weather proof. I bought a used right switch assembly on E-Bay that will get me back to OE, but it's still almost 30 years old. I am thinking about trying to install the starter push button from a newer Nighthawk in the 1985 assembly. At least then I would have a new switch.
-Joe
Would probably be better to go with new(er) switchgear if possible. My HawkGt had a killswitch from a Duc and a 1/4 turn throttle. 1/4 turn throttles are FUN.
rubber side down,
derek
http://azbiker.smugmug.com
Got SmugMug? If not, save some cash and use my code: McYdbycdcvM5Q
AZbiker is offline   Reply With Quote
Old 11-19-2012, 07:12 AM   #3483
njpaddler
njpaddler's Avatar
Oddometer: 142
700S starting woes
The Run/Stop switch is in the "Run" position and does not get used.
That, my guess, is the problem. If it never moves, never gets used, likely the contacts are corroded and not passing current through. Using it keeps it clean.
I'd take it apart and first check it with a meter before doing anything else, then clean it thoroughly.
njpaddler is offline   Reply With Quote
Old 11-19-2012, 11:51 AM   #3484
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Location: Moving forward...at the speed of rust in mid-OK
Oddometer: 3,720
The "Start" button was worn out. Cleaning it did nothing, but I was able to resolve the issue with a $5 momentary switch from the auto parts store, wired in place of the "Start" button. It is not weatherproof, but it's getting the job done for now.
I have purchased a used right side switch assembly, which hopefully has a good "Start" button. I am considering getting a new right side switch assy. from a later model Nighthawk, either to see if I can fit teh "Start" button from the new assembly into the old housing, or just use the new gear as-is.
-Joe
The Marines...When it absolutely, positively has to be destroyed overnight.
Trust and Respect take years to earn, but can be lost in a moment.
Life's too short to hold a grudge. -Joe
Purcell69 is offline   Reply With Quote
Old 11-20-2012, 08:36 PM   #3485
jimmycorp
adventure lurker
Oddometer: 179
Nighthawk 700S for tallish guy?
Hey guys, new guy and recent lurker here. Taking my MSF next week and thinking of getting an 84 700s for my first bike. I'm 6'2 and 270, wondering if this bike would be a good fit?
jimmycorp is offline   Reply With Quote
Old 11-21-2012, 06:27 AM   #3486
njpaddler
njpaddler's Avatar
Oddometer: 142
Thumb New & tall
jimmycorp,
Absolutely. I bought a 1985 650 as my first bike & I'm 6'3". I still have it. I also bought a 1984 650, and I still have it, too, if that answers your question ...
njpaddler screwed with this post 11-21-2012 at 06:32 AM
Old 11-21-2012, 10:12 AM   #3487
RABBIT170
CB750 Adventurer
RABBIT170's Avatar
Oddometer: 111
41mm forks
So whos going to be the first to instal the 41mm Dual Disc Brakes Forks/Rim off the new CB1100 onto a Nighthawk 750?
current
2014 Honda Grom 125
1999 Nighthawk 750
2002 Nighthawk 250
RABBIT170 is offline   Reply With Quote
Old 11-21-2012, 01:22 PM   #3488
jimmycorp
adventure lurker
Oddometer: 179
jimmycorp,
I'm assuming this is smaller physically than a 700s?
If so thanks for the input!
Sent from my SPH-M820-BST using Tapatalk 2
Zero f*cks given
Old 11-21-2012, 07:50 PM   #3489
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Oddometer: 3,720
The S is a great bike. I've been riding for 36 years now, mostly what is now considered "Dual Sport". I picked up a gently used S this May and I absolutely love it. Around town, at 6k RPM and below, it is very well mannered. When you open the throttlewide and she hits 7k, the bike begins to accelerate very rapidly, this happens again as you pass 9k. Save that for a time when you have more experience and lots of open road ahead.
The 1985 CB650 is dimensionally almost exactly the same as a 1984-1986 Nighthawk S.
-Joe
Old 11-22-2012, 06:03 PM   #3490
jimmycorp
adventure lurker
Oddometer: 179
-Joe
Thanks for the input! Going to check out an S in a couple weeks, once I do my MSF course. Wish me luck!
Old 11-22-2012, 08:39 PM   #3491
Purcell69
Mors ex Tenebris
Purcell69's Avatar
Oddometer: 3,720
Obviously, best of luck with the course. This has to be the most meaningful money you will ever spend on motorcycling. Protective gear is great and has its place, but riding smart is the best plan of all.
In your spare time, you may want to take a look at www.nighthawk-forums.com. There is a lot of good info there, much of which pertains to the CB700SC, aka Nighthawk S. It can give you some idea of what to look for in a used S and what to stay away from. I'm not affilated with that site, I just stumbled across it while searching for info on my '85 S. That board doesn't see that traffic that ADV does, but the members are pretty helpful just the same.
-Joe
Old 11-23-2012, 06:35 PM   #3492
drdubb
OFWG
drdubb's Avatar
Oddometer: 386
Nighthawk forums.com
Can't beat that forum for nighthawks. You can find the answer to almost any problem.
'06 DR650 - Suzuki
'95 750 Nighthawk - Honda
'83 650 Nighthawk - Honda
'71 SL 350 - Honda
drdubb is offline   Reply With Quote
Old 12-04-2012, 05:12 PM   #3493
jimmycorp
adventure lurker
Oddometer: 179
Hey Guys,
Finally did my MSF course and git my license, will be going up to get the Nighthawks next week.
jimmycorp screwed with this post 01-10-2013 at 10:14 PM
Old 12-05-2012, 05:56 AM   #3494
Lulu7404
Oddometer: 273
Nighthawk for sale
Hey everyone. My wife is selling her CB250 Nighthawk. Little guy isn't seeing much action since she started riding dual sport. Here is the thread.
http://www.advrider.com/forums/showthread.php?t=845782
14 Triumph Tiger 800
13 KTM 350XCF-W -- new hotness
13 KTM 250XCF-W -- hers
Lulu7404 is offline   Reply With Quote
Old 12-31-2012, 09:42 AM   #3495
genespleen
genespleen's Avatar
Oddometer: 163
Hmmm...I guess I'm really just bumping up the thread.
genespleen is offline   Reply With Quote
Times are GMT -7.   It's 12:12 AM.
