Old 10-25-2012, 03:41 PM   #136
William42
William42's Avatar
Oddometer: 3,163
Originally Posted by jaumev View Post
ARGGGGGG!!!
Please William, send it to me and I can do some proper ones... these are not suitable for such a nice bike!!!
Come on... now I teach you how to do it... not so difficult!!
But jaumev, mine are even uglier in real life than in the pics.
Mud is evil
William42 is offline   Reply With Quote
Old 10-26-2012, 03:06 AM   #137
tremor38
tremor38's Avatar
Oddometer: 1,470
Well... that’s the first ting I tried, I connect the blinkers without the MUST BE USED boxes and I understood why there is this advice: the blinkers where ruined.
So I recommend you if you read a MUST BE USED advice: USE THEM
LOL! Sorry to hear that....hence if you had checked the output of the boxes, and it was less than 12v, U would have had the answer and would not need to proceed to the risky test.
2011 Yamaha XT1200Z
tremor38 is offline   Reply With Quote
Old 10-30-2012, 03:30 PM   #138
jaumev OP
jaumev's Avatar
Oddometer: 1,520
Yeah... I know... I'm useless in electric things....
(lucky the blinkers where in guarantee....)
jaumev is offline   Reply With Quote
Old 10-30-2012, 03:33 PM   #139
jaumev OP
jaumev's Avatar
Oddometer: 1,520
So... no shame!!: SENT IT TO ME!!!
Old 11-19-2012, 05:05 AM   #140
jaumev OP
jaumev's Avatar
Oddometer: 1,520
At last!!
I have the 21” front wheel so we can start to build the front fender brackets and looking where relocates the horn. Next monday I hope to have the new metallic brake lines and start with the centre and side stands.
It looks great, I’m anxious to try it!!!
Old 11-19-2012, 05:06 AM   #141
jaumev OP
jaumev's Avatar
Oddometer: 1,520
Friday I was in the manufacturer (Uni Racing) to collect the new decal kit for the ST. I asked for a vinyl to protect the windshield from scratches when I ride in the forest, this is the result:
Is the same material we use to make the side tank protections. Very strong.
They also develop some rim protections
Old 11-19-2012, 06:20 AM   #142
jaumev OP
jaumev's Avatar
Oddometer: 1,520
I have the bike at the dealer and was at home without work (wife was busy!! ) So I've been doing some holes in the boring plastic cover on the right.
So far I've done one but I think I'll add another ....
Old 11-21-2012, 06:04 AM   #143
jaumev OP
jaumev's Avatar
Oddometer: 1,520
Did it!
Old 11-21-2012, 06:29 AM   #144
GB
Mod Squad
GB's Avatar
Oddometer: 57,130
Nice setup
Any plans to add the under the seat 10 liter fuel tank? If yes, please give us a pictorial
Old 11-21-2012, 06:40 AM   #145
jaumev OP
jaumev's Avatar
Oddometer: 1,520
Originally Posted by GB View Post
Nice setup
I don't think so.
I need more range only once a year and could have less expensive provisional options.
Old 11-21-2012, 07:10 AM   #146
omroizo
Oddometer: 7
Did it!
Hey jaumev.
I was thinking to do the same to open hole to the right panel and make it to look just like the radiator panel.
But then i realize that maybe i will cause problem with the electronics of the ST that they are located under the right panel.
Is there any way to make them waterproof???
omroizo is offline   Reply With Quote
Old 12-01-2012, 02:51 PM   #147
jaumev OP
jaumev's Avatar
Oddometer: 1,520
Originally Posted by omroizo View Post
Hey jaumev.
Hi omroizo, sorry I didn't see your post before.
In the interior of the grid I glued a plastic piece to close the hole, so it still "waterproof" like the OEM.
Is the same Yamaha does in the Worldcrosser version.
Old 12-01-2012, 03:20 PM   #148
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,492
Couldn't you just get a grill sticker?
pluric is offline   Reply With Quote
Old 12-01-2012, 03:42 PM   #149
jaumev OP
jaumev's Avatar
Oddometer: 1,520
Old 12-01-2012, 04:07 PM   #150
jaumev OP
jaumev's Avatar
Oddometer: 1,520
The modifications to fit the 21” front wheel are finished. It was a long work but the dealer make a very good job:
We use the OEM hubs to keep the ABS and TC that I love. I also like the low OEM front mudguard so we need to make some longer brackets to rise it.
Next step was a new brake line to avoid the one fixed on top to the mudguard. Now there is one to each front brake. Finally we decided to change the complete system, so all the lines are metallic now.
I had to take off the grid fixed under the front light. I like it a lot but with the new wheel there isn’t enough space when the front suspension is in full compression. Instead I fixed some aux lights that I’ve already had.
Next problem, the wheel doesn’t fit with the big ACD skid plate. They modify it but the wheel still touch in it in full compression, we need to work on it.
We enlarge the centre stand 4cm just cutting and welding. The side stand has an extension I can replace for the OEM end with a single screw.
We bend the centre stand to be closer to the bike. As I have the dual exhaust It could closer than with the OEM exhaust.
To balance the bike, there is a new enlarged suspension but it wasn’t enough so we need to have new links.
Now the bike is 3cm higher than the OEM. I’m not very tall so I had to modify the seat to reach properly the ground. The new shape and a non slide material on top also avoids slip forward as in the OEM seat.
I’m very pleased with all this mods. With the 21” wheel and the upgraded suspensions this bike is a beast. It has lost a bit of stability in highway at high speed but in slow windy roads it’s even better than before. Overall loss is minimal.
In off road is impressive, really agile and balanced. More technical is the track better it works, is really fun!!.
Also with the better ground clearance is difficult to hit the skid plate.
jaumev screwed with this post 12-02-2012 at 01:16 AM
Times are GMT -7.   It's 06:57 PM.
