Old 11-17-2012, 04:11 PM   #1
henrymartin OP
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,715
Rear Shock for KLR250?
I'm looking for an upgrade to my rear shock, KLR250. The stocker is now like a pogo stick.
My Google-fu is probably not working because I can't find anything except replacing it with a KLR650 stock shock.
henrymartin is offline   Reply With Quote
Old 11-18-2012, 04:10 AM   #2
OldPete
Be aware
OldPete's Avatar
Oddometer: 5,675
i found the thread in thumpers forum...read it or search it yourself.
http://www.advrider.com/forums/showt...ghlight=klr250
OldPete is online now   Reply With Quote
Old 11-18-2012, 03:19 PM   #3
emti
Oddometer: 278
The KLR 650 shock is the cheapest solution, I tried a used 250 shock from ebay and got screwed. The 650 shock fits ok, need to enlarge one hole, and fiddle withe carb boot/airbox fitting. emti
emti is offline   Reply With Quote
Old 11-18-2012, 06:53 PM   #4
henrymartin OP
Mr. Tourguide
Oddometer: 3,715
I'm familiar with the thread, but didn't find what I was looking for. Some people mention KLR650 shock, other than than I found one shock for $600ish.
So, did you have the 650 shock on yours? How does it work for you? Any changes to the front springs to compensate for the stiffer rear, or did you leave your front stock?
I love the little KLR for woods riding, I just don't want to bounce around too much
Old 11-19-2012, 07:49 AM   #5
beergut
Thumper
beergut's Avatar
Oddometer: 414
Call Rick at Cogent Dynamics.
My KLR
beergut is offline   Reply With Quote
Old 11-19-2012, 08:37 PM   #6
henrymartin OP
Mr. Tourguide
Oddometer: 3,715
Are his shocks better than the Hagon? Asking because there is about $200 price difference.
Old 11-21-2012, 03:10 AM   #7
emti
Oddometer: 278
It lowers the rear of the bike about an inch or so I just raised the forks an inch to match .Still have the stock front springs. I dont have a better dirt bike to compare it to but it seems ok within the expectations of a KLR 250. For some reason afternarket shocks are expensive. My only issue is/was getting a good seal withe carb to airbox boot. emti
Old 11-21-2012, 12:46 PM   #8
henrymartin OP
Mr. Tourguide
Oddometer: 3,715
Thanks.
I started looking at the Hagon shock, but yeah, it's expensive. Maybe it would be easier and cheaper to find a proper dirtbike shock in the same length and then have a machine shop modify what needs to be done.
KLX250 shocks seems much cheaper on fleebay and the bike weight/power is just about the same.
Old 11-21-2012, 01:47 PM   #9
B.Curvin
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,748
This
I am not familiar with the quality of Hagon, but Ricks stuff is top shelf. I can tell you for sure that Cogent Dynamics shocks are 10X better than a progressive. I won't use anyone else.
Nuke Gay Whales for Jesus.
Porsche Audi VW
B.Curvin is offline   Reply With Quote
Old 04-22-2013, 04:11 PM   #10
seekerhiker
Starbuck
seekerhiker's Avatar
Oddometer: 46
Thumb Put in the 650 shock
I have instructions on installing a KLR650 shock in the KLR250 here - http://youtu.be/k6xwxYsuIOQ
The man who can make the pin replacement/sleeve/adapter is Ian Smith at MotorSmith:
8 Wicket Street
Unit 8
Pine Meadow, CT
860-751-9026
fellesh@yahoo.com
seekerhiker is offline   Reply With Quote
Old 12-05-2013, 02:55 PM   #11
Dominic49
Oddometer: 29
I just did the same swap on my bike without having to order any custom parts (factory pieces off the klr650 will cure the hole being to small issue.) Off the shelf bolts and spacers. (the head of the 650 bolt had to be shaved down a little to clear the dog bone.)
I also swapped the 250 spring on to the 650 shock as it is a slightly higher spring rate.
I did however decide to make a new upper link to take care of the intake boot clearance issue and the height issue. (optional)
Dominic49 screwed with this post 12-05-2013 at 03:16 PM
Dominic49 is offline   Reply With Quote
Old 11-15-2014, 09:26 AM   #12
rube
Oddometer: 103
KLR650 shock on a klr250
Dominic,
Thank you for the part numbers and photos.
What did you use for the sleeve for the extension link (shackle) you built?
I'm getting ready to do this swap on my klr250 and like you extension link solution to avoid the compression on the carburetor boot.
Thanks again,
rube
rube is offline   Reply With Quote
Times are GMT -7.   It's 06:38 AM.
