11-19-2012, 12:20 AM
#5881 | |
Tinkerer
Oddometer: 166
I did something similar to your SAE connector arrangement using one of our (3BR Powersports) Baryl connectors between the cradle and the dash.I shortened up the cable a bunch between the cradle and the "Y" and again between the Y and the plug. I left the audio cable full length. The Baryl connector is more weather resistant than the SAE but if it is up on the dash it probably doesn't make any difference. ![]() You can see how short the cable is between the Y and plug in this view.
11-19-2012, 01:55 AM
#5882 | |
Professional Trail Rider
Oddometer: 1,723
I measured 8 ma draw from the rugged mount when my Montana is in the rugged mount and is turned off and my bike's ignition is switched off. I measured no draw from the rugged mount when my Montana was removed from the rugged mount. I use non-rechargeable lithium AA batteries in my Montana for those rare instances when I want to use my Montana and it is not in the rugged mount nor connected to my iMac. |
11-19-2012, 03:06 AM
#5883 | |
Procrastinators
Oddometer: 5,796
Here's an example:
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
11-19-2012, 06:55 AM
#5884 |
Criminal
Oddometer: 80
Latest Firmware Rugged Mount issue
I've just updated to 4.60 and now when I power down my unit in the (Still Powered) rugged mount, the screen image gets corrupted. I can repeat this issue. Anyone else able to repeat this bug?
-Coop 2012 R1200GSA Triple Dirt If the army still used flame throwers, I'd have never left. |
11-19-2012, 07:08 AM
#5885 |
OX Ambassador
Oddometer: 419
How so? Can you snap a quick photo of the corrupted screen?
11-19-2012, 07:13 AM
#5886 | |
Oddometer: 75
. Ordered and on its way!
2011 Weestrom KTM 300XC KTM 525 EXC |
11-19-2012, 07:42 AM
#5887 |
hook-em
Oddometer: 488
yeah, I think they've had that price going for a while, great deal. I'm waiting until black friday or about, hoping to get the best deal.
Indecision always goes to the left... '09 BMW R1200GSA '09 KTM 950SER Erz |
11-19-2012, 07:45 AM
#5888 | |
Oddometer: 198
11-19-2012, 07:55 AM
#5889 | |
Long Haul Adventurer
Oddometer: 3,178
![]() Cheers,
Cheers, Dan |
11-19-2012, 07:57 AM
#5890 | |
Oddometer: 3,178
Cheers,
Cheers, Dan |
11-19-2012, 08:57 AM
#5891 | |
Tinkerer
Oddometer: 166
11-19-2012, 09:01 AM
#5892 | |
Oddometer: 1,435
It looks like everyone goes with the rugged mount? I'm going to try and standardize on just the Montana. I've had a 60CSx on the 650, and a 2730 on the 1200. I'm not tech enough to keep up with both. (I really can't keep up with either.) ![]() Is there a "getting started with a Montana" thread somewhere? This is like 5 million pages.. Thanks, Jeff
IBA#32778 2008 R1200GSA 2007 G650XChallenge No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..) |
11-19-2012, 09:09 AM
#5893 | |
Deputy Cultural Attaché
http://garminmontanagpsr.wikispaces.com/
Successfully surviving motorcycling since 1976. |
11-19-2012, 09:12 AM
#5894 |
Grizzly herder
Oddometer: 1,043
Mine did that as well. There is always the next endless update to fix that.
http://www.advrider.com/forums/showthread.php?t=595530 http://www.advrider.com/forums/showthread.php?t=702314 Uhaul, it's part of the KTM experience. 09 KTM 990 Adv |
11-19-2012, 09:20 AM
#5895 |
de-composer
Oddometer: 317
There's a Montana FAQ linked on Embeedee's sig.
The rugged mount is the way to go. Not sure about everyone else but on gpscity.com someone posted pics and a ram mount parts list using the 1.5" balled larger ram parts. I went with this and it seems like the way to go. It's very stable and easy to lock down. Lots of options for mounting depending on your bike and where you want it. I got the 2013 NT map DVD and Amps mount from gps4us.com since gpscity was out of mounts. Seems there's an issue with the torx locking screw on some mounts and they were recalled, so confirm availability on that. Honestly I'm not sure you need the garmin maps. The OSM maps are free, routable and seem to be more detailed. I'm a noob but am using these maps so maybe I'm missing why the garmin maps are better. What I REALLY want are the Mapquest OSM terrain (not topo) maps but I haven't found a download for them yet or if a downloadable version exists. |
