Old 11-19-2012, 12:40 PM   #1
SRG OP
SRG
SRG's Avatar
Oddometer: 1,319
Heat Shield Clamp
I'm looking for hose clamps w/ an attachment point/nut to use holding on a self made heat shield. Something like the ones shown here:
http://www.motorcycle-superstore.com...at-Shield.aspx
All I want is the clamps - anyone got a source?
SRG is offline   Reply With Quote
Old 11-19-2012, 01:13 PM   #2
scapegoat
Pushin forward back
scapegoat's Avatar
Oddometer: 2,899
Adjustable band brackets...cant find anything to fit smaller the 4" posts though.
Reality is merely an illusion, albeit a very persistent one.
scapegoat is offline   Reply With Quote
Old 11-19-2012, 05:15 PM   #3
SRG OP
SRG
SRG's Avatar
Oddometer: 1,319
Some more searching and I found Flatland Racing sells these:
http://www.flatlandracing.com/Mercha...Code=Universal
Old 11-21-2012, 02:40 AM   #4
rjsurfer
Oddometer: 207
Use these type of nuts with a standard large hose clamp that can wrap around the exhaust can.
http://www.dormanproducts.com/catalo...ec20_Part5.pdf
Go to the 8th line down and you can see what I'm talking about, you can get them at Lowes or HD in the hardware dept,
You can slide the tab of the nut under the hose clamp to hold it then you can make your own heat shield up and mount it with matching sized bolts or screws. Length of bolt or screw is critical.
Ron W.
DRZ 400SM
DL-650 Gone but not forgotten
rjsurfer is offline   Reply With Quote
Times are GMT -7.   It's 12:50 AM.
