Old 11-19-2012, 02:24 PM   #31591
leftystrat62
leftystrat62's Avatar
Oddometer: 999
Originally Posted by ba_ View Post
What tank is that?
that's the 4.7 gal
leftystrat62 is offline   Reply With Quote
Old 11-19-2012, 02:36 PM   #31592
Loud Al
Loud Al's Avatar
Oddometer: 3,921
Originally Posted by Scott_PDX View Post
Yeah, but not much of a scientific test. Sure would like to see a drag race from stop on the mods vs. not modded. I just added a full FMF set up and did the airbox mods etc. Only had a chance to ride around the neighborhood so far, but the "seat of the pants" dyno sure seems like more power than what I'm seeing in that video.
After it stops raining we can compare my stock WR to your modified WR
A Quick Trip to Big Sur
Allan
Loud Al is offline   Reply With Quote
Old 11-19-2012, 02:40 PM   #31593
scottmac
scottmac's Avatar
Oddometer: 1,982
You should both be running the same gearing to get the best results....
scottmac is offline   Reply With Quote
Old 11-19-2012, 05:09 PM   #31594
Mikef5000
Oddometer: 2,031
Originally Posted by Bob in Indy View Post
Wow... that doesn't seem to be a big difference, at least from the video.
Agreed. I've pretty much decided that, short of going all out (with a big bore kit), I don't think modding this bike is worth it for more power. For sound, or just for the sake of tinkering, definitely, but not for power.
In the end, I want more low-mid range power; I could care less about more peak power.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 11-19-2012, 06:22 PM   #31595
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,775
The Drag Race
Too many unknowns to make that comparison meaningful........carbon fiber helmet vs fiberglass, chain lube or not, hi-beam or low beam, blue socks or red?
R² would be gone from the frame. Just sayin
HF
Dang, I'm getting interested in my WRR again...
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 11-19-2012, 06:36 PM   #31596
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,764
Interesting video, yes, and lots of variables. Agreed that the WR in stock form is a very competent machine.
However, that being said, I have ridden my modded bike and a completely stock WR back to back. The stock bike is fun, but I appreciate being able to snap the front tire up to get over a rock, or a log, etc. Uncorking the airbox along with a free flowing exhaust system is still the way to go.
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 11-19-2012, 07:05 PM   #31597
indypup
indypup's Avatar
Oddometer: 3,764
How's my bike compare to yours Mike? I don't have a big bore but I have modded just about everything else. I know you didn't ride it that much but was wondering if you could tell any difference.
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 11-19-2012, 07:30 PM   #31598
Mikef5000
Oddometer: 2,031
I would love to try yours with stock gearing for a more direct comparison. But that being said, and don't take this personally or anything, but I was disappointed in the lack of difference. Like you said, I didn't ride it much, and like I said, we're running very different gearing, but the fact is, I cracked the throttle several times hoping to loft the front end, but the reality was the same as my bike, I needed to bounce it and/or put some effort into it. You're gearing and tires were much better for off road than mine, but (useable) power wise they are still damn close. Perhaps peak power (like a drag race) you'll walk away from me, but I don't use peak power out on the trails.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Old 11-19-2012, 07:32 PM   #31599
indypup
indypup's Avatar
Oddometer: 3,764
Yeah, that's what I thought. ;) Speaking of lofting the front end. You were doing that a lot when I was following you. What's your secret for doing that?
Old 11-19-2012, 08:08 PM   #31600
Mikef5000
Oddometer: 2,031
Yeah, lofting is kind of my thing. I've ridden street bikes for a decade, and always wanted to be able to wheelie, but was never willing to risk my bike learning (on pavement). Now that I'm riding dirt I'm giving it my best shot, and getting better every time I go out.
I don't use the clutch to loft, so that leaves your body and the throttle. On a flat surface... In first gear I can just give the bars a good tug and crack the throttle and it'll float the front tire, good enough to get over a small rock or root or across a small washout. Put my whole body into it (king of lean forward and throw myself back) and crack the throttle and it'll come up plenty far to cross a creek or whatever. In second gear, the 'throw the body weight' thing works to float the tire, but not lift it much. Add a suspension bounce in there and it'll come up more.
The easier method is with less than smooth ground. A rock or root are all that's needed to bounce the front tire up in first or second gear with a good crack of the throttle.
What it ALL come down to is timing. Timing when to hit the gas, or tug, or throw your weight, or bounce. It's all about timing, and the only way to get that down is by practicing. Luckily, without using the clutch, the wrr isn't powerful enough to loop you into oblivion without you knowing what hit you. You could certainly loop it if you tried, but you'd have to really be trying.
All my opinion/thoughts of course.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Old 11-20-2012, 07:12 AM   #31601
coresports
coresports
coresports's Avatar
Oddometer: 329
i was actually surprised i stayed as close as i did....i think if we kept going i would get farther behind but then again, i am not a scientist
i have 2 more side-by-side runs from the same day i will get uploaded before turkey day - dam work gets in the way, haha
dougz73 - we are approx the same weight, fwiw
coresports is offline   Reply With Quote
Old 11-20-2012, 08:38 AM   #31602
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,755
Deal! But since when did YOU let a little rain slow you down? Hoping to get out sometime over the Turkey Day break. Will post up in the usual PNWet areas, or PM me. Know any good "drag" spots?
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 11-20-2012, 10:38 AM   #31603
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,661
dual sports
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 11-20-2012, 12:49 PM   #31604
PatrickInVA
PatrickInVA's Avatar
Oddometer: 229
Originally Posted by Rapid Dog View Post
(great WRR Picture)
What tail bag is that?
PatrickInVA is offline   Reply With Quote
Old 11-20-2012, 01:50 PM   #31605
TwilightZone
Oddometer: 3,198
>"What tail bag is that? "
It is a Wolfman "Peak Tailbag". Really nice bag.
Holds first aid, tools, tire pump, other stuff... etc.
http://www.wolfmanluggage.com/Tail/peak_tail_bag.html
"I don't really know, I've been too busy falling down."
TwilightZone is online now   Reply With Quote
Times are GMT -7.   It's 11:15 AM.
