11-19-2012, 01:40 PM
#31591 | |
Oddometer: 156
- DR650 - WR250R times 2 |
11-19-2012, 02:24 PM
#31592 |
Oddometer: 966
11-19-2012, 02:36 PM
#31593 | |
Oddometer: 3,636
After it stops raining we can compare my stock WR to your modified WR
Allan |
11-19-2012, 02:40 PM
#31594 |
Oddometer: 1,290
You should both be running the same gearing to get the best results....
11-19-2012, 05:09 PM
#31595 | |
Oddometer: 1,691
In the end, I want more low-mid range power; I could care less about more peak power. |
11-19-2012, 06:22 PM
#31596 |
Bike-aholic
Oddometer: 2,103
The Drag Race
Too many unknowns to make that comparison meaningful........carbon fiber helmet vs fiberglass, chain lube or not, hi-beam or low beam, blue socks or red?
R² would be gone from the frame. Just sayin HF ![]() Dang, I'm getting interested in my WRR again...
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 BMW F800GS, '71 Honda CL70 Bergs Over the Rainbow Texas or Bust! BigDog/Highfive--Fall Colors in Missouri 2011 Athena Big Bore Project The Other Side of Nowhere Highfive Goes Dragon Hunting WRRDualsport.com |
11-19-2012, 06:36 PM
#31597 |
MacGyver
Oddometer: 1,985
Interesting video, yes, and lots of variables. Agreed that the WR in stock form is a very competent machine.
However, that being said, I have ridden my modded bike and a completely stock WR back to back. The stock bike is fun, but I appreciate being able to snap the front tire up to get over a rock, or a log, etc. Uncorking the airbox along with a free flowing exhaust system is still the way to go.
_______________ "You can't put the shit back in the donkey." - Tony Soprano FYYFF
11-19-2012, 07:05 PM
#31598 | |
╭∩╮( º.º )╭∩╮
I know you didn't ride it that much but was wondering if you could tell any difference.
If there's no video...it didn't happen
2007 ST1300, 2008 KLR650, 2008 WR250R, 1995 Ninja 250R Only a dog knows why a motorcyclist hangs his head out the window! Be real, be whole, be innovative. |
11-19-2012, 07:30 PM
#31599 |
Oddometer: 1,691
I would love to try yours with stock gearing for a more direct comparison. But that being said, and don't take this personally or anything, but I was disappointed in the lack of difference. Like you said, I didn't ride it much, and like I said, we're running very different gearing, but the fact is, I cracked the throttle several times hoping to loft the front end, but the reality was the same as my bike, I needed to bounce it and/or put some effort into it. You're gearing and tires were much better for off road than mine, but (useable) power wise they are still damn close. Perhaps peak power (like a drag race) you'll walk away from me, but I don't use peak power out on the trails.
11-19-2012, 07:32 PM
#31600 | |
╭∩╮( º.º )╭∩╮
11-19-2012, 08:08 PM
#31601 | |
Oddometer: 1,691
I don't use the clutch to loft, so that leaves your body and the throttle. On a flat surface... In first gear I can just give the bars a good tug and crack the throttle and it'll float the front tire, good enough to get over a small rock or root or across a small washout. Put my whole body into it (king of lean forward and throw myself back) and crack the throttle and it'll come up plenty far to cross a creek or whatever. In second gear, the 'throw the body weight' thing works to float the tire, but not lift it much. Add a suspension bounce in there and it'll come up more. The easier method is with less than smooth ground. A rock or root are all that's needed to bounce the front tire up in first or second gear with a good crack of the throttle. What it ALL come down to is timing. Timing when to hit the gas, or tug, or throw your weight, or bounce. It's all about timing, and the only way to get that down is by practicing. Luckily, without using the clutch, the wrr isn't powerful enough to loop you into oblivion without you knowing what hit you. You could certainly loop it if you tried, but you'd have to really be trying. All my opinion/thoughts of course. |
11-20-2012, 07:12 AM
#31602 | |
coresports
Oddometer: 100
i have 2 more side-by-side runs from the same day i will get uploaded before turkey day - dam work gets in the way, haha dougz73 - we are approx the same weight, fwiw |
11-20-2012, 08:38 AM
#31603 | |
Oddometer: 1,149
2011 WR250R 2009 KLR650 2004 KTM 450 EXC 2000 R1150GS "The older I get, the faster I was" |
11-20-2012, 10:38 AM
#31604 |
bikes, booze, broads...
Oddometer: 8,333
dual sports
'08 R1200R / '10 WR290X/R '81 R100RS Rattlecandy Red '06 950 ADV Orangeboom '05 R12GS Wedding Bike '91 R100GSPD Derelict |
11-20-2012, 12:49 PM
#31605 |
Oddometer: 95
