Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 11-19-2012, 08:02 AM   #14956
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,684
Originally Posted by Rob Dirt View Post
Check your brake pads. At 12k my rear pads were toast.
Interesting. I swapped out all pads at a little over 20k miles. IIRC, the rear ones were the most worn at that point, but not down to the backing plate yet. But then, I don't use the rear brake much.
FWIW, the pads I swapped in are EBC HH ones -- big improvement in bite. Now, 10k miles later, they're still in great shape; but I don't expect them to last as long as the originals.
Also, for anyone who's interested, at 30,500 miles I'm still on the original chain and sprockets. I'm planning to replace those this winter though just so I don't have to think about it at all next season.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 30-June 1, 2014
markbvt is offline   Reply With Quote
Old 11-19-2012, 09:01 AM   #14957
woodmnctry
woodmnctry's Avatar
Oddometer: 185
Warranty ????
Under Triump "Warrany Terms & Condition"
it is stated that
Conditions and Exclusions:
3. The machine must have been serviced by an authorized Triumph dealer, at the intervals specified in the Triumph Owners Handbook and the service log completed accordingly.
Has anyone ever had warrantly service denied becaus of this clause -- seems we all do what we can service wise and may have done an oil change rather that go to the dealer --- just curious if anyone has encounterd issues on this??
woodmnctry is offline   Reply With Quote
Old 11-19-2012, 09:19 AM   #14958
cug
Oddometer: 4,858
Legally wrong:
http://cadrecycle.com/magnusonmoss.php
cug is offline   Reply With Quote
Old 11-19-2012, 12:55 PM   #14959
markbvt
Oddometer: 2,684
Maybe you inadvertently received a manual intended for the British market. As cug has pointed out, it's illegal in the US for a company to deny warranty claims because the service was done somewhere other than an authorized dealer -- even if you did it yourself (as long as you've kept parts/supplies receipts to prove you did it).
--mark
Old 11-19-2012, 01:23 PM   #14960
woodmnctry
woodmnctry's Avatar
Oddometer: 185
Originally Posted by cug View Post
Thanks --- that is what I thought but just wanted to sure
G
Old 11-19-2012, 04:48 PM   #14961
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,192
anyone use wolfman racks on your XC? Pictures
Click Here!
2012 Triumph Tiger 800 XC
2008 Yamaha WR250R
1971 Lambretta DL
levain is offline   Reply With Quote
Old 11-19-2012, 11:59 PM   #14962
Simon Smith
Simon Smith's Avatar
Oddometer: 192
--mark
Legally wrong in the UK too, parts have to be to the same specification as the manufacturers, but any "competent person" can do the work.
'11 Triumph Tiger 800XC,
Simon Smith is offline   Reply With Quote
Old 11-20-2012, 06:59 AM   #14963
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,703
It's EU law that so long as it is serviced to the same spec as you would get from an authorised dealer they can't deny you warranty.
2002 black Tiger955i, 72000 miles and counting.
2012 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 11-20-2012, 07:07 AM   #14964
opjocephus
I'm down, I'm down!
opjocephus's Avatar
Oddometer: 549
I do.
OP
"They're skanky, but they look pretty good!"
Plastic seat sweat, my balls are mighty wet.
"Your eyes look like a couple of piss holes in a snow bank." The Great Jaydini
opjocephus is online now   Reply With Quote
Old 11-20-2012, 07:08 AM   #14965
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,703
--mark
Yes I am. Are you using a Scottoiler or similar. I just swapped my front sprocket at 17600 miles and it was looking very worn. I do that to help the chain last a little longer.....I hope.
I wasn't expecting to get much more than 25K on the 800 compared to the 30K+ I get on the 955 because of the smaller front sprocket. 800~16 compared to 955~19.
Old 11-20-2012, 07:39 AM   #14966
markbvt
Oddometer: 2,684
Not using a Scottoiler, no, but I lubricate the chain religiously every 200-300 miles (or after riding in the rain) using the Dupont Teflon multi-use lubricant. I used that stuff on my Wee-Strom's original chain as well, and that chain lasted about 32,000 miles (though the front sprocket did need replacing around 25k miles). I attribute the long life primarily to that lube -- it's great stuff.
The Tiger's front sprocket is worn, but not terrible yet. I'll replace it this winter. But I'm undecided on the rear sprocket -- it's not showing much wear at all, so I may leave it on.
--mark
Old 11-20-2012, 08:24 AM   #14967
TerraUnFirma
Fair/Not Balanced
TerraUnFirma's Avatar
Oddometer: 352
Stock Tiger Bar End inserts...
Last night I installed HDB handguards, Top Clamp and mirrors on my XC, but I ended up installing with the stock bar-end bolts and the factory inserts as opposed to tapping and using the supplied HDB inserts and bolts. The stock bolts are a little smaller but are countersunk type and worked fine. It wasn't obvious how the stock inserts might be removed...anyone been through this and have a clue?
Overall, it seems a rock solid setup, highly recommended. I do have one thought, the shields are very flat, vertically, I'm thinking of heating them with a heat gun and seeing if I might not be able to angle the top lip back a bit, I'd think it would cause smoother airflow over hands and lower arms.
Cheers,
Tom Stites - Dawsonville, GA -
'11 Triumph Tiger 800XC ABS
'97 BMW R1100RT
'06 Suzuki DRz400s
'08 Yamaha WR250R
TerraUnFirma is offline   Reply With Quote
Old 11-20-2012, 08:41 AM   #14968
some call me...tim
some call me...tim's Avatar
Oddometer: 279
Just as a heads up to those who aren't aware, the Dupont Teflon lube has changed, and isn't the same magic-in-a-can that it used to be. http://www.webbikeworld.com/t2/dupon...ain-lube-2012/
some call me...tim is offline   Reply With Quote
Old 11-20-2012, 08:56 AM   #14969
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,192
Originally Posted by opjocephus View Post
I do.
Awesome. Thanks. Exactly what I was looking for. You wouldn't happen to own anyu Kriega bags would you? I'm wondering if I could use a US20 on exhaust side and US30 on left. It seems with the welded on loops, it could be done, but how much rigamarole involved is my question
Click Here!
2008 Yamaha WR250R
1971 Lambretta DL
Old 11-20-2012, 09:20 AM   #14970
TekurRides
Oddometer: 67
Quick question? Could you give some reasons for choosing the wolfman as against a hard luggage solution. How protective do you think the bags are in case of a crash. Would you put expensive like camera and stuff there or may be just tools and clothes and other inexpensive stuff?
TekurRides is offline   Reply With Quote
Times are GMT -7.   It's 08:08 AM.
