11-18-2012, 03:52 PM
#1 |
Oddometer: 125
Air Filter Servicing on Extended Trips?
I'm planning on heading to Central America for a couple months starting in December. I still have a long was to go before I'm ready but have things pretty much figured out. One thing I'm not sure about is air filter maintenance. The bike I'll be taking is an XR650R. I have a choice between a foam air filter or a K&N filter. I already have both. Both would require carrying oils, and maybe cleaners, etc.
How are you maintaining your air filter on the road? |
11-18-2012, 04:36 PM
#2 |
Registered User
Oddometer: 25,004
I'll offer a couple of things...
Foam filters can go many, many miles (think 20k or so), depending on the envirnoment. I would not choose a KN for longterm travel. Oils and tranny fluids to renew foam filters can be found most anywhere. You don't need a special mfgr's labeled brand. Get a good one to start; and the factory filters are good. I suggest thinking more about oil filters for your specific bike. Without good filtration - air and oil (fuel may also apply) - the aliens can get in and ruin your fine bike in short order. The barrier, so to speak. |
11-18-2012, 07:13 PM
#3 |
Oddometer: 1,074
Put a prefilter on and you should be good for the entire trip with the foam filter.
11-19-2012, 03:56 AM
#4 |
BAN - Born Again Noob
Oddometer: 5,395
Personally I'd stick a post in the appropriate regional forum asking if an inmate, on your route, could offer assistance servicing your bike..help sourcing spares, advice on local availability a garage to work in.
It'd be a great way to meet new folks and it may mean you'd not have to carry so many spares. I did something similar when I rode around the US and met some great people.
Planning NA 2010 NA 2010 Adriatic Loop August 09 Mandello Guzzi Protest Sept 09 "I've got the key to the gates of paradise...but I've got too many legs!!" Jeff "Civilized men are more discourteous than savages because they know they can be impolite without having their skulls split, as a general thing." -- Robert E. Howard |
11-19-2012, 07:10 AM
#5 |
almost gnarly
Oddometer: 1,479
A couple drops of dish soap like Dawn in a little water will do a good job cleaning a foam filter. Re-oil with a little bit of motor oil and you're all set. Neither one should be too hard to find or carry.
'97 R1100GS, '99 DR350, '02 DR650, '03 DR650, '04 R1150RT A Few Days Solo to Copper Canyon A Maine Rider’s Arizona Day Trips A Few Days Solo in Baja |
11-19-2012, 07:26 AM
#6 |
Hold my beer & watch this
Oddometer: 527
I have heard of using a zip lock and some camp gas or kerosene to clean the air filter. Squeeze out the excess solvent then douse it with a shot of gear oil and squeeze again to get ride of the excess. The remaining solvent will help the oil disperse into the filter and then will evaporate.
Fly Rods, Kids and a KLR |
11-19-2012, 07:38 AM
#7 |
Oddometer: 1,203
I ride a KLR on long trips, but I don't know about the XR. But the KN filter for the KLR is totally unacceptable for long trips on dirt. It clogs with dust too easily. And my bike will not run.
I carry two spare preoiled foam filters. This can get me 3-4k miles whithout having to clean one. They can be scrunched up to less that a couple of cubic inches each. Cleaning them using gasolene in a plastic bag works pretty well too. The prefilter sounds like a good idea too, but I have never tried it. |
11-21-2012, 06:58 AM
#8 |
Oddometer: 125
Thanks for all the tips. I think I'll stick with a foam filter and bring an extra. The XRR filter is just a flat piece of foam so it packs small. And I'll bring either a small can of spray filter oil or pour some regular filter oil into a sealed container.
Brian |
11-23-2012, 02:32 PM
#9 | ||
tierra de boobies
Oddometer: 538
Mike
Team Mojados Spearfishing Quote:
11-23-2012, 05:24 PM
#10 | |
Registered User
Oddometer: 25,004
You can easily find oils locally. There's no need to carry extra, imo. It is a good thing - wanting to care for your bike. You'll find you're own groove after some time. Best of luck to ya... |
11-24-2012, 09:19 AM
#11 |
Oddometer: 220
![]() I always carry a spare that is pre-oiled and ready to go on long trips. I keep them in a "stronger" gallon sized zip-lock bag until I need them. Sent from my iPad using Tapatalk HD |
