Old 11-21-2012, 06:16 AM   #14386
TH
There and Here
TH's Avatar
Oddometer: 912
During my rides, granted they haven't been as "extreme" as yours, but I have only bottomed out my forks once. It was a pretty decent pot hole in a forest road. It didn't seem that big, compared to some of the other holes we went through that night. That was with stock springs and wheel.
"doggone and dagnabit! That's what I call a whopping' big rabbit."
Keep the rubber side down
'01 Sprint ST '12 Super Tenere
NOVA Tag-o-Rama Map
TH is offline   Reply With Quote
Old 11-21-2012, 06:57 AM   #14387
jaumev
jaumev's Avatar
Oddometer: 1,498
My springs are harder than OEM
The ST suspension is 190mm long but I don’t know if there is any mechanic or hydraulic system who stops the fork before it hits the end. And if there is what is the space it leaves…
Does anybody know?
jaumev is offline   Reply With Quote
Old 11-21-2012, 07:47 AM   #14388
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 1,939
Forks...
Does anybody know?
If you were first trying to determine your maximum travel by unscrewing the fork caps and just letting the forks slide down to the bottom then you will not get an accurate assessment of the actual travel. The fork has to be fully assembled, with springs, etc., and then you have to "pull" it down, much like you have with the straps. Usually this measurement will be as much as an inch less as one taken with the forks semi-disassembled. Few forks I am aware of these days use any sort of bottoming "cone" like the old damper rod forks, yet some actually have bottoming "bumpers", much like a shock, but looking at the parts diagram of the Super Ténéré fork it doesn't appear it's one of them. In fact, internally it looks like most upside-down sportbike forks around these days, and from my experience that means the springs run into coil-bind as the fork bottoms out.
BTW, using different springs, particularly if they are of different wire gauge thickness or are wound with more or less coils than stock, can significantly change when this coil-bind occurs. Again, the only way to find out is to fully assemble the fork and "pull" it down until it well and truly bottoms.
One thing, you can make it a lot easier on yourself to check for this point of coil-bind if you pull the forks, drain out the fork oil, then re-install the forks and check the travel. With oil in the forks there is less air-space above the oil and this acts as a spring, but a very progressive one, and as you get close to maximum travel it can get *VERY* stiff. So stff that some fork makers actually use this as their bottoming stop in sense, specifying fork oil height/air volumes that literally bring the fork close to hydraulic "lock" just prior to spring coil-bind.
But this can be your friend if you start to run into clearance problems, that is if you can live with the near full-stroke harshness... That is, if you are bottoming out and using the forks full travel to coil-bind and hitting your header pipes or skid plate with the 21" wheel, you can raise the fork oil height in the tube. This will effectively *stiffen* the spring rate throughout the fork travel, but will really spike it near full-stroke... If you want you can keep raising the fork oil level until there is literally no way the wheel can hit anything. Only problem is you may not be getting all the travel the fork has to offer and the ride will be much more harsh through the stroke of the forks.
Hope this helps.
Dallara
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is online now   Reply With Quote
Old 11-21-2012, 09:30 AM   #14389
jaumev
jaumev's Avatar
Oddometer: 1,498
Hope this helps.
Dallara
It helps A LOT!!
As you can see in the pics before I compressed the fork with straps to the maximum I could and it was 34mm left, so if I understood your comments this must be approximately the maximum fork travel with my settings (springs, oil, etc.)
Thank you very much Dallara!
Old 11-21-2012, 12:20 PM   #14390
Thagua
Let's go adventuring...
Thagua's Avatar
Oddometer: 354
Use progressive fork springs
It helps A LOT!!
Hola Jaumev ... I have done the upgrade to 21" on the front modifying the front fender and making the suspension more stiff on the last inches before bottoming with the Wilbers progressive springs.
Saludos,
Roberto
PS.- Remember that I am one step ahead of all innovations
'Let's go adventuring'
Thagua is offline   Reply With Quote
Old 11-21-2012, 12:37 PM   #14391
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 16,805
Saludos,
Roberto
You're right. None of us saw that trailer coming.
How's the Tenere trike kit turning out???? Opps, I hope I didn't mention that too soon.
pluric is online now   Reply With Quote
Old 11-21-2012, 12:48 PM   #14392
Thagua
Thagua's Avatar
Oddometer: 354
Innovations
After your kind remarks and help with links my trailer has been cut 32 inches shorter to use it as a baggage trailer .. I am now considering a double wheel trailer as shown on the following picture... and thanks again to all who contribute with ideas to improve our great bikes ... although mine is the BLACK PEARL 'Super World Crosser'
Cheers,
Roberto
Old 11-21-2012, 01:01 PM   #14393
Dallara
Dallara's Avatar
Oddometer: 1,939
Talking My pleasure...
It helps A LOT!!
No problem, Jaumev.
Happy to be of any assitance... Especially to someone like you who has contributed so many fine ride videos and pictures of the Super Ténére´out there off-road.
One note... I just went out and checked my fork travel indicators (small cable tie around each fork tube) on my own Super Ténéré, and my forks hit full travel with an indicated 25mm from axle carrier casting to the dust cap slider limit at the upper edge of the cable tie. That's in actual riding. Though I haven't ridden in any off-road sections as technical and extreme as you have, I do ride fairly hard and have bottomed my forks regularly (as should be the case).
Note this is traveling more than the 34mm you seem to be getting in your pics.
Just for the record, my bike has the full Stoltec mods (stiffer, custom-wound, heavy spring wire front springs, Penske valving, etc.) to the forks, and as such might actually have slightly more usable travel than stock since Nick at Stoltec says the springs he uses have a much more *open* wind to avoid coil-bind so early. With his mods the forks are much smoother in operation as well as more compliant than stock, yet with much more control and precision... None of the indistinct "hobby-horsing" (excessive fore-and-aft pitching) that the stock set-up exhibited. They also smoothly bottom out, with none of the harsh "slamming into a hydraulic-lock stop" feeling of the stocker.
That said, again my fork travel is nearly a half-inch more than your "test bench" travel so you might want to go take another look.
Just FYI...
Dallara
Dallara screwed with this post 11-21-2012 at 02:20 PM
Old 11-21-2012, 01:13 PM   #14394
jaumev
jaumev's Avatar
Oddometer: 1,498
Saludos,
Roberto
Hola Roberto!
I know! You and Wasp where my inspiration to the conversion! Many thanks to be the first to show us the way.
My BM springs are harder than the OEM so I hope they help to no to arrive to the end of the fork travel.
I remember all your innovations.... also the ones I never must do (the trailer)
Cheers!
Old 11-21-2012, 01:31 PM   #14395
jaumev
jaumev's Avatar
Oddometer: 1,498
No problem, Jaumev.
That was my contribution to keep pete quiet
One note... I just went out and checked my fork travel indicators (small cable tie around each fork tube) on my own Super Ténéré, and my forks hit full travel with an indicated 25mm from axle carrier casting to the dust cap slider limit at the upper edge of the cable tie. That's in actual riding. Though I haven't ridden in any off-road sections as technical and extrem as you have, I do ride fairly hard and have bottomed my forks regularly (as should be the case).
Just FYI...
Dallara
Probably I can go a little further than the 34mm but I was afraid the straps broke, I did lot of power…. I don’t know if my springs can be the reason to that difference.
Anyway, the bike is finished and Saturday is going to be the great day… I’m really anxious to try it, it looks sooooo god!
Many thanks again!
Old 11-21-2012, 02:05 PM   #14396
GrahamD
GrahamD's Avatar
Oddometer: 5,307
I though I've sent to you a PM days ago.
It is in the flea market forum:
http://advrider.com/forums/showthread.php?t=834493
PM sent. Sold.
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 11-21-2012, 02:45 PM   #14397
jaumev
jaumev's Avatar
Oddometer: 1,498
Originally Posted by GrahamD View Post
PM sent. Sold.
Received!!
Old 11-21-2012, 02:56 PM   #14398
wolftrax
wolftrax's Avatar
Oddometer: 422
Many thanks again!
Lookin good, your going to love the 21"er!!!
2014 Honda CRF250L
2013 Husky TR 650
1990 KLR650
wolftrax is offline   Reply With Quote
Old 11-21-2012, 04:22 PM   #14399
Thagua
Thagua's Avatar
Oddometer: 354
Protect your forks
Hola Javier ... Protect your forks ... for the lower use those sponge type covers (Acerbis) and for the upper, italian manufacturer Pro Grip makes a slip on carbon protection.
Saludos,
Roberto
Old 11-21-2012, 04:48 PM   #14400
GrahamD
GrahamD's Avatar
Oddometer: 5,307
"can I put more than 5Kg on the back of the Tenere? Will it break? Can it take it?"
From Barrel over at YST.
Times are GMT -7.   It's 08:15 PM.
