Old 11-23-2012, 04:52 AM   #71386
Jammin
Living on a DR
Jammin's Avatar
Oddometer: 1,556
Ha! Found the culprit: clogged fuel filter (paper core). Replaced it with a new spare (copper core) and sanDRina runs like a champ! Went for a 60 km test ride and no issues. I think that was it Continuing south tomorrow
Come on, motorcycle gods, what else you got? Let me have it.
I got jolted last night and told myself that 'give up' isn't in my dictionary. I beat my demons back in their cave and listened to the advice from ADV brethren who directed me to inspect this part.
If I don't make it to the next town tomorrow, I'll figure it out
Thanks!!!
J A Y on a 98 Suzuki DR650SE (sanDRina)
Trip Website: JamminGlobal.com
Current Ride Report: Global South | Past Trips: CDR '09, Alaska '08, Mexico '07 | YouTube Videos
Jammin is offline   Reply With Quote
Old 11-23-2012, 04:58 AM   #71387
refokus
Just Learning
refokus's Avatar
Oddometer: 2,455
Originally Posted by Adv Grifter View Post
. It is the wise man who uses his friends and their broad knowledge and creative ideas to solve the unsolvable.
+1
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 11-23-2012, 05:36 AM   #71388
procycle
procycle's Avatar
Oddometer: 2,306
Originally Posted by Slideways#96 View Post
You running that 150/70/17 on a stock dr rim?
No. I have what I call 'Adventure Wheels'. A 4.25x17 rear and a 2.75x19 front.
Makes the bike much feel more planted on the twisty pavement without giving up anything significant in off-road capability. It would be a bad idea to run a 150 tire on the stock rim.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 11-23-2012, 05:56 AM   #71389
Ridin'nFishin
Oddometer: 492
Thanks!!!
Great!
Now ride.
Riding a Motorcycle is like flying like a Eagle without ever leaving the ground.
Ridin'nFishin is offline   Reply With Quote
Old 11-23-2012, 06:09 AM   #71390
nsrrider
Oddometer: 31
Barrel and cyinder head paint?
Need some input. Can the barrel and cylinder head on the DR be painted with high temp paint (like from a rattle can) with any expectation of it holding up very well?
Can they be powder coated and would that hold up better?
Is there a better option?
thanks guys!
nsrrider is offline   Reply With Quote
Old 11-23-2012, 07:23 AM   #71391
Slideways#96
scooter trash
Slideways#96's Avatar
Oddometer: 559
Okay, thanks for the advice..
Slideways#96 is offline   Reply With Quote
Old 11-23-2012, 08:11 AM   #71392
sagebrushocean
Harris's hawker
sagebrushocean's Avatar
Oddometer: 180
Looks like the previous owner did a proper job of bypassing the side stand and neutral safety switches. Under the tape there will likely be a jumper wire as described here:
http://www.advrider.com/forums/showp...postcount=2300
Originally Posted by Anklyne View Post
Does anyone know what this connector is for? Two of the connections are shorted with some wire and all four of them head back into the wiring loom. Unfortunately I didn't take note of which wires were shorted. It's located on the LHS near the CDI.
2008 DR650SE supermoto
2009 CRF230M
sagebrushocean is offline   Reply With Quote
Old 11-23-2012, 08:15 AM   #71393
JagLite
JagLite's Avatar
Oddometer: 1,240
Thumb Success!
Thanks!!!
Simple bike, simple problems
So glad you found the cause and solution.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 11-23-2012, 12:44 PM   #71394
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Thanks!!!
Great news! So, looks like the few geniuses here who insisted it was fuel related ended up being correct. (I was not one backing that theory! )
Just goes to show ... sometimes even the simplest things can fool even the very experienced. It's happened to me ... many times.
But I'm so glad it appears NOT to be electronics!
Carbs are MUCH easier to sort out.
How would you guys like to pay for:
1. New Stator
2. New Rectifier/Regulator
3. New Coil
... and whatever else was purchased ... only to find out it was a simple case of a clogged filter.
Any bets some nice used Stators and other electronics will be turning up for sale soon in the Flea Market?
Ride On Jay!
Old 11-23-2012, 01:13 PM   #71395
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,657
1. New Stator
3. New Coil
Ride On Jay!
This reminds me of the time my brother couldn't get his Harley 45 started and tore the whole thing apart just to find out he was out of fuel.
Old 11-23-2012, 01:55 PM   #71396
Magnum Noel
Magnum Noel's Avatar
Oddometer: 187
Originally Posted by buckrut1972 View Post
After spending $140 on gloves a bit ago that 29 degree ride in this morning finally did it for me. I NEED HEATED GRIPS. I see lots of models but can anyone point me in the right direction? I prefer the easier the set up the better.But I'll take anything at this point.
I like the Oxford Heated Grips they've been great
Magnum Noel is offline   Reply With Quote
Old 11-23-2012, 02:00 PM   #71397
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,264
Still in progress. 3 more days ahead of us.
--> http://drriders.com/topic6350.html
Great trip. Great photos. I rode around outside of Ridgecrest back in 1977.
Be sure to keep us posted about the swingarm issue.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 11-23-2012, 03:52 PM   #71398
ER70S-2
ER70S-2's Avatar
Oddometer: 6,455
I did a bit of work on the bike today.
Genius!!! You've made the DR infinitely more comfortable and you didn't have to buy a new seat.
I found this in Sagebrushocean's link:
There are 4 wires going into the connector for the side stand switch,
2 orange, one green & one orange with black tracer. You want to make
a jumper that connects one of the orange wires to the orange with
black tracer.
Just goes to show ... sometimes even the simplest things can fool even the very experienced. How would you guys like to pay for:
1. New Stator
3. New Coil
Ride On Jay!
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 11-23-2012, 07:40 PM   #71399
Garak
Cardassian Spy
Garak's Avatar
Oddometer: 266
+1. I'm very happy with my Oxfords. The wiring can be delicate in spots so exercise caution when installing, but once they are on they work very well and seem pretty robust.
Across the country on the kindness of strangers and the strangeness of friends (and a DR650).
My LinkedIn Profile
Garak is offline   Reply With Quote
Old 11-23-2012, 09:08 PM   #71400
procycle
procycle's Avatar
Oddometer: 2,306
I'm so glad you have it sorted out!
For future reference - one way to help diagnose a fuel flow problem is to engage the choke as soon as the misfiring starts. If running on choke makes a big improvement it's almost certain that there is a fuel starvation problem.
Times are GMT -7.   It's 08:24 AM.
