11-21-2012, 08:09 AM
#6346 | |
Oddometer: 158
| KTM 690 SMC | Honda Africa Twin | |
11-21-2012, 07:58 PM
#6347 |
Oddometer: 37
HID Lights
I purchased Xentec HID's for my 690, which has the 990 Adventure headlight (Rally Raid Kit). The light worked fine until last Sunday, when I rode it at the local OHV park, and it stopped working. After checking the wires, bulb, and connecting the ballast to my truck HID's, I found the ballast had went bad. Have any of you had any issues with HID's? I'm thinking something may have been wrong with the ballast to begin with, as the box said it was "shockproof."
2009 KTM 690 Adventure 2008 KTM 250 XCF-W ---Sold |
11-21-2012, 09:06 PM
#6348 |
when in doubt GAS IT
Oddometer: 1,659
Ballasts do that LED is the future, most suppliers will replace ballast
11-22-2012, 08:50 AM
#6349 |
Oddometer: 37
What brand of ballast would you recommend? Are you saying maybe I should try another Xentec?
11-22-2012, 01:05 PM
#6350 |
SE Asia adventure tours
Oddometer: 567
Sorry no help... I'm looking for a good ballast myself. HID's have much better color rendition than LED though some new smaller emitors such as the Nichia 219 are getting better. Of course LED's have less to break on them.
Mega lumens from the new hi power LED's certainly have the wow factor - can blind others (and you when you hit reflective objects) but they don't help you SEE better than a good HID in a reflector. That's the tension between those two right now. "Aweing" someone with a lights power and helping you see better are not the same thing; there's no replacement for a well thought out/designed reflector. More light food for thought... it's really hard to beat a 50 watt, Hi CRI FX-7 Bi-Xenon projector for on the road lighting. What would be really awesome for you fabbing experts would be instead of having 2 swithes for hi/lo would be to have 3 for lo beam/hi beam/off-road only beam... actually 4 - have an "off" at the beginning. And it needs to be more durable.... maybe some kind of waterproof, rubber shock mounted holder for the ballast? |
11-22-2012, 01:41 PM
#6351 | |
Oddometer: 32
In terms of your hid note though, Retro solution makes a multi watt mode ballast. Sent from my Galaxy Nexus using Tapatalk 2 |
11-22-2012, 02:16 PM
#6352 |
Oddometer: 1,659
I have 2 90mm hella's. With roo lights slim line HID ballasts , ( light force copy ) excellent light out put , but as stated above
More failure points ,but no issues so far , my lights are set up. , off hi/lo. ( one lamp low beam both hi beam ) The only thing I don't like is start up time , where LED is instant . Once I'm working again I,ll get a pair of baja squadrons set up the same way , |
11-22-2012, 02:57 PM
#6353 | |
Guns are for pussies
Oddometer: 13,783
Just say'IN |
11-22-2012, 06:40 PM
#6354 |
Oddometer: 1,659
I totally agree I find some hid hard to see they are bright but don't seem to light up the road. ( must be some sort of color blindness)
11-23-2012, 12:54 AM
#6355 |
Machinery 2 Upper Level
Oddometer: 288
Agree about not seeming to light up the road as well. It seems that the light from my HID's is monochromatic, as opposed to the mixture that makes up "white" light coming out of incandescent lamps. It could also be that the color temperature of the HID's is too high. Lower color temps more closely resemble incandescent light, and that may be what's messing with our eyes.
Dennis Robertson Nuke operator Rescue bum Diver Check out my novel, DEFENDER, a Kindle e-book, www.Amazon.com/gp/aw/d/B004Z1U7UI |
11-23-2012, 09:56 AM
#6356 |
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 169
HID50.com - good enough for Walter and his extreme trips? Next on my to buy list
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen) 2008 Yamaha YZ450, 2002 Yamaha YZ426 www.bruneibikers.com www.airborneriders.com |
11-23-2012, 11:38 AM
#6357 | |
Wanderer
Oddometer: 808
My Aprilia 550 has a 1 HID bulb that moves location to change the focus between "dim" and "bright". It works better but doesn't have as good of pattern. I am thinking the best of both worlds would be a squadron for the bright and an HID for the dim. Or 2 squadrons.. one dimmed down for the "dim" and both on full power for the bright. 80w total and 7200 lumans
Noah 08 KTM 690 ADV. 52,000 km. 25 countries. 4 continents and counting. RTW Ride Report --> http://advrider.com/forums/showthread.php?t=781893 Blog ------------------> http://rtwwithnoah.blogspot.com/ Facebook------------> https://www.facebook.com/RtwWithNoah Open-Exporers----->A collection of travel blogs |
11-23-2012, 02:06 PM
#6358 | |
Oddometer: 13,783
Just say'IN |
11-23-2012, 02:35 PM
#6359 |
Wanderer
Oddometer: 808
No Dude.
Walter...
11-23-2012, 03:54 PM
#6360 |
Oddometer: 13,783
Just say'IN |
