Old 11-25-2012, 01:42 PM   #1
Superstar OP
Superstar's Avatar
Oddometer: 493
Pennzoil safe for wet clutch?
Any reason for me not to use Pennzoil 10-40 for my first oil change (Super Tenere).
http://www.pennzoil.com/motor-oil/pe...Specifications
I checked the API donut and it doesn't say 'energy conserving' so I assume it is safe for wet-clutch bikes.
Autozone has 5.5 qts jug plus the Bosch 3300 filter for $24.
I'll switch to full synth at 2K, but I like to run dino for break in.
Superstar is offline   Reply With Quote
Old 11-25-2012, 01:45 PM   #2
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,844
I'd do it. I've run many different types of 10w40 dino oils in my wet clutch HD primary with no problems.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 11-25-2012, 05:51 PM   #3
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
For the love of all that's sacred, why wouldn't you use a MOTORCYCLE specific oil and be sure the anti-wear addatives your EXPENSIVE engine needs are contained therein? You'd seriously skimp on $10 difference in the price of 4 qts. of oil for a $15,000 bike? http://www.amsoil.com/storefront/mcf.aspx Dino is NOT NEEDED for break-in any longer. Modern cylinder bores are finely finished, ready to roll.
Old 11-25-2012, 05:59 PM   #4
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,844
So I guess the reason for you not to use that oil is that your bike is sacred.....
Old 11-25-2012, 07:04 PM   #5
kubiak
Oddometer: 4,829
i would use a motorcycle oil for sure, i feel a lot better with the additives in the mc oil for you cam and rockers. i used car oil in one of my bikes and changed the oil every 1,000 miles and the cam and rockers were shot at 40,000 miles. dont know if it was the regular oil but it was enough for me to pay the extra 2 dollars per oil change form now on.
Old 11-25-2012, 11:14 PM   #6
Tosh Togo
Oddometer: 1,594
The answer to your whine is that Delo 400 and Rotella T work just dandy in MOTORCYCLE powerplants. They already have the right additives to keep gearboxes and wet clutches happy. About 10 bucks a gallon, so you'll save more than 20 clams, not 10.
Seriously.
Tosh Togo is offline   Reply With Quote
Old 11-26-2012, 05:35 AM   #7
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,337
It will be fine. I've run Castrol dino 10-40 in both of my bikes at one point.
However -- I switched to synthetic motorcycle oil because both bikes shift a LOT better with it in there. The shifting was crunchy and clunky and imprecise running generic dino oil. I'd consider using motorcycle oil just for that if I were in your shoes. But if you can't afford it at the moment, the Pennzoil will not hurt anything.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 11-26-2012, 07:48 AM   #8
MJS
MJS's Avatar
Oddometer: 1,905
I'd bet that the oil in question does have friction modifiers (bad for wet clutch) since it is rated API "SN". If you're going to use a automotive oil, use a diesel oil. One with a "C" as the first letter of it's rating. The Delo 400 and Rotella fall into this class since they are diesel oils.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 11-26-2012, 09:14 AM   #9
darkstarmoto
Am I evil? Yes I am
darkstarmoto's Avatar
Oddometer: 388
I was under the impression you "should" use an oil that is JASO certified at minimum for your bike with wet clutch.
05 KTM 950ADV - 08 KTM 690 SMR - 07 Ducati MTS1100S - Redneck Engineering Mutant
darkstarmoto is offline   Reply With Quote
Old 11-26-2012, 06:05 PM   #10
triplenickel
triplenickel's Avatar
Oddometer: 2,428
If the API logo says energy conserving that will have the friction modifiers. If the field is empty it doesn't.
07 SE
PG007
Old 11-27-2012, 07:53 PM   #11
Superstar OP
Superstar's Avatar
Oddometer: 493
Apparently this has changed recently with the introduction of the SN API type.
Old 11-28-2012, 11:07 AM   #12
MrPulldown
MrPulldown's Avatar
Oddometer: 3,356
I beleive that anything into the 40's weight will be fine. Conventional or syn.
MrPulldown is offline   Reply With Quote
Old 11-30-2012, 12:24 PM   #13
flars
Oddometer: 344
erl
"I beleive that anything into the 40's weight will be fine. Conventional or syn"
True. The stuff-that-is-to-be-feared is NOT used in 40 wt and higher.
flars is offline   Reply With Quote
Old 11-30-2012, 02:06 PM   #14
LuciferMutt
Oddometer: 11,337
Yep...most oils containing energy conserving friction modifiers (or whatevs) are used in x-30 weights and below. This is a big part of the reason almost all new cars these days specify a 5-30 or 5-20 oil -- to cut operating friction and eke out more fuel mileage!
YMMV...
Old 12-03-2012, 01:50 PM   #15
showkey
Oddometer: 1,955
Not always true..........when this came up prior it was found that 15w-50 Mobil 1 had friction modifiers as per Mobil tech support and not suitable for wet clutches.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Times are GMT -7.   It's 05:00 AM.
