11-19-2012, 06:06 PM
#106 |
Careening forward
Oddometer: 5,737
How about a photo of said object so we can guess at its purpose.
2003 KLX 400R dual sport |
11-19-2012, 06:18 PM
#107 |
Oddometer: 9,779
11-19-2012, 07:34 PM
#108 |
Oddometer: 869
I saw a Volt for the first time a couple of days ago. It looked nice in person, better than in the photos. If it fits tall people well, it will be a contender when I sell my current Golf TDI -- honestly, the Volt is probably better suited to my driving patterns, mostly short trips with occasional long drives, but it wasn't available when I bought the VW.
11-19-2012, 08:20 PM
#109 |
Woolf Barnato
Oddometer: 29,331
It's kind of tricky to see, a flashlight needs to be shined on it obliquely. A photograph would show the reflection of the light.
'Gonna get me a six pack...push people off the highway!' "they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood." "I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!" "Yeah, that guy sure is terrible at touching moms" |
11-20-2012, 03:01 AM
#110 | |
I know better
Oddometer: 6,735
Everybody is ignorant, only on different subjects - Will Rogers Do not do to others what you would not have them do to you - Hillel If you can't be knowledgeable, be certain |
11-25-2012, 06:47 AM
#111 |
Oddometer: 356
Pictures don't do the Volt justice.
Was out raking leaves and enjoyed my neighbors Volt and Prius silently drive by ...just a little whoosh Then come two fucking obnoxious harleys POSs' with straight pipes disturbing the peace ![]() It's about time cops start writing tickets for no mufflers
11-25-2012, 07:13 AM
#112 | |
Riding Nomad™
Oddometer: 12,787
Learn to ride. Ride to learn. |
11-25-2012, 07:22 AM
#113 |
Air cooled runnin' mon
Oddometer: 6,141
First TDI haters, now Harley haters.
How about Toxic, chubby, Volts.
I used to be indecisive. Now I'm not so sure. "You only have too much fuel if you're on fire" unknown |
11-25-2012, 09:25 AM
#114 |
Careening forward
Oddometer: 5,737
How about those goddam leaf blowers; louder than any Harley I ever heard.
11-25-2012, 03:33 PM
#115 |
I know better
Oddometer: 6,735
How'd this turn into the curmudgeon thread?
11-25-2012, 06:25 PM
#116 |
Careening forward
Oddometer: 5,737
11-25-2012, 07:01 PM
#117 |
Woolf Barnato
Oddometer: 29,331
I just drove to Los Angeles and back for the holiday. The mileage worked out to about 42 mpg for the full trip, 800 miles. The total average for the car since brand new is now 69 mpg. The drive back took about nine hours due to traffic instead of the usual six. That may be the first time I've made almost the entire drive at the speed limit.
The car would hold 80 on the southbound climb over the Grapevine but there wasn't much acceleration. Northbound on the descent I was able to add 15 miles to the range due to the downhill grade. It appears that it doesn't charge more than about 12 kw coasting down hill. The car would out run the cruise control i.e. it would coast at 70 when the cruise was set at 65. I though it might use more regen. to hold the set speed. If I feathered the brakes I could hold the speed at 65 and see a sizable increase in the charge rate. One of the hacks that would be cool is a way to see what the crossover point is from pure regen. to mechanical brakes to avoid heating the brakes instead of recovering energy. Also, the temperature of the engine, motor/generator, battery and inverter would be nice.
11-25-2012, 08:13 PM
#118 |
Holding up Michoagán
Oddometer: 1,403
Anorak-
Did you put it in L on the downgrade? Its not actually a lower gear, just applies more regen. I don't have any hills around my area to try it... |
11-25-2012, 09:06 PM
#119 |
Woolf Barnato
Oddometer: 29,331
Yes but it was too much retardation for the traffic conditions even in the far right truck lane. It would hold the speed at about 45 mph or so.
11-26-2012, 02:59 PM
#120 | |
Oddometer: 1,403
I've read on the Volt forum that if you put it in cruise and L, it will then hold a constant speed downhill. Of course, the conditions have to be conductive to using cruise control downhill. Skipping cruise control use, you could also then use / feather the gas pedal to lessen the 'engine braking' provided by L. Won't hurt anything, you're just telling it to not regen so much by using the gas pedal. Also, they say that you can tell when you're off the regen braking by the little green ball. When the spinning leaves in the ball go away when braking, you're getting into the friction braking. |
| Thread Tools | |
