Old 11-26-2012, 03:00 PM   #1
dgomezhall OP
Oddometer: 48
6v Electrics
Working on restoring a old bike with 6v electrics...everything is working, but I'm changing handlebars and need to replace the handlebar control switches.
Anyone have any experience with
Will they work with 6v as I assume they're made for 12v?
dgomezhall is offline   Reply With Quote
Old 11-26-2012, 07:00 PM   #2
michael1968
michael1968's Avatar
Oddometer: 788
Yes, simple things like switches should* be fine. You only need to worry about more complicated things like rectifiers etc.
*I say should work because there is a slight chance that the current in a 6 v system would be to high for the 12v switches. Voltage=Current x Resistance so half the voltage means you have twice the current in any given system, you're old bike is probably putting out less watt's than a newer bike so I wouldn't worry.
Cheers,
Michael
michael1968 is offline   Reply With Quote
Times are GMT -7.   It's 07:55 PM.
