Old 11-27-2012, 05:07 AM   #3796
Moronic
Moronic's Avatar
Oddometer: 1,727
Originally Posted by oalvarez View Post
So, is the journo saying that the Stelvio's cast and spoke wheels weigh the same but that the lighter of the two motorcycles (8v) is the easier to maneuver/flick around? No surprise if so. Or is he talking about the construction of each wheel and how the weight is distributed amongst them (hub, spokes, rim versus one cast piece)?
The latter.
He is acknowledging the NTX carries more weight, but attributes most of the steering difference to the wheel construction, with the cast wheels carrying a lower proportion of their mass at the perimeter.
So, the gyroscope effect was less pronounced on the cast wheel, he believed. This made for lighter steering, which he greatly preferred on twisting tarmac prevalent at the launch.
Sorting out the S4Rs Ohlins shock: click here.
Moronic is offline   Reply With Quote
Old 11-27-2012, 05:15 AM   #3797
dmac57
dmac57's Avatar
Oddometer: 3,017
Originally Posted by khale View Post
Better? Not sure where I pulled 'absorbent' from, maybe I meant 'obscene'
Originally Posted by NoVa Rider View Post
exorbitant. . ..
There it is.
Whew! Good on ya for being a good sport!
"Everybody's got to believe in something.
I believe I'll have another beer."
- W. C. Fields
dmac57 is offline   Reply With Quote
Old 11-27-2012, 10:12 AM   #3798
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Originally Posted by RichBMW View Post
That's interesting, as I will be predominantly riding on road. I may have to give this a little more thought.
And the Stelvio licenses the spoked wheel patent from BMW, so the construction is similar. Another factor to consider aside from rotating mass is stiffness...the spoked wheels are stronger offroad because they have some flex...which I would think would be a negative for paved twisties.
EJ_92606 is offline   Reply With Quote
Old 11-27-2012, 10:17 AM   #3799
Montauk
Oddometer: 280
Originally Posted by EJ_92606 View Post
Cast wheels are fine for casual off road.
Someone keeps reading my mind
Montauk is offline   Reply With Quote
Old 11-27-2012, 10:18 AM   #3800
RichBMW
RichBMW's Avatar
Oddometer: 2,118
Another good point. I've never noticed any handling issues on my current GS, and that has spokes, so am sure I'll never ride to the bikes limits. As long as they are priced similar to the current spoked wheels, and the bike is priced sensibly, I'll go cross spoke, otherwise my decision will be made for me.
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 11-27-2012, 11:18 AM   #3801
Montauk
Oddometer: 280
I wish this spoke vs cast rim issue was just as simple as picking colours.
I was going to do some physics calculations at higher accuracy (not involving the effects of tire and flexing of it at higher speeds along with the effects of gravity due to vertical alignment), but I decided for later if time permits.
Here's what I think: Assuming total weight to be the same for either rim, the geometry of weight distribution are quite different. Spoke rims will weight higher at the ends, because of total weight minus the small weight of sum of spokes. While the Cast rim will have weight distributed across the wheel due to weight of cast spokes. Hence, I suspect the centripetal acceleration to be different, while the centrifugal force may remain somewhat the same (it could also change). Due to increased centripetal acceleration for a spoke rim at a given constant speed, the effects of turning on a curve would be pronounced as we increase the angle of lean.
This effect translates to a feel and handling of a bike on a paved curve. Scientifically, it would be there, however, once you start riding your own bike, you get accustomed to its handling, and you make adjustments to it without even knowing. This is what I call your "style" of riding. We ride bikes that we own, unlike journo's who tests them against another.
So, IMHO, I think get the wheel you want, spoke is great because it has tendency to flex if you were to go off-roading or unexpectedly go over big bumps, it will be far more forgiving. It also means about $500 more as an option!
Old 11-27-2012, 11:58 AM   #3802
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
I don't think the spokes create an issue, its just a question of whether the cast wheels handle slightly better on pavement.
Old 11-27-2012, 12:52 PM   #3803
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,700
Old 11-27-2012, 01:37 PM   #3804
RichBMW
RichBMW's Avatar
Oddometer: 2,118
Wow, thanks for the detailed response.
Originally Posted by Emoto View Post
That was funny! I liked the summary that Montauk gave though, I knew the was a more scientific explanation
2015 BMW R1200GSAW
Old 11-27-2012, 01:57 PM   #3805
grpweld
grpweld's Avatar
Oddometer: 324
Just saw this, knew about it but hadn't seen this clip before! I just really love the sound of the wet head :)
http://www.youtube.com/watch?v=76HUC...em-subs_digest
09 R1200gs
grpweld is offline   Reply With Quote
Old 11-27-2012, 02:30 PM   #3806
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,615
Who wrote their script director? I like what Charlie says at the end... NOW, you can conquer the world...
Facebook
Nova Scotia on Explorer
2012 Triumph Tiger Explorer
http://novascotiaexplorer.blogspot.com/
Voluhzia screwed with this post 11-27-2012 at 04:03 PM
Voluhzia is offline   Reply With Quote
Old 11-27-2012, 03:00 PM   #3807
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,700
Old 11-27-2012, 07:54 PM   #3808
TuonoBiker
Oddometer: 809
This is why I love the ADV forum.....can't imagine reading this response over on the vtwinforum where I, from time to time, tune into the latest "hadda lay 'er" down harley threads. lol
Very detailed and it forced me to think back to my college Calculus-based physics class.
'12 R1200GS Adventure
'06 Ducati 999S
'11 Harley Street Glide - gone and mostly forgotten
'07 Tuono Factory - gone but not forgotten
TuonoBiker is online now   Reply With Quote
Old 11-28-2012, 01:10 AM   #3809
Montauk
Oddometer: 280
Fuel consumption
Official Fuel consumption as taken from press release:
90km/h l/100km is 4.1 L (57mpg)
120km/h l/100km is 5.5 L (51mpg)
The 120km using 5.5 L (51 mpg) of gasoline seems high fuel usage. I would expect this machine would run leaner, so I would expect it more like 53-54 mpg at 75 m/hr speed. What do you guys think?
I don't own a recent R1200GS, therefore I cannot relate. For my current bike the difference lies about 2-4 mpg at those speeds in approximation and mine is not leaner at all.
Old 11-28-2012, 03:01 AM   #3810
Deans BMW
Granpa Hoon
Oddometer: 3,527
My '10 GS consistantly gets from a low of 38-39 to a high of 42-44 MPG. The new wet head sounds like it will do 5 to 10 MPG better in mixed riding. BTW, the sound of the BMW at the very end of the video sounded fantastic as it wound out.
I am liking, big time so far everything that I am hearing about this new bike.
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW is offline   Reply With Quote
Times are GMT -7.   It's 02:14 PM.
