Thread Tools Search this Thread Rating: Thread Rating: 401 votes, 4.93 average. Display Modes
Old 11-27-2012, 02:27 AM   #6001
Bli55
Oddometer: 381
I'm stuck...
I want to replace that small locking screw on top of the rugged mount with a longer finger operated one, but, how on earth do you take it out??
I unscrewed it as far as it goes, now it just bounces up and down on its spring.
Bli55 is offline   Reply With Quote
Old 11-27-2012, 06:19 AM   #6002
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,678
Originally Posted by Bli55 View Post
I'm stuck...
It's a captive screw; it is not supposed to come out.
With enough force, anything is possible.
Old 11-27-2012, 06:22 AM   #6003
DrtSqtr
DrtSqtr's Avatar
Oddometer: 147
thanks garmin
Thanks to all that helped me with my Montana but after many frustrating months its finally going back to Garmin. Map data would not hallways show up on screen. Garmin gave me an RMA # so a new one will be shortly here. Hope this works.
DrtSqtr is offline   Reply With Quote
Old 11-27-2012, 06:24 AM   #6004
mass-klr
mass-klr's Avatar
Oddometer: 168
Wiring the Amps Rugged Mount
In case someone is wondering how to wire you GPS to have power only when the key is turned on, I found the following to connect the GPS as a Switched accessory.
But since I only want to have one Switched accessory connection I did the following. Switched blue wire is inserted under the Running lights fuse.
Less than $20 :)
mass-klr screwed with this post 11-27-2012 at 06:34 AM
mass-klr is offline   Reply With Quote
Old 11-27-2012, 06:38 AM   #6005
gspdbill
noobie allover again
Oddometer: 404
Originally Posted by slowpoke View Post
I just got one and I'm still learning how to use it. I have 400 pages to go through here. Lol
Same here. Being delayed waiting for the microSD cards, should be here today.
Bill
'05 R1200GS for now......
gspdbill is offline   Reply With Quote
Old 11-27-2012, 06:45 AM   #6006
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,393
I don't have an sd card in my Montana and no storage issues yet. Don't let that keep you from using your new toy
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 11-27-2012, 07:09 AM   #6007
MizzouRider
MizzouRider's Avatar
Oddometer: 1,776
Mine's still in the box. Haven't had time to look at it yet. Recd the rugged mounts and Ram Amp Ball. Ready to get started.
I still need to read much more. Not sure what software, maps, cards, etc, I need to get started.
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Old 11-27-2012, 07:41 AM   #6008
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,759
Just do it. Get your hands on it and start using it. It's the best way to learn!
Old 11-27-2012, 08:07 AM   #6009
Bli55
Oddometer: 381
OK, I figured it out. Brute force can often solve everything, but there's also the long way...
And it doesn't break your mount!
Old 11-27-2012, 08:58 AM   #6010
mass-klr
mass-klr's Avatar
Oddometer: 168
What did you do to get it out? And what are you replacing it with?
My Security screw is also not catching the thread. Garmin is sending me a replacement mount. Hope the new one is OK.
Old 11-27-2012, 10:11 AM   #6011
Bli55
Oddometer: 381
mass-klr,
I've been taking pictures so will post them when I get a replacement.
Old 11-27-2012, 04:30 PM   #6012
chabon
chabon's Avatar
Oddometer: 293
I want to do the same thing. I was told I have to pull the wiring harness (which I cut up) off my bike to return it with the mount to get a replacement mount with a working screw! Easier just to fix myself. I'm thinking you have to take off the 4 tiny screws and open up the back of the unit to replace the screw???
Copper Canyon Mexico or Will I Come Back Alive?
Baja Team 6
Barracas Del Cobre
Chabón - F650 Funduro - WR250X
chabon is online now   Reply With Quote
Old 11-27-2012, 05:10 PM   #6013
TravellingStrom
TravellingStrom's Avatar
Oddometer: 397
Less than $20 :)
What's missing here is a small fusein the line going to the Montana after the relay
www.travellingstrom.com
TravellingStrom is offline   Reply With Quote
Old 11-27-2012, 05:11 PM   #6014
ramz
Professional Trail Rider
Oddometer: 2,006
That's what I did. The stock screw is too short to grab more than a thread or two.
I disassembled the mount by removing the four tiny screws and got access to the small e-clip that holds the screw in the case when the screw is unseated. I removed the screw and replaced it with an M3 x .5 - 6mm allen head screw. The stock screw is an M3 x .5 - 5mm with the threads removed just below the screw head - where the e-clip fits.
The replacement screw I'm using is threaded all the way, so when I screw it into the case, it does not sit loosely held in by a clip. When I want to lock the release mechanism, I screw the replacement screw all the way in using an allen wrench. It is a bit more awkward to use than the stock setup, and I'm going to ask a machinist friend of mine if he'll cut away the threads like the stock screw and I'll fit an e-clip and have a setup similar to the stock screw. I won't have a torx security head, just an allen head, but the screw will be the correct length.
ramz is offline   Reply With Quote
Old 11-27-2012, 05:37 PM   #6015
stevepsd
Oddometer: 226
Been playing with my Montana 600. Loaded the Garmin 2008 100K topo's onto it's built storage and then put NT North America 2013.20 onto a uSD card. Everything works great.
However, I thought with all the customization available on this unit that I could have the 100K Topo's active (and the NT 2013.20 disabled) when in 'Recreation' mode and the reverse when in 'Automotive' mode but it appears that the maps that are 'active' or 'disabled' are not tied to any one mode. Or am I missing something?
-steve
'12 XT1200Z SuperTénéré, '09 KTM 530 EXC, '08 Triumph Tiger 1050, '87 XR600R Street Legal
Gone but not forgotten: '92 Yamaha TDM850, '82 XJ550 Seca, '80 XS1100,'85 GL1200A, '84 V65 Sabre, '80 CB750F SuperSport, '77 RD400, '72 TS250, '69 CB450K, '68 CL70
stevepsd is offline   Reply With Quote
Times are GMT -7.   It's 09:29 PM.
