Old 10-07-2012, 05:22 PM   #661
usgeese
Oddometer: 25
Took the bike out yesterday for my first time and went about 60 miles in the foothills nearby. First impression: the seat has to go. Felt like I was sitting in a bowl and that I was pushed to far forward and it was as hard as a board. Nor the first time that I have had issues with BMW seats. The bikes power was a little surprising and felt that it could have also used a 6th gear but overall I am happy with. Had my first WTF when I rode a mile to get gas before my ride nd the bike would not start after getting gas. It turned over but never caught. I followed the owners guide to the letter but it would not start. Pushed out of the way, took the gear off, popped the filler open and waited about 10 minutes and tried again with success. After the ride I was going to try to start it again after a few minutes but forgot so I was not able to try and duplicate what had happened earlier. Went out after 15 minutes and it started fine.
usgeese is offline   Reply With Quote
Old 10-29-2012, 12:04 PM   #662
usgeese
Oddometer: 25
Dealer says it's the battery. I call B/S. After checking the battery and finding nothing wrong I took it or a ride. Going down the highway at 70mph the motor quits on me. I had the bike towed to the shop . With the ignition turned on but the bike not running the battery showed 6.6 volts. Replace the battery and have not had any starting issues since then.
I have had the seat rebuilt, put bar backs on it, and new footpegs that are lowered about 1/2" from the original height and I now really like the bike. I don't feel like I am riding a scooter any more.
usgeese screwed with this post 10-29-2012 at 06:32 PM
Old 11-07-2012, 12:13 PM   #663
UnsafeHOTADVENTURE
Oddometer: 46
18,000 mile service
Brought the bike in because it died on me in Silverado Canyon. They replaced the fuel pump assembly and decompression lever. They also went to do the 18,000 mile service and have found that i need new brake rotors front and rear. They say they are out of spec.
How could rotors be dead in 18,000 miles? This sounds ridiculous to me. Anyways if they are only .3mm out of spec is it really that big of a deal? I just put new pads on and they want to scrap the new pads as well.
My biggest question is will sprockets, chains, and brake rotors from 2006 F650gs fit on my 2011 g650 or have they changed anything? I would like to purchase aftermarket parts and install them myself rather than pay 500 dollars in labor for bmw to install there overpriced parts. But there is no aftermarket parts on most websites for 2011 g650s. I can get parts all day long for the older f650 and I would imagine they should all fit. Am I right?
UnsafeHOTADVENTURE is offline   Reply With Quote
Old 11-17-2012, 05:46 PM   #664
hvacnut
Let's Ride!!
hvacnut's Avatar
Oddometer: 34
Originally Posted by Steamy Moose View Post
Does any one here run a wolfman tankbag on there G650GS? if so, do you have a pic you could share please?
Life is good ride more!!!
hvacnut is offline   Reply With Quote
Old 11-22-2012, 09:09 AM   #665
Sphene
Ridin' Fool
Sphene's Avatar
Oddometer: 29
tire question
Happy Turkey day everyone. Does the 2011 and newer run tube type or tubeless?
Sphene
Sphene is offline   Reply With Quote
Old 11-22-2012, 09:13 AM   #666
trrt
Oddometer: 75
tubeless
Tom
Ride a White Swan, or a White G650GS 2011
trrt is online now   Reply With Quote
Old 11-27-2012, 05:59 PM   #667
Albatros
Albatros's Avatar
Oddometer: 64
Hi. I want to change my hand guards by the Touratech. I understand that you have to raise the handlebars, change the original brake line and remove the weights, however, I have understood that the latter alters the control of the bike. I would like to hear opinions of those who have these hand guards. Thank you.
Albatros is offline   Reply With Quote
Old 11-27-2012, 09:13 PM   #668
Lost Rider
Broken Roadie
Lost Rider's Avatar
Oddometer: 2,787
I don't know about the TT guards, we used Highway Dirt Bike Guards, but I raised our bars by 2" with ROX risers and didn't need to change the brake line. Never noticed much difference in anything after removing bar end weights.
I posted about it all earlier in this thread.
Good luck!
Lost Rider is offline   Reply With Quote
Old 11-28-2012, 03:58 AM   #669
ar1814
ar1814's Avatar
Oddometer: 99
Are you considering these ones : http://www.touratech-usa.com/Store/3...Sertao-2011-on ?
They look like the same as these (credits LostRider) :
If so, I'm interested too, as I want to mount them on my 2004 F650GS with ABS and have the same question about the brake line+risers..
I'm pretty sure you need the longer brake line for the ABS models (and the G650GS all have it), you might not need it if you don't have the ABS, because the brake line goes directly to the front brake...
ar1814 screwed with this post 11-28-2012 at 04:04 AM
ar1814 is offline   Reply With Quote
Old 11-28-2012, 02:30 PM   #670
Albatros
Albatros's Avatar
Oddometer: 64
Good luck!
Yes, I want to put these handguards TT and my bike is the model with ABS. The rise handlebar is 34mm and need change the brake line. The question is whether these handguards are really strong and if remove the weights can change the stability of my bike. Thanks.
Old 11-30-2012, 05:27 PM   #671
Lost Rider
Broken Roadie
Lost Rider's Avatar
Oddometer: 2,787
No, in my experience those hand guards are not strong, they flex and allow the levers to break, defeating the purpose. That's why we went with HIghway dirt bike guards.
We have ABS and no additional brake line was needed when using the 2" ROX risers.
I don't see how removing the bar end weights effect stability, I always thought they were they for vibration damping. Never really noticed they weren't there on any bike I've taken them off, but that's just me.
Good luck!
Mobile ADV Fix Complete
Old 12-02-2012, 11:22 AM   #672
reenmachine
Rain or Shine
Oddometer: 147
Bar ends simply add mass to lower the natural frequency of the bars, hence reducing the annoying high-frequency vibration at higher rpm. Removing them won't hurt the stability of the motorcycle, but may reduce cruising comfort. However, if you're removing them to add hand guards, you're adding the mass back so it's probably a wash.
'11 BMW G650GS
'02 Yamaha FZ1
reenmachine is offline   Reply With Quote
Old 12-08-2012, 08:04 AM   #673
WayOut
Be like water
WayOut's Avatar
Oddometer: 2
OK, so I picked up a new 2012 G 650 GS in Sept. & absolutely LOVE it! I have ~3500 miles on it so far; almost all pavement at this point but we'll be hitting some dirt soon & I'm sure many drops are in our future. This bike is loads of fun & seems to defy gravity. I've been riding on the streets for almost 30 years now & this bike is even more fun than my old RD 350! I tried the F 700 GS, & it's a great smooth engine, but it just didn't feel right to me, seemed too top heavy. Even the G 650 GS is a bit heavier than I'd like, but when it's moving you can flick it around so easily, I feel like I could ballroom dance with it! I want to thank the people on this thread, I got some great info from this site!
Some logistical notes I'm 5ft-5 & ~140 lbs.I have the bike with the factory seat & no lowering, it feels a bit big when I'm trying to back it out of a slight incline (I'll sometimes walk beside it to move it into position) but when I'm riding it, or stopped at lights, it feels great. When you lean hard to the left, the 1st thing you scrap is the kickstand (no centerstand on mine) but it doesn't feel like it's even close to sliding out at that point. I haven't scrapped anything on the right side, yet
I bought it stock, I wanted to feel how the Beast ran, without any add-ons. Then I added some stuff 1 at a time:
  • BMW handguards
  • Wunderlich Tobinator windscreen adjustment
  • Hippo Hands (I love them)
  • Caribou 34 Liter B&W Top Case
Here are some pics:
The moto glamor shot a few days after getting it
And here's some showing the accessories
WayOut is offline   Reply With Quote
Old 01-01-2013, 09:55 AM   #674
Steez
USMC Infantry
Oddometer: 201
Happy New Years everyone!
Just curious if you current owners could give me an update on how the cast wheels are faring. Has anyone actually dented the rims? I know when the bike first launched everyone was apprehensive of them.
I'm very interested in this bike, and if the wheels are doing well it looks promising!
Steez is offline   Reply With Quote
Old 01-01-2013, 10:43 AM   #675
reenmachine
Rain or Shine
Oddometer: 147
14,000 miles and mine are perfect. Mostly on pavement, but I've been getting off road more lately and have no complaints.
'11 BMW G650GS
'02 Yamaha FZ1
Times are GMT -7.   It's 03:06 AM.
